07-14-2005, 11:13 AM | #1 |
Member#: 38583
Vehicle:2003 WRX Midnight Black |
Problem with battery: water is bubbling up through the little screw caps
I am having A problem with my factory battery for my 2003 Subaruwrx.
I am having problems starting my car. The car turns but it takes like 30 sec for to crank up. Also after it is cranked i ckecked the battery and water is bubbling up through the little screw caps that you put the water in to refill it. What is the problem: battery or Alternator?
07-14-2005, 11:28 AM | #2 |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
Take it to the dealer and don't mess with it too much. IF it is a factory battery, it is covered under warranty for 3 years, 36,ooo miles and it is not pro rated. They replace it for free
07-14-2005, 01:19 PM | #3 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
The battery could be toast, and probably is. If one or two of the cells has died or if it is getting to much electron flow into the remaining cells this will happen. It is doubtful that your alternator has inadvertently increased in effeiciency, so, a battery. I would do a voltage output test on the alternator as well, just for fun, cause maybe it has gotten more effiecient. And be careful, there is Hydrogen gas coming out of your battery at this point as the electrolyte breaks down into the gas. Hydrogen gas likes very much to react with oxygen and blow up, so don't light any cigs around your car or try and look in the holes which you have lit up with your blowtorch!
07-18-2005, 04:42 PM | #4 |
Member#: 38583
Thanks Guys I decided to replace the battery, and know it is running
with no problems. |
07-18-2005, 05:41 PM | #5 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
check the voltage across the battery while the car is running - your alternator may have been overcharging the battery (in which case it'll kill the new one, too)
brake pedal is mushy halfway through the pedal travel | wrxmuch? | Brakes, Steering & Suspension | 28 | 11-13-2009 12:04 AM |
Problem with STI Water Spray | Jrags87 | Newbies & FAQs | 0 | 06-19-2009 10:04 PM |
Correct water line hook up to the turbo | SlidewaySTI | Newbies & FAQs | 2 | 02-18-2009 06:45 AM |
problems with hot water heater | White 2.5rs | Off-Topic | 18 | 01-10-2006 05:12 PM |
problem with gearbox or is this normal??? | Aussie_STI555 | Transmission (AT/MT) & Driveline | 1 | 03-09-2003 01:54 AM |
