Welcome to the North American Subaru Impreza Owners Club Wednesday June 26, 2019
Old 07-31-2005, 04:35 PM   #1
palmerx141
Member#: 58312
WRB Bugeye SQC 217
272whp/283wtq
Default Torque Specs For O2 Sensor?
Attaching mechanical cel fix. Anyone know what to torque it to?
palmerx141 is offline   Reply With Quote
Old 08-01-2005, 01:12 PM   #2
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
I have the front O2 sensor instuctions in front of me - I assume the rear is the same. According to the factory manual: Torque = 22.1 ft-lb. Apply anti-seize SS-30 by JET-LUBE (the Loctite equivalent should be #37616).
jac04 is offline   Reply With Quote
Torque specs for Cosworth rod bolts for EJ25? Navid Built Motor Discussion 0 10-20-2007 10:57 PM
looking for torque specs for valve cover, spark plugs and coil packs Tobey Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-13-2005 03:35 PM
wire color for o2 sensor potholessuk Electrical & Lighting 3 01-26-2004 04:35 PM
FYI - Special Socket for O2 Sensor MNbiker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-03-2003 10:33 AM
THERE IS A RECALL FOR MY00 RS FOR O2 SENSOR PROBLEM CALL YOUR DEALER CHACHI Normally Aspirated Powertrain 12 04-07-2001 03:07 PM
