07-14-2005, 03:22 PM | #1 |
Member#: 65462
Vehicle:01' 2.5RS Silver/Carbon Fiber |
p0037 after running 87 octane for the 1st time.
I was broke as hell the day before yesterday and I needed gas to get to work so I put in 87 octane for the first time ever since I bought it. I've always put in 91. But anyways, I drove to work and I got this CEL. P0037. Could the gas have caused this cel? thanks -Ryan
07-14-2005, 03:35 PM | #2 |
Member#: 90156
NWIC
Vehicle:1986 Syncro Vanaru 07 SV650 |
P0037 Rear oxygen sensor heater circuit malfunction
The oxygen sensor has a little heater on it, basically just a shorted wire, to help get the sensor up to operating temperature and keep it there. I can't think of how running the wrong octane would affect this circuit. But, maybe one of the great minds here will have something else to say. I am guessing, however, that this is unrelated to your gas usage. Time for a new sensor, most likely. When was the last time you changed? You could clear the code and run the expensive stuff and see if it comes back... |
07-17-2005, 04:03 PM | #3 |
Member#: 65462
Also my air/fuel ratio gauge is hooked up to my rear o2 sensor and my gauge is reading lean. (And I have my fuel pressure at 45psi at idle. with a wrx fuel pump) so the gauge usually reads optimal at idle and a little rich at WOT(Nitrous equipped RS incase you're wondering.)
But I was thinking the Sensor has taken a dump and thats why my air/fuel gauge is incorrect. I have put in half a tank of 91 octane with some NOS octane booster(Black bottle) since this started. No impovement. I clear the CEL everytime I see it but it only seems to come on if the car is warming up. P.S. I have no Catillac Converters. (track pipe with o2 sensor ports) but I've had this installed for months now with no problem. (In case you're wondering, it sounds like crap, kinda like a Baja bug!) |
07-17-2005, 09:47 PM | #4 | |
Member#: 90156
NWIC
Just change the sensor and away you go. That would be the next logical step as it will eliminate another variable in the problem.
Catalytic, actually. |
07-23-2005, 12:01 AM | #5 | |
Member#: 65462
But anyways, the CEL only comes on when I first start my car, and I clear it and it will only come back if I shut it off, let it cool down, and start it again. My question is, will this code make my car run any different? |
07-23-2005, 10:34 AM | #6 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
If you're piggybacking an AFR gauge off the stock sensor (which it sounds like you are) then if I were you I'd disconnect that first and see if it fixes the problem - BEFORE dropping $$ on a new sensor - especially if you're too broke to buy premium gas
07-23-2005, 11:16 AM | #7 |
RIP 1/19/64 - 7/23/11
Scooby Guru Member#: 24654
NESIC
Vehicle:1957 Taggart Comet atlasshruggedpart1.com |
An RS should run fine on 87; why were you putting 91 in it?
07-23-2005, 05:16 PM | #8 |
Member#: 65462
I have a 75 shot of nitrous with some fuel risers. Thats why I use 91. And as for the afr gauge, its connected to the pin out on the ecu. The gauge has been installed for over a year so I don't see how it would all of the sudden start messing with the sensor. And as for the "Too Broke" thing, everyone has hard times. I was doing better the next day.
07-23-2005, 05:27 PM | #9 |
Member#: 24569
South East
Vehicle:2004 Mazda RX8 Titanium |
<-----Thought the guy was trying to be l337 in the thread title. I was like what the hell does "pooet" mean?
I am using teh internet too much. |
Going to wax my baby for the 1st time. question for ya | Super_HKS | Car Care & Detailing | 12 | 09-03-2008 05:52 PM |
WRX in the snow for the 1st time! | BNastyer | New England Impreza Club Forum -- NESIC | 28 | 02-05-2007 11:48 AM |
Stage 2 WRX at the track for the 1st time!!! | JWerty1 | Proven Power Bragging | 12 | 09-29-2004 09:26 AM |
SubEd Leaves the Hizzouse for the 1st time in 3 years | SubEd | Off-Topic | 22 | 05-10-2004 06:35 PM |
Let my wife drive my RS for the 1st time | OG | General Forum Archive | 5 | 07-12-2000 07:46 AM |
