Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 08-09-2001, 11:38 PM   #1
25psi
Member#: 3086
2001 2.5 RS
Default Battery relocation to the trunk
Hey guys!
Who done it?
Gimme all the info you got PLEASE!!!! I wish to do it!
Thanks.
Eugene
25psi is offline   Reply With Quote
Old 08-10-2001, 12:42 AM   #2
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
I did it in my WRX. Ask me questions.
Imprezer is offline   Reply With Quote
Old 08-10-2001, 02:44 AM   #3
srosqvist
Guest
Member#:
Did you use a sealed battery box?
Old 08-10-2001, 02:45 AM   #4
srosqvist
Guest
Member#:
Where in the trunk did you put it, how did you mount it and where did you run the battery cables?
Old 08-10-2001, 03:23 AM   #5
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Might want to consider what the battery cables weigh. How much weight are you actually transferring after factoring that in? I remember this argument quite a while back, and it was determined that this did just about nothing. Try a dry cell battery instead.
Streetman is offline   Reply With Quote
Old 08-10-2001, 09:57 AM   #6
slim speedy
Member#: 2254
1992 Sentra SE-R
1999 Infiniti G20
You only need to run the positive line to the front of the car (negitive can be ground to somewhere in the trunk) I would think 4 gauge wire would be more than adequate for running the positive line. And 15 feet of 4 guage wire can't weigh more than a pound or so. I don't think wire weight is a big factor to look at.
slim speedy is offline   Reply With Quote
Old 08-10-2001, 10:04 AM   #7
Frank
Member#: 3791
The battery must weigh like 40 pounds. I HIGHLY doubt that one car length of cable will "outweigh" the advantage of moving the battery out of the engine bay. Sorry for that hideous pun.
Now that the battery is in the trunk how are you gonna rearrange the bits in the engine for optimal heat dissipation and airflow?
Frank is offline   Reply With Quote
Old 08-10-2001, 10:18 AM   #8
2.5 RRRRS
Member#: 206
Why not just get a super light battery and keep it in the front. The battery was relocated to the back on my MG, but I put it back up front due to the excessive weight of the cable, etc. It didn't help weight distribution at all on that particular car.
2.5 RRRRS is offline   Reply With Quote
Old 08-10-2001, 10:30 AM   #9
M_Annequin
Member#: 8314
2002 Impreza WRX
Dirt Over Silver
Default Something else to consider
Weight isn't the only reason to relocate the battery. Think safety.
M_Annequin is offline   Reply With Quote
Old 08-10-2001, 10:52 AM   #10
Shaggy
Member#: 531
2000 RS
Silverthorn Metallic
I have had my car on scales and was playing around with moving items. Relocating the battery to the far rear pasanger side in the trunk shifted 2% to the rear of the car. It _does_ do something.
Yes this was with out adding the wire, and if you want to get picky about weight balance, and I thing you should, run the wire on the pasanger side to help balance the biggest dead weight of any car out. The driver.
Shaggy is offline   Reply With Quote
Old 08-10-2001, 11:10 AM   #11
micah
Member#: 3154
What are the handling advantages of biasing weight backwards in an AWD car?
Is it advantageous to bias weight rearwards, at the expense of increased polar moment?
These are not rhetorical questions, just curious if anybody knows.
cheers
mbs
micah is offline   Reply With Quote
Old 08-10-2001, 11:14 AM   #12
nizz
Member#: 188
2004 Forester XT
24k gold on white
It's an advantage to even out the weight distribution between front and rear in any car for more neutral and predictable handling.
nizz
nizz is offline   Reply With Quote
Old 08-10-2001, 11:25 AM   #13
aspera
Member#: 7879
Have you looked into a Dyna-Batt or a Holley Annihilator battery? You could realize overall weight reduction. A smaller battery might (not sure if there's enough room) also mount behind the driver's side foglight. This would lower it and also free up engine bay room. You could also mount it in the spare tire tub in the trunk (lower).
aspera is offline   Reply With Quote
Old 08-10-2001, 11:30 AM   #14
Iowannaski
Member#: 8268
00 GM67
BRP me ASAP
Well, I think that begs the question: Why not get a super light battery and put it in the trunk?
Another thing to think about is that anybody with an amp in their trunk already has the wire going from one end to the other. Of course, if you have 20-30 pounds of stereo equipment in your trunk you might not be obsessed with lightness...
Iowannaski is offline   Reply With Quote
Old 08-10-2001, 11:40 AM   #15
micah
Member#: 3154
I've heard that said before, and it "sounds logical" but I've never heard a good explanation.
For example, don't the front tires have more to do than the back tires in an AWD car, ie, steering and acceleration/braking, as opposed to just acceleration/braking for the rear tires? "Sounds logical".
cheers
mbs
Old 08-10-2001, 11:50 AM   #16
Iowannaski
Member#: 8268
00 GM67
BRP me ASAP
Let go of the all wheel drive concept for a minute, because all cars (well, all cars that are meant to turn) benefit from equal weight distribution. Too much weight in the front, and the front tires will not have enough leverage to rotate that mass. Too much weight in the back, and the front tires will not have enough traction.
In a car wearing the same rubber on all four tires, a 50/50 weight distribution will provide each of the tires with the same grip (ignoring acceleration and aerodynamic forces).
Old 08-10-2001, 12:04 PM   #17
25psi
Member#: 3086
2001 2.5 RS
WOW! Nice discussion going here!
Ok, here we go.
I want it in the trunk to clean up engine compartment. I have WAAAY too many wires and cables around battery. + Yes a little bit of better weight distribution. (Ideal weight distribution I belive is 51/49 Rear/Front)
I already have nice 4G power cable runing to the end from battery. It is used for my amp. So, I was thinking about reusing it to run power from the back to front to power all the stuff in the engine compartment.
Here is the pic. All in black is what I have now. all in green is what i am thinking.
Picture is here. (Stupid free sute would not allow me to display it)
Now for the questions:
Can I do it the way I designed it?
I know summit sells Battery Relocation Kit, does it include posts that need to be mounted up-front?
How do you mount those posts?
Thanks dudes.
Eugene
Old 08-10-2001, 12:18 PM   #18
jeffg
Member#: 2958
2001 6.0?RS
I would look at bigger than 4 guage wire, and make sure it is fused well. The biggest draw on the battery is during starting. Make sure your wire can handle that load without much loss, or it could be hard to start. If you try using a non sealed batter, make sure it is vented to the out side of the car.
jeffg is offline   Reply With Quote
Old 08-10-2001, 12:25 PM   #19
25psi
Member#: 3086
2001 2.5 RS
Biger than 4G????? 2? It'll be like a hand width thick!!!!
Also fuse I have is 150A one. Really heavy duty fuse. I belive it should do fine to protect my amp, no?
I do plan to go to a seled type battery in the near future but not right away, they are quote expencive.
Eugene
Old 08-10-2001, 12:34 PM   #20
MagicMT
Member#: 4042
2001 Magic Mobile
Old School Style
Default Re: Something else to consider
How would it be safer?
Mike
MagicMT is offline   Reply With Quote
Old 08-10-2001, 05:22 PM   #21
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed (sold)
Default hmmm
I'm not sure how it would be safer either? It definitely does have a weight transfer effect-I cant believe the discussion of cable weight. Even if cable weight were significant its spread down the length of the car and the significant weight(the battery) is transferred to the rear. Its a good project. And I think 4 gauge would be sufficient(check the temperature of the line after starting to be sure) as most resistance is at dirty terminals.
subysouth is offline   Reply With Quote
Old 08-10-2001, 05:44 PM   #22
jeffg
Member#: 2958
2001 6.0?RS
looking at a couple of wire charts, assuming a 50 amp load when starting, and a cable run of 15 feet (closest guess), 4awg wire should be good enough. Make sure you fuse the batter at both ends, one within 18" of the battery and one before the cable goes through the firewall. This will prevent a short from killing your car.
Again, I would like to stress that if you are not using a sealed battery, make sure it is vented to the outside of the car. Wet, non-sealed batteries produce hydrogen and some other gases as a byproduct. If they are trapped in a trunk, or passanger compartment, there is a possiblity of an explosion. Most race organizations would require your battery to be vent anyway.
Old 08-10-2001, 06:33 PM   #23
jonny_boy
Member#: 8539
91 Miata
Revhead Red
Default Something else to ponder...
Why not just drive in reverse
But seriously, I own a Miata which comes standard with the battery in the boot/trunk and the non-sealed battery issue is a serious one. Even with venting I believe the gas it produces will corrode the metal around it. More technical info on this topic can be found on miata.net's forum.
Jon
jonny_boy is offline   Reply With Quote
Old 08-19-2001, 11:19 PM   #24
aspera
Member#: 7879
My old MR2 had the battery mounted down by the steering rack...not possible in the WRX. If I get a small, light battery for my WRX I would like to mount it behind the driver's side foglamp underneath the stock location. This would free up engine room. It would mount the battery lower in the car. Wiring would be nearly as short as stock. There is already a grommet right in front of the battery for wires to go into the front fender. I took out the foglight and looked around to find lots of unused room in the fender.
Battery Relocate to Trunk? DinoGuan Electrical & Lighting 7 09-01-2006 02:33 AM
Battery relocation to trunk jblaine Electrical & Lighting 5 02-14-2005 10:03 PM
Has anyone relocated battery to the trunk? tonytiger Normally Aspirated Powertrain 12 08-12-2002 05:49 PM
anyone relocate their battery to the trunk? tdxflex Car Audio, Video & Security 12 07-08-2002 11:01 PM
I reduced 70 lbs on my A4, and relocated the battery to the trunk Cary Lam Vancouver Impreza Club Forum -- VIC 12 04-26-2002 06:33 AM
