07-15-2005, 02:29 PM | #1 |
Member#: 50167
Vehicle:1996 Subaru STI RA White |
2004 STi: Cruise Control Problems
I have a 2004 STi. I travel for my work, and my STi sat out for almost 4 days while I was in NYC. I came back from my trip, and my cruise control no longer works. There is no CEL, there is not any hesitation. When I hit the button the cruise light turns on, but I cannot set or resume. It doesn't light up, and it doesn't function. I tried to check the Neutral saftey switch out when I filled up with gas last night, and it seems to be fine. I tested all of the other electronics in my car, and they seem to be functioning properly. The car was not driven while I was gone, and before I left the cruise worked. My car is heavily modified, but this should have nothing to do with what is going wrong on my car. I will take it in for warranty service if need be. It only has 31,000 miles on it. If I do that my powertrain warrenty is gone for good. I was planning on trading the car in to the dealer in a few months. I need some help, and I've done a search and came up with nothing.
I am going to check the following today: -Neutral saftey switch -Cruise control fuse -flash the ECU
07-17-2005, 02:12 AM | #2 |
Member#: 50167
I pulled and checked every single fuse and there was a blown fuse that had nothing to do with the crusie control, but somehow knocked it out. Problem is fixed.
07-17-2005, 11:21 AM | #3 |
Member#: 69198
Can you post which fuse it was just in case I, or someone I know, run in to this problem down the road?
07-17-2005, 07:01 PM | #4 |
Member#: 50167
Sure I'll do that later today.
cruise control problem | avatarr | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 10-27-2003 10:39 AM |
cruise control problems? | extraducksauce | Service & Maintenance | 2 | 10-26-2002 10:43 AM |
4EAT + cruise control problems | kami333 | Newbies & FAQs | 0 | 08-19-2002 02:27 PM |
Cruise COntrol Problem...Help? | Rubasu | Normally Aspirated Powertrain | 2 | 06-12-2001 05:04 PM |
Cruise Control Problem | AndyHidley | Technical Forum Archive | 2 | 07-20-2000 11:04 AM |
