07-11-2005, 08:03 PM | #1 |
Member#: 90391
NESIC
Vehicle:2005 sti wrb |
Weird noise when I cut the wheel all the way
like the tittle says when im taking a hard turn or pulling into my driveway the car makes a weird noise like something is scraping ive checked everything nothing is scraping i dont know what a worn out wheel bearing does when its bad but could this be the problem? i have an 05 with 6kmiles on it it also does it when i have the wheel cut all the way and im backing up and i know its not the pwer steering cause i know what that sounds like but if anyone has experienced this please share! thanks
07-11-2005, 08:13 PM | #2 | |
Member#: 79493
SCIC
Vehicle:2003 WRB WRX Wagon 5 doors > 4 doors |
07-11-2005, 10:28 PM | #3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
He has a brand new 05 STi, chances of a bad bearing are close to zero and in any case it's a warranty repair if something is wrong.
Are you sure it's not the power steering, if you hold it at full lock (a bad thing to do) the pump may make some noise. Also I know on the 04's the DCCD would make some noises on tight low-speed turns, the 05 is presumably the same and you may be hearing that. |
07-11-2005, 10:41 PM | #4 | |
Member#: 79493
SCIC
well anyways, your car should still be under warranty, so take it to them, let them figure it out. |
07-12-2005, 01:29 PM | #5 |
Member#: 2133
Vehicle:2005 STi WRB/Gold 2005 S4 Avant |
I bet your DCCD control is set to something other than "Auto"...am I right?
07-12-2005, 05:12 PM | #6 |
Member#: 90391
NESIC
well usually i always leave it on auto but on occasion ill set it to something else but i havent noticed if it has happen while the dccd is not on auto
07-13-2005, 12:28 AM | #7 |
Member#: 72181
Vehicle:2005 Impreza 2.5RS Regal Blue |
I have an 05 RS and it does the exact same thing when I back into my garage, usuallt when I have the wheel fully deflected. However I do not think it is anything bad, I think it is an AWD trait. We used to have a Toyota 4-Runner and when it was in 4 wheel drive it made the same noise on a tight turn, and when it was doing that I read somewhere that 4WD does not like to be turned hard at low speeds so the same might apply to AWD. Also if you look in your manual it talks about hearing odd sounds during certain situations and that it is normal. Just my thoughts
07-13-2005, 08:43 AM | #8 |
Member#: 87520
I've noticed the same thing with my 05 RS, but only when driving
out of my driveway and turning left, with the car cold. I attribute this to cold oil in the center LSD. |
07-14-2005, 06:41 PM | #9 |
Member#: 90391
NESIC
well like someone posted above ive only noticed when the dccd is in another position other than auto.. it just feels awkward when its doin it but ill leave it until i feel like it gets worse cause i dont wanna take it to the dealership and have them look at me like im crazy if this is normal
weird noise when turning on the car? | youngjom | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 07-01-2007 02:32 AM |
Weird Noise When Engaging the Clutch From A Stop | e_a_olson | Transmission (AT/MT) & Driveline | 6 | 06-14-2006 10:23 AM |
weird noise when i crank the car | WRXout | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 08-21-2004 03:18 AM |
weird noise when pressing the clutch | MavWRX | Transmission (AT/MT) & Driveline | 4 | 06-09-2004 01:39 PM |
Weird noises when I hit the accelerator pedal | RootUsr | Service & Maintenance | 2 | 11-09-2003 06:45 PM |
