Welcome to the North American Subaru Impreza Owners Club Saturday December 16, 2017
Old 08-01-2005, 12:12 PM   #1
Bundyboyz
Member#: 32764
2003 WRX with 91K
New Motor & Paint WRB
Default and now for something crazy
I'm in a situation, and that's why I'm asking this question.
Mr. Tire ruined a rear tire... just one by having the toe way out. The tires really only had a few thousand miles left anyway. I replaced the tires and wheels with a package from discount tire direct.
See thread... thoughts on this 17 x8 package 848
Anyway to even up at Mr. Tire I got a free alignment done right... belts replaced. And they said they will find a take off 16 tire, to put on my old 16 wrx wheel... to match up close enough to have a tire wheel that will work as a full size spare for my 17 inch tire wheel combo.
Let's simpllify. Is it possible to use a 16 inch wheel tire combo to act as a full size spare. I assume it'd be like a 205/60/16 tire. I need to do some math. Anyone have an idea of what tire to run? The spare would need to match a 225/45/17 obviously tire width isn't important but the height is...
The spare would only be used to get me a few miles to safety or what not, as I'm aware of the diameter difference can fry your diff.
Bundyboyz is offline   Reply With Quote
Old 08-01-2005, 03:08 PM   #2
Bundyboyz
Member#: 32764
2003 WRX with 91K
...bump still trying to figure this out, so as not to cause damage.
Old 08-01-2005, 03:28 PM   #3
Blackboxracing
Member#: 90106
you got it, as long as your overall diameter is the same (your aftermarket stuff should have the same stock diameter) your good
Blackboxracing is offline   Reply With Quote
Old 08-01-2005, 03:28 PM   #4
Thingfish
Member#: 91451
03 WRX
A 205/55/16 ( Stock WRX ) matches a 225/45/17 . Both are 25", +/- .1 , depending on maker.
Thingfish is offline   Reply With Quote
Old 08-01-2005, 04:44 PM   #5
ripvw
Member#: 27790
correct, and 205/55x16 is what I am using as my full size spare on my original 16x6.5 alloy.
calculator here for matching up other sizes:
http://www.miata.net/garage/tirecalc.html
rolling circumference of 225/45x17: 78.5
rolling cicumference of 205/55x17: 78.2
(nominal measurements, actual will depend upon tires)
while the 225/45x17 is very slightly larger, as you wear down those tires they will get closer in rolling circumference to your (hopefully) unused 205/55x16 spare. Subaru specs call for all tires to be within 1/4 inch rolling circumference, so you're pretty damn close. In my opinion, the 1/4 inch spec is a good thing to shoot for, but for short distances it doesn't matter that much.
By comparison, the T135/70x16 donut is miles off with a rolling circumference of 73.64, which is why those with automatics using the donut are supposed to pull the AWD fuse and put their car into FWD. Those with an MT should try to run the donut on the front wheels - open diff.
all of this and much more was recently an entertaining topic in the News and Rumors forum:
http://forums.nasioc.com/forums/showthread.php?t=812110
ripvw is offline   Reply With Quote
Old 08-01-2005, 05:08 PM   #6
Bundyboyz
Member#: 32764
2003 WRX with 91K
alrighty! well done nasioc.
And now for something completely different... ajbinord Mid West Subaru Owners Club Forum -- MWSOC 2 04-16-2005 02:03 AM
And now for something completely different... WHTWRX Off-Topic 7 08-07-2003 12:39 AM
And now for something completely different.... WHTWRX Off-Topic 21 07-30-2003 04:34 PM
And now for something completely different... Your favorite Monty Python Lines. redoktober_99 Off-Topic 52 08-29-2002 11:18 AM
And now for something completely different rao Mid West Subaru Owners Club Forum -- MWSOC 13 06-15-2001 08:42 AM
