Welcome to the North American Subaru Impreza Owners Club Sunday January 22, 2017
Old 08-14-2005, 03:57 PM   #1
rsracer2005
Member#: 72326
2005 WRX
Default Pressure in my tires. They look low.
How much psi should be in my tires? I have 215/45/17 toyos mounted on 17x7 enkei rpm2. thanks.
rsracer2005 is offline   Reply With Quote
Old 08-14-2005, 04:34 PM   #2
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Open your driver's door and look at the sticker.
Neek is offline   Reply With Quote
Old 08-14-2005, 05:22 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
..which will tell you a pressure that is at least 5psi too low for any kind of performance at all......those pressures are for grandma.....or fat, lazy, stupid, americans.
Old 08-14-2005, 06:12 PM   #4
Odin
Member#: 25428
2005 STi
What would you reccomend for stocker's on an STi? They call for 36F/30R.
Thanks.
Odin is offline   Reply With Quote
Old 08-14-2005, 08:49 PM   #5
DP WRX
Member#: 14984
2002 WRX Wagon
WR Blue / TXS STG2
Depends on the tires, but as Uncle said you're going to want to increase the pressure. For example, I just put BFGoodrich KDWS tires on and am running 40psi. I just took off Bridgestone S-03s running about 35psi. Anything higher on the S-03s were too hard for my old butt.
I'd start at 34-35psi and see how that feels.
DP WRX is offline   Reply With Quote
Old 08-14-2005, 09:07 PM   #6
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Nonsense. It's a fine place to start then adjust up from as you see fit. I do like to keep the 6 pt. difference front to rear in my STi.
Old 08-14-2005, 11:59 PM   #7
gregr01
Member#: 49333
04 STi
java pearl black
The OEM RE070s do not require any additional psi for street driving, even spirited.
Since the 05 STi is a bit camber challenged (compared to the '04) you may benefit from a few more psi, especially for autox. Just increase in 2 psi increments (equally front and rear) until you find a setting you like.
If you can't tell a difference then 36/30 is fine.
/hijack
gregr01 is offline   Reply With Quote
Old 08-15-2005, 02:45 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Let's STOP talking about the STi and the re070.....those are NOT regular street tires.....OK!!!!!
Get past that. The OP does NOT have an STi and what works for an STi and the re070 does NOT apply to his issue.
...and my previous post stands.
Old 08-15-2005, 10:25 PM   #9
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
I am currently at 40/38. But thats a bit higher than I usually run.
ss
subysouth is offline   Reply With Quote
Old 08-15-2005, 10:32 PM   #10
solbey11
Member#: 89234
The tire pressures inside the door are for alignment purposes as well. I'm not saying that raising your tire pressure will drastically reduce the life of your tires, but if you ever had to align a car you would know what I'm talking about. I aligned a car once and forgot to set the tire pressures. After I did that it threw almost every alignment angle out of spec. My suggestion would be if you are going to run higher pressures all the time get it realigned with those pressures on the car.
solbey11 is offline   Reply With Quote
Old 08-15-2005, 10:47 PM   #11
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Good advice.
ss
Why am I building so much pressure in my crankcase? bmxpunk Built Motor Discussion 45 08-28-2009 12:30 PM
look whats in my tire!!! Nickr9287 North West Impreza Club Forum -- NWIC 33 01-13-2008 08:07 PM
Low water pressure in my House. How do I increase teh pressure!!?? wrxman555 Off-Topic 26 12-14-2003 12:31 AM
How mamy pounds of pressure should my tires have??? woohoosbru Newbies & FAQs 12 05-08-2003 05:58 PM
What? More air pressure in front tires? Lightsped Brakes, Steering & Suspension 22 09-22-2002 01:50 AM
