07-14-2005, 09:39 PM | #1 |
Member#: 90326
Need Help Engine Wont Start
alrite guys i really need your help,
recently i changed my front left caliper, all my rotors and i bleeded my brake system, after i finished i tried to start my car and it didnt start, i hear noises and i see the alternator belt moving but the car just wont start can someone please tell me whats going on
07-14-2005, 10:17 PM | #2 |
Member#: 6486
Vehicle:00 Impreza 2.5 RS Blue Ridge Pearl |
If you have an alarm try turning it off with the key fob thingy and try it again.
year? make? model? mods? |
07-14-2005, 10:22 PM | #3 |
Member#: 90326
its a 2002 subaru wrx no mods and no alarm
07-14-2005, 10:26 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
So what else did you do besides work on the brakes? That alone won't do it, unless in the process you somehow ran the battery down by leaving a door open, light on etc.
Does the engine crank over normally and not fire, or does it clunk or click but not crank? Exactly what "noises" do you hear? |
07-14-2005, 10:28 PM | #5 |
Member#: 90326
i went to get my battery checked at lappens and they said the battery is fine the engine cranks normally when i turn the key in the ignition the pulleys and cranks move but it just dosent start
07-14-2005, 10:34 PM | #6 |
Trust no one
Ok then, so answer the other question- what else did you do? There is no way that brake work alone will cause a no-start condition, so you must have done something else at the same time that caused this.
07-14-2005, 10:37 PM | #7 |
Member#: 90326
all i did was the brakes i changed the front left caliper bleed the system and the rotors that was all that i did and now the car won start
07-14-2005, 10:47 PM | #8 |
Trust no one
Doesn't add up. Did you have the key on for any reason for a long time?
Check all the fuses, you may have somehow blown one. Look especially at the "IGN" fuse in the under-dash fuse box, and the main fuses in the under-hood box. When you turn the key to "run" (dash lights on) and pause there before starting, do you hear the fuel pump run for a few seconds? |
07-14-2005, 10:53 PM | #9 |
Member#: 90326
no the key wasnt in the ignitoin at all where i know where the fuest box under the hood is located but where is the under the dash fuse box located? is the fuel pump? what is it suppose to sound like?
07-14-2005, 10:58 PM | #10 |
Trust no one
Pull out the coin tray under the left side drivers dash, the fuse box is behind there. If you have your owners manual all this info and more is in it.
The fuel pump makes a low humming or buzzing from the rear of the car, you should hear it prime if you turn the key on all the way but don't start the engine. |
07-14-2005, 11:04 PM | #11 |
Member#: 90326
alrite thanks mulder i'm gonna give that a try tomorrow afterwork and tell you if it works or not
07-15-2005, 02:53 PM | #12 |
Member#: 90326
i checked all the fuses and they're all ok damn now what? please need help someone
07-15-2005, 03:17 PM | #13 |
Member#: 60649
NWIC
Vehicle:00RS EJ205 swap |
Check to make sure all plugs remain plugged in in the engine bay. Perhaps the AFM or starter wires becake unplugged. Might have been loose for a while and just now came off?
Need Help, car wont start! | JD_STI | Off-Topic | 15 | 01-26-2008 02:48 AM |
Need Help Car Wont Start | muskatomas101 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 12-02-2007 05:13 PM |
Need Help Car Wont Start | jess74 | Electrical & Lighting | 8 | 08-24-2007 03:58 PM |
NEED HELP! car wont start after deck installation! | yeng | Car Audio, Video & Security | 7 | 04-28-2003 05:53 PM |
need help wrx wont start | Brewmaster | New England Impreza Club Forum -- NESIC | 8 | 06-15-2002 09:06 PM |
