Welcome to the North American Subaru Impreza Owners Club Friday April 28, 2017
Old 07-27-2005, 10:37 AM   #1
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
Default AC Compressor Pulley?
I have a MY97 Legacy GT. The bearing in the pulley is whinning and aout to go out. I was told by the dealer that the pulley is not replaceable and I need a new compressor which cost over $700 dollars. Has anybody replaced the pulley?
HIHO is offline   Reply With Quote
Old 07-27-2005, 11:14 AM   #2
sm1tnwes
Member#: 87125
2001 Outback
Dark Red
does it whine all the time? if not, it could be the tensioner i beleive.. that is the problem on my bros 95 legacy... he has to get around to fixing it still though
sm1tnwes is offline   Reply With Quote
Old 07-27-2005, 01:32 PM   #3
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
HIHO, wow, long time no hear from. Good to see you post again.
Its the bearing in the A/C clutch?
ss
subysouth is offline   Reply With Quote
Old 07-28-2005, 09:05 AM   #4
HIHO
Member#: 7624
BD5; family sedan
Yeah it's been a while. Yes the bearing in the magnetic clutch assy is going out. I think I found the part on Suparu Parts. I just need to know how to remove the clutch. Does anyone have a manual that shows?
Old 07-28-2005, 10:30 AM   #5
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
My Haynes manual just shows the complete compresser swap. IIRC it usually involves some specialized tools to get the clutch off most newer vehicles. I would call a reputable A/C-only shop and see if they've done the swap. If you can buy the part seperately, it seems like it should be doable though, dont know why the dealer said they need to swap the whole thing.
You have to get the air gap correct(by shimming IIRC) on the clutch or it can stay closed and burn out the compresser or the clutch wont engage correctly and it will wear out prematurely. I am pretty handy with tools but I think I'd probably let a shop do the swap. It would suck to do the work then have to replace it again or the compressor a couple of months down the road.
ss
Old 07-28-2005, 01:20 PM   #6
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I tried pulling the clutch off with a puller, and it wasn't budging. It does require special tools.
The bearing itself for the clutch is more then likely going to be integrated in the AC compressor. So just swapping clutches really isn't going to help.
I'd recommend finding a used compressor, or get your current compressor rebuilt. I checked into having mine rebuilt, and it was around 300 bucks. If you're interested in that route, I can probably dig up the link to the place I called.
josh
Legacy777 is offline   Reply With Quote
Old 07-28-2005, 07:04 PM   #7
HIHO
Member#: 7624
BD5; family sedan
I can get a new one at Advanced for $298. That sucks.
AC compressor and lines, tensioner w/pulley, and AC belt shibby2821 Engine/Power/Exhaust 24 08-01-2010 05:15 PM
AC compressor, STI engine harness, side feed fuel rails V8Nate Engine/Power/Exhaust 17 07-10-2010 02:28 PM
ac compressor pulley won't turn legacy1907 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-05-2009 01:16 AM
wtb: Idler pulley the pulley under the ac compressor stiboss Private 'Wanted' Classifieds 5 04-06-2008 02:32 PM
Squeeling AC compressor pulley. What to do? ilmaestro Normally Aspirated Powertrain 18 09-08-2004 06:36 PM
