08-22-2005, 08:16 PM | #1 |
Member#: 8512
South East
Vehicle:2002 WRX chassis... stage-infinity.com |
The Knock Box
08-22-2005, 09:06 PM | #2 |
Member#: 21980
NESIC
Vehicle:2002 PSM WRX (Sold) 2017 BMW X5 |
Neat. No price listed so I assume its too much for me
08-22-2005, 09:29 PM | #3 |
Member#: 37731
haha, i thought this was going to be a post about your car
08-23-2005, 01:01 AM | #4 | |
Member#: 39235
08-23-2005, 10:45 AM | #5 |
Member#: 64228
actually i rememeber ~$400
08-23-2005, 10:52 AM | #6 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
i like the noise cancelling headphones!
09-10-2005, 10:55 PM | #7 |
Member#: 18446
Vehicle:2002 WRX wagon psm |
09-11-2005, 12:12 AM | #8 |
Member#: 15918
NWIC
Vehicle:08 STI/02 PGT WRX DGM / Orange |
I've been thinking about making a product like this that incorporates a FM modulator so you can just listen through your car stereo / or FM headphones. I'm curious how much interest there would be. You could also do some cool stuff interfacing to a PC via the sound card input and using FFTs and normalization to a recovered tach signal to see the knock events in time / energy plots referenced to TDC...
09-11-2005, 11:08 AM | #9 | |
Member#: 67608
As for the normalization and such, most modern ECUs already do all that. They have a "knock window" referenced to TDC as well as a specific set of frequencies. Good ECUs will have a RPM/Load "noise" map, which amounts to a normalization map, though it doesn't continuously renormalize; it's just set once at the factory. -Adrian |
09-11-2005, 11:57 AM | #10 | |
Member#: 23717
NESIC
Vehicle:2005 Big red |
TMS |
09-11-2005, 07:14 PM | #11 | |
Member#: 15918
NWIC
09-11-2005, 07:29 PM | #12 |
Member#: 18446
I don't know if this is what you were thinking, but, though I've never really used it like this, I've experimented with hooking one of those cassete shaped thingies (what folks use to play their MP3 players through their car stereo) into my TUNA.
Seemed to work just fine, but I prefer putting headphones on (when I'm tuning in the passenger seat, of course.) |
09-11-2005, 07:47 PM | #13 |
Member#: 56468
NWIC
Vehicle:04 Improved STI Dirty White |
I have a post somewhere on here about hooking up a knock sensor to your PC and using simple (usually free) sound processing software to filter out other engine noise. The valves in my engine tap at about the same frequency as knock, but you can still hear it.
I just bought a Bosch knock sensor at the junkyard and wired it to a mini-audio jack (radio shack has one's that come with alligator clips), and plugged it into my computer. Set the filtering software to "play through," filtered out all sound except 5-10 kHz, and it worked great. You can either play it through head phones or right out of the speakers of the computer. The valve noise is atrocious--one person told me it's the buckets rattling on top of the valves that are making all that racket. |
09-11-2005, 09:33 PM | #14 | |||
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
BTW, I've read at least one Subaru patent that adjusts the knock window based on IAM (e.g. if IAM is low, the knock window is shifted farther from TDC). The J&S Safeguard system tries to employ a "knock window" but, unfortunately is unable to identify TDC or crank angle degrees ATDC. Their "window" is described in a post at http://www.eng-tips.com/viewthread.cfm?qid=54276 but it doesn't necessarily exclude valve closing noise: Quote:
09-11-2005, 10:09 PM | #15 |
Member#: 2992
NESIC
The classic knock detection method is emodied in the TI chip TPIC8101 - Knock Signal Interface. It is a reincarnation of the Harris HIP9010 chip (do a search, it's no longer available). I've seen a Subaru patent that essentially implements this processing in the digital domain.
09-11-2005, 10:26 PM | #16 |
Member#: 2992
NESIC
And then there's the idea that you can discern knock by its "signitaure" instead of its relative loudness. That idea is espoused by http://researchnews.osu.edu/archive/knock.htm and you can see its embodiment here:
where the "backslash" lines represent knock and its declining frequency. And then there's National Instruments' approach to knock detection, described at: http://www.ni.com/svix/engine_knock.htm http://www.ni.com/pdf/csma/us/collins.pdf |
09-11-2005, 10:57 PM | #17 | |
Member#: 2992
NESIC
I have to confess that my responses here were due solely to:
And I'm sure any useful analysis would empoy DSP and FFT. Last edited by Jon [in CT]; 09-11-2005 at 11:03 PM. |
09-12-2005, 12:50 AM | #18 |
Member#: 56468
NWIC
I think you could design a meter that eliminates almost all the valve noise if you could isolate the frequencies.
Interesting web site. I agree that knock has a certain change in pitch that makes it distinct from all other noise, hence even if you are hearing the valves click away, knock sticks out. The human ear is great at detecting the change in pitch (frequency). I'm sure you could get a computer to do it, but it won't be easy. |
09-12-2005, 11:19 AM | #19 |
Member#: 21980
NESIC
A PC can do it in realtime, there was a guy who made his own filter in LabView for his Porshe tuning days.
So far I've used a stock knock (not the stock one, another stock one) sensor spliced into a headphone jack and pluged into an amp (laptop) and then plugged into headphones for listening. I use a set of Bose noise canceling headphones (QC2s and yay for employee discount otherwise I wouldn't have them). So far so good and soon I'll have the TXS Tuner at my door. The bonus of the raw audio is you can record it with a laptop and use the spectrograph as shown above. That works well but I've found our engines to be VERY noisy with the spectrograph and you have to mess with it to clean it up. I have had more luck just listening than trying to analyse. |
09-12-2005, 01:21 PM | #20 |
Member#: 2604
NESIC
Vehicle:1999 2.5RSt RBP |
I am currently using labview for knock detection. send me a pm if you are set up with labview and want to check it out. You will need the signal processing toolset to use it however which is annoying.
Todd |
09-12-2005, 02:09 PM | #21 | |
Member#: 56468
NWIC
09-12-2005, 02:43 PM | #22 |
Member#: 2036
Vehicle:2000 Intrepid silver |
Todd: Is your J&S still connected? It would be interesting to see how it compares to the labview.
The J&S employs a knock window. The fact that it doesn't precisely know where TDC is not important. The window opens near TDC, and remains open for 44°, which is long enough to reliably detect knock. Here's an AEM data log from an S2000 Honda, showing the knock volts vs J&S detector output. Looking at the log, it's difficult to tell when the AEM actually makes a detection. http://www.jandssafeguard.com/Giles/AEMknocklog.html Giles's Gilbert's site http://www.holyrollerdyno.com/ He spent a year fine tuning the AEM maps on his dyno, before he installed the J&S. As soon as he tested it, he emailed back "at last, a real time knock detector that I can rely on". |
09-12-2005, 06:00 PM | #23 | |
Member#: 8512
South East
US Dealer @ Motec:
09-12-2005, 06:01 PM | #24 | |
Member#: 8512
South East
Knock Box vs. Knock Block |
09-12-2005, 06:32 PM | #25 |
Member#: 2036
Here's another knock detector:
http://www.thielert.com/en/automotiv...ment/knock.htm I have a price sheet from a few years ago, and the unit with cable and sensor was 3700 Deutch Marks ($2300). It has a digital output to signal a knock event, and an analog output proportional to knock intensity, for connection to an ECU as a timing modifier. |
Darn it... Just stripped the threads on the bolt that holds the knock sensor in. | Surestick | Normally Aspirated Powertrain | 3 | 04-21-2010 06:28 PM |
07 STi Logs... can you ID the source of the knock? | TROLL | Open Source Reflashes | 11 | 01-25-2008 06:42 PM |
If spun rod bearing happaned..will the knock sound increase when rev the engine up? | skyline31 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 08-29-2007 06:20 AM |
Wiring the knock sensor directly to the SAFC, can it be done? | t3hWIT | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 09-24-2006 12:10 AM |
The Knock Box | garageGT | Engine Management & Tuning | 6 | 05-23-2006 02:59 PM |
