07-18-2005, 04:56 PM | #1 |
Member#: 24409
SCIC
Vehicle:'03 Comatose WRX Wagon. Parked. |
WRX spitting coolant, but no sign of leaks
Recently, about 4 months ago, I blew the top radiator hose. I replaced it with the OEM hose, and was back in business. But now, for the last few days, I am noticing (smelling and seeing) increasing splatter, and loss of coolant at the top of the radiator. No increase in engine temps, but I am concerned. Anyone have any suggestions on where an unseen leak may be, or what might be going on? TIA
MT
07-18-2005, 05:39 PM | #2 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
the top seam of the radiators tends to develop leaks (where the metal meets the plastic) but that seeps rather than splatters - if you are getting splattering, maybe the new hose is a little loose?
07-18-2005, 06:54 PM | #3 |
Member#: 3808
Vehicle:2005 Forester XT!!! Crystal Gray Metallic |
When they leak at the seam on top coolant leaks down & is picked up by the fans. That's what makes it seem to be spraying all over. Check the hose clamp at the radiator end of the hose. If it's loose that could be the source of your leak. Keep a close eye on your coolant loss. Don't want to fry your engine.
07-18-2005, 10:35 PM | #4 |
Member#: 59203
Vehicle:1999 Forester Black |
Make sure it's not the radiator cap leaking. I once replaced a radiator only to discover later the radiator cap had a split gasket.
good luck |
07-19-2005, 01:10 AM | #5 |
Member#: 24409
SCIC
Thanks for the feedback so far. I forgot to mention that I did make sure that everything was tight. Maybe it just wasn't tight enough...
I will check it out. Bump for anymore ideas, feedback |
07-19-2005, 01:15 AM | #6 | |
Member#: 46336
South East
Vehicle:2013 BRZ |
07-19-2005, 07:11 AM | #7 | |
Member#: 22412
SWIC
I was under the 3/36 when mine started leaking, so it was replaced under warranty. |
07-19-2005, 04:36 PM | #8 |
Member#: 24409
SCIC
Cracked Radiator!!!!
So I found the source of my leak to be about a 2" crack on the top of the radiator. I guess its time to dip into the Subie fund and pull money out for stuff that isn't fun. Damn.
Anyone have any recommendations for a new one? This is a daily driver. Not a race or autocross car. Oh, and IBgetanoem because at this point, I know where and how much for one. I am looking for some other alternatives that are priced comparably, or maybe even less. Thanks again for the help! MT |
07-19-2005, 10:49 PM | #9 |
Member#: 23258
Vehicle:2005 STi White |
If you get another oem, chances are it will fail again. When mine went on my '02 WRX, I replaced it with a PWR: fit perfect, retained stock fans.
Some other options are Griffin, Koyo, and Fluidyne....just to name a few |
07-20-2005, 12:17 AM | #10 | |
Member#: 25187
Vehicle:2020 Forester 2010 Challenger R/T |
07-21-2005, 07:15 PM | #11 | |
Member#: 23258
07-22-2005, 12:15 AM | #12 | |
Member#: 25187
07-25-2005, 12:50 PM | #13 |
Member#: 43853
NESIC
Vehicle:2004 WRX Sedan Stg 2 Platinum Silver |
i just got my radiator replaced under warranty last week. it was leaking from the seam. you would think subaru would use a better designed radiator with all the problems people have with them.
07-25-2005, 01:05 PM | #14 | |
Member#: 25187
07-25-2005, 01:30 PM | #15 |
Member#: 12340
Vehicle:2002 WRX 2.5L Hybrid WRB |
Well Kean, you are driving a GM.
Just giving ya guff man, don't take it personally! |
07-25-2005, 02:59 PM | #16 | |
Member#: 25187
yeah.... that thing had more problems than you could imagine over the 10yrs/110k miles I had it. Paint, differential, intake manif gasket, radiator(s), transmission(s), coolant leaks (at the intake manifold), windshield wiper motor, alternator, distributor, etc. |
07-25-2005, 04:01 PM | #17 |
Member#: 12340
Oh believe me, I can imagine just how much stuff you had to do to that thing. After working on cars for over eight years I have seen it all.
Just curious, I would be willing to put money on you going through 4 or more alternators in that period taht you owned that truck. Would that be accurate? |
07-25-2005, 04:10 PM | #18 | |
Member#: 25187
07-25-2005, 04:17 PM | #19 |
Member#: 12340
Well Kean, I am glad to see that you have a Subaru now. I am actually on my second one, my first was a '99 2.5RS and I like a complete idiot, sold that car for a '97 Cobra. Well, I learned my lesson after I replaced the clutch only to find out that it was actually the transmission that was the problem. So I decided to get my dream car the WRX and make it what I wanted it to be. And no problems with my tranny either!
07-25-2005, 04:35 PM | #20 | |
Member#: 25187
As for the quality of my Subaru, I've been quite satisfied. However, my wife's '99 Honda Civic (although lacking the "fun" factor) has proven to be an absolute champ in reliability. ......now I just need to focus on my '69 Charger so I can get it back on the road again. |
Is this a sign of a big leak or little leak | Bad Noodle | Newbies & FAQs | 4 | 06-14-2008 05:34 PM |
Car turns over but no input of fuel? | silentt | Normally Aspirated with bolt-on Forced Induction Powertrain | 16 | 12-28-2007 09:19 PM |
Coolant is disapearing with no signs of leaks!! | boostinscooby | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 20 | 06-19-2007 12:37 AM |
UP Rattle but no leak / What kind of replacement nut for UP studs? | Zoinks | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 09-06-2005 07:48 AM |
CEL goes on but no sign of boost creep. | Alfaneggio | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 07-29-2004 11:00 PM |
