Welcome to the North American Subaru Impreza Owners Club Saturday January 29, 2022
Old 08-21-2005, 06:47 PM   #1
dgaseven
Member#: 37125
Default Update: Mr. Singh's Innovations in Engine Technology
Last year I read/posted a very interesting article from Popular Science about
Mr. Singh's grooved cylinder heads which resulted in cleaner/cooler engine
operation. He now has a website for anyone interested in this little techique.
http://somender-singh.com/
Without grooves, the combustion is incomplete and
unburned fuel remains in the cylinder. This unburned
fuel is still expanding during the exhaust stroke. At
the end of the exhaust stroke, the expanding unburned
gases flow past the intake valve into the intake manifold,
causing poor idle.
With the grooved cylinder heads, combustion is
more complete leaving little unburned fuel behind,
more of the fuel is used to generate power and less
is used to generate heat. (Thatís also why the engines run cooler)
With the modified heads little or no unburned fuel
remains during the exhaust stroke. With less unburned
fuel to expand during the overlap period, the gasses
flowing past the intake valve are reduced, resulting
in improved idle quality.
This image depicts the flame front (dotted line)
and a gas jet created by the groove (yellow arrow)
What is more difficult to show is the multi-point
flame front and increased turbulence within the
cylinder leading to more efficient combustion.
dgaseven is offline   Reply With Quote
Old 08-21-2005, 06:51 PM   #2
whoosh
Member#: 40989
OT vag inspector
try it on your car and let us know how it works.
so it's like breaking a wave and mixing it back up?
whoosh is offline   Reply With Quote
Old 08-21-2005, 08:05 PM   #3
Bill The Butcher
Member#: 41721
2004 STi Silver
Bill The Butcher is offline   Reply With Quote
Old 08-21-2005, 08:09 PM   #4
whoosh
Member#: 40989
OT vag inspector
if the car burns almost all hydrocarbons then the exhaust would be cleaner.
if it's cleaner then you wouldn't need cats.
no cats= mo' power.
so. if you did this to subie heads could you pass emissions with no cats?
Old 08-21-2005, 08:29 PM   #5
Hazdaz
Member#: 14611
How is this idea that much different than the HEMI engine, and it using a hemispherical combustion chamber?
I mean I realize that one involves grooves and the other reshaping of the chamber itself, but the ideas are sort of similiar, yet seems that everyone is quick to discredit Singh's idea because it is "too simple".
Maybe I don't know enough about engine internals (and I will be the first to say that I am not a 'greese monkey'), but Singh's idea sounds quite interesting. Seems to me that some of the best ideas are very simple and make people go "why didn't I think of that".
Hazdaz is offline   Reply With Quote
Old 08-21-2005, 09:12 PM   #6
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I enjoyed reading the article. I hope one of the tuners here tries it and reports.
thanx for the link
Carl
1 Lucky Texan is offline   Reply With Quote
Old 08-21-2005, 09:22 PM   #7
whoosh
Member#: 40989
OT vag inspector
i see the connection...pulsating TITTIES!
Old 08-21-2005, 09:35 PM   #8
evilnissan
Member#: 73937
2008 Jeep Patriot
beater silver
evilnissan is offline   Reply With Quote
Old 08-21-2005, 10:27 PM   #9
dmpi
Member#: 49987
04 STI
BLUE/SILVER
He needs to build a prototype. Something simple. Maybe a motorcycle that can get 200 miles/gallon. Then he can show the world, that he is right.
dmpi is offline   Reply With Quote
Old 08-21-2005, 10:39 PM   #10
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
I hear the tornado works too!
DoctorNick is offline   Reply With Quote
Old 08-21-2005, 10:42 PM   #11
skywaffles
Member#: 82470
Supercharge any car: 49.95! 40 hp on stock cars! Increased gas mileage! Cures cancer and AIDS!
skywaffles is offline   Reply With Quote
Old 08-21-2005, 10:42 PM   #12
Chuck H
Member#: 20442
Maybe he needs to test it on a modern engine that already has pretty efficient combustion. The fact that he can make anitquated carbureted motors more efficient with his method doesn't have much relevance to modern fuel injected motors. With a motor running in closed-loop mode maintaining 14.7:1 stoichiometric A/F ratio, there isn't a lot (if any) extra gas leftover when the combustion cycle is done, so what difference are his grooves going to make?
Chuck H is offline   Reply With Quote
Old 08-21-2005, 10:43 PM   #13
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Never had a condom with grooves? it just feels better!
Old 08-21-2005, 10:51 PM   #14
dmpi
Member#: 49987
04 STI
BLUE/SILVER
Do you wear the grooves on the inside or outside?
Old 08-21-2005, 10:52 PM   #15
DoctorNick
Member#: 7022
2001 Forester
Arcadia green
Don't ask me, I don't wear condoms when I'm banging my woman
Old 08-21-2005, 11:51 PM   #16
soldmyboxster
Member#: 65520
Vortex Valve OWNZ. Especially after both of their Pikes Peak cars failed to finish.
soldmyboxster is offline   Reply With Quote
Old 08-22-2005, 12:11 AM   #17
HighWayDrifter
Member#: 8908
2012 Ford Raptor
i would be worried about those ridges causing detonation due to the heat and introduction of new fuel and air on intake..
IE
those ridges are going to be marginaly hotter then the valleys after the exhaust stroke.
meaning on the compression stroke you might get some detonation as the fuel hits those hotter regions of the chamber..
just some thoughts.. prob why dude goes with larger "ridges" then smaller ones.. would make a huge difference on a FI setup i would assume.
HighWayDrifter is offline   Reply With Quote
Old 08-22-2005, 01:12 AM   #18
dgaseven
Member#: 37125
Old 08-22-2005, 01:23 AM   #19
dgaseven
Member#: 37125
here's my take on that situation... What companies have spent millions of
dollars on research to achieve, Singh has matched with a few grooves inside
a cylinder head.
Old 08-22-2005, 05:13 AM   #20
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
a cylinder head.
How many of them have tried something as wacky as cutting grooves into the head?
drees is offline   Reply With Quote
Old 08-22-2005, 05:23 AM   #21
nhlfan
Member#: 81464
1993 civic si
Talking
nhlfan is offline   Reply With Quote
Old 08-22-2005, 05:32 AM   #22
Davidss
Member#: 27446
I tried his idea twice.
Once on a 5hp go cart and it worked... It was almost night and day. It was quieter, the exaust was cooler, and it had more low end torque!
Then we tried it on a 89 240sx. The results were unconclusive. Sometimes it seemed more powerfull and sometimes it seemed slower. I think part of the problem was that it needed a standalone to nail down the timing...
Davidss is offline   Reply With Quote
Old 08-22-2005, 10:24 AM   #23
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Someone introduce Mr. Singh to Larry Windmer. Larry's "Roller Wave" pistons, his "soft head" configurations, and these head notches may be a good match.
Ditto on the concerns about the edges of the grooves causing hot-spotting in the head though.
[edit]Okay, I read TFA and looked at the pictures. No more hotspotting concerns, this looks quite interesting. I wonder if the decreased temps can be attributed partially to the increased combustion chamber volume the groove creates?[/edit]
Chromer is offline   Reply With Quote
Old 08-22-2005, 10:34 AM   #24
aod
Member#: 7121
If it worked, then the major manufacturers would already have in in their cars. You know, since they are always looking out for the best interests of their customers and all.
aod is offline   Reply With Quote
Old 08-22-2005, 11:08 AM   #25
StiDreams
Member#: 26315
07 Outback
Silver/Silver
Yeah, our best interest, that's what they're always looking out for.
StiDreams is offline   Reply With Quote
engineering vs. engineering technology bvallerand182 Off-Topic 127 10-30-2008 06:04 PM
News Flash: SRT engineers reveal breakthrough in race technology! upnygimp Off-Topic 15 06-25-2007 06:51 PM
Engine Technology SUBE555 News & Rumors 170 10-06-2006 07:21 PM
Cool Engine Technology - No Vlave Springs! 37% eff. in a 2 stroke! Hitokiri General Community 15 02-07-2005 10:38 PM
Anybody know if Subaru is working on more efficient engine technology? danc General Community 24 03-02-2002 06:24 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
