Welcome to the North American Subaru Impreza Owners Club Saturday August 13, 2022
Old 07-06-2008, 02:09 AM   #476
ony
Member#: 159169
2000 rs
been on my gc since the spring.
ony is offline   Reply With Quote
Old 08-11-2008, 11:26 AM   #477
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
Yimi Tuned 296AWP/322TQ
any more pix? this is going to be my next mod!
T
Tahoe SC is offline   Reply With Quote
Old 08-12-2008, 09:08 PM   #478
BIGSKYWRX
Member#: 7958
09 GH B+
Old 08-12-2008, 09:17 PM   #479
GeoffSFAs10
Member#: 173996
nice. i think me needs to do this soon.
GeoffSFAs10 is offline   Reply With Quote
Old 08-13-2008, 11:38 AM   #480
06 subaru xt
Member#: 185699
Angry humm
nice
06 subaru xt is offline   Reply With Quote
Old 08-15-2008, 08:18 PM   #481
Tahoe SC
Member#: 131996
2006 CGM WRX Wagon
thanks big sky!
got my kit today, will likely install this weekend.
looks like i have to drill the holes for the rear brackets too as they only have like 1/2 hole showing.
looks easy enough though.
how long of bolts did you guys use with the brackets to go through the trunk area?
Old 08-16-2008, 03:02 AM   #482
stoyo
Member#: 187060
Very nice! Who doesn't like a diffuser?...
stoyo is offline   Reply With Quote
Old 09-12-2008, 09:22 PM   #483
go0sebumpz
Member#: 147521
11' WRX Swaggon
when drilling the oe brackets onto my 03' would i need to remove my spare tire in case?
go0sebumpz is offline   Reply With Quote
Old 09-12-2008, 09:49 PM   #484
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you are going to be drilling from the underside of the car into where the spare is, you might consider removing the spare first...
Old 01-03-2012, 08:52 PM   #485
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Bringing back from the dead.. I just installed mine but the bracket that bolts to the Sub-frame brace will not tighten down with the 4 little screws that go in it.
I tighten them as much as possible and the bracket stile moves UP and down.. Anybody know how to fix that?
Dat8687 is offline   Reply With Quote
Old 03-10-2012, 11:47 PM   #486
Ride Operator
Member#: 18710
02 GDA PSM
12 Impreza Sprt Lmtd MBP
Default drill baby, drill
Thread necro, sharing my install I did last weekend, was pretty easy. Didn't feel like spending the cabbage on the Cusco bits so I drilled.
Pic of some of the the hardware I used. Parts were the diffuser, 2 steel brackets, diffuser bracket, and miscellaneous hardware from the hardware store.
Note - I missed the rear diffuser hole on the left by about 1/8th of an inch so had to fudge that one a little and make the screw hole slightly larger by drilling the plastic:
Diffuser bracket installed with the two holes I drilled (note the predrilled holes not used):
Rear view shot of diffuser bracket:
Steel brackets installed on the under carriage (note my Cusco rear sway bar installed September 2002, it is holding up well to the elements and it's why I finally decided to drill, SoCal weather ftw:
Diffuser installed:
Steps:
0) Pop your truck, clear out the spare tire, etc. Get your car up on jack stands or ramps.
1) Attach diffuser bracket to diffuser and measure the two holes needing to be drilled on the bumper side. Done by holding up the diffuser to the under carriage and eye balling.
2) Drill those two holes and loosely bolt the diffuser onto those two holes, check work, then remove diffuser and attach the two steel plates to the diffuser and re-attach diffuser to the bumper side bolts. So now the diffuse is installed on the bumper side only and hanging.
3) Most difficult part next... get a sharpy out and get under the diffuser and trace where the two plates match up on the undercarriage, you only need to trace enough so that you can line up the plates. This requires some work in adjusting the plates so that they fit in a good spot under the car.
4) Remove the diffuser and match up the two plates to your traces, start drilling again. I used two holes per plate as seen in my pics. At this point I had drilled 4 holes in the under carriage and two holes near the rear bumper.
5) Attach the steel plates, 2nd pair of hands is helpful here, so you can attach the plates to the spare tire wheel well/under carriage.
6) Mount the diffuser. Take pictures. Take everything off and rattle can spray were I drilled just because...
7) Final step (still need to do) paint shiny silver bolts viewable from the rear of the car with flat black model paint.
Ride Operator is offline   Reply With Quote
So I finally got round to fitting an 06 diffuser UKjon Member's Car Gallery 14 10-07-2006 11:18 PM
06 Diffuser Kit Install?? Boosted1456 Brakes, Steering & Suspension 2 09-13-2006 09:39 PM
F/S cusco rear subrame brace and 06 diffuser kit stilix SCIC Private Classifieds 21 09-06-2006 08:28 PM
06 diffuser mounting RuWRXcrazy2 Interior & Exterior Modification 4 03-13-2006 07:42 AM
06 diffuser for gc8 k22addict Interior & Exterior Modification 4 11-21-2005 09:19 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
