Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 09-01-2005, 11:53 AM   #1
Suberman
Member#: 82487
2007 WRX STI Spec C
Default how to see if engine has AVCS??
How to see if its an AVCS equipped engine??
with a popped bonnet, is it possible to see if its a JDM EJ207 or a EDM EJ207??
Suberman is offline   Reply With Quote
Old 09-01-2005, 12:01 PM   #2
Davenow
Member#: 23676
teh numbers on the engine. Get them, post them.
Or look at the heads/cam pullies.
Old 09-01-2005, 01:06 PM   #3
cronic
Member#: 9749
Look for the avcs solinoids..
cronic is offline   Reply With Quote
Old 09-01-2005, 02:12 PM   #4
ofay
Member#: 69621
05 mines wrx RIP
still hatin ROTAS
what do you look for
ofay is offline   Reply With Quote
Old 09-01-2005, 02:26 PM   #5
Davenow
Member#: 23676
12345
Old 09-01-2005, 03:46 PM   #6
ofay
Member#: 69621
05 mines wrx RIP
still hatin ROTAS
still lost
Old 09-01-2005, 03:54 PM   #7
scoobystas
Member#: 26568
2003 Yellow Bugeye
Version 8-Vf37
wow, the scooby specialists are being very vague today
scoobystas is offline   Reply With Quote
Old 09-01-2005, 05:15 PM   #8
TheMadScientist
Member#: 23717
2005 Big red
Default Non-avcs
Screwed up
TheMadScientist is offline   Reply With Quote
Old 09-01-2005, 05:16 PM   #9
TheMadScientist
Member#: 23717
2005 Big red
AVCS at the top front of the head.
TMS
Old 09-01-2005, 05:46 PM   #10
Scoobs2002
Member#: 64615
2002 Impreza WRX
GT42R Power!
And if its JDM it has it on the back side too.
Scoobs
Scoobs2002 is offline   Reply With Quote
Old 09-01-2005, 06:06 PM   #11
cronic
Member#: 9749
Scoobs
Nope..
Old 09-02-2005, 04:48 AM   #12
Suberman
Member#: 82487
2007 WRX STI Spec C
TMS
a picture says a thousand words....
thanks!!
Old 09-02-2005, 12:29 PM   #13
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I can't seem to figure this one out on my own. What does AVCS stand for?
specialev is offline   Reply With Quote
Old 09-02-2005, 12:34 PM   #14
TheMadScientist
Member#: 23717
2005 Big red
Active valve control system
TMS
Old 09-02-2005, 03:26 PM   #15
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
Thanks for helping me continue my re-education, TMS.
Note - I just found this thread if any newbies like me are interested and like me have more questions. http://forums.nasioc.com/forums/showthread.php?t=134854
Old 01-13-2020, 04:44 PM   #16
sebastian323
Member#: 510671
2006 WRX
Gray
How can I tell if I have dual or single AVCS? I have one AVCS solenoid on each head, and two oversize AVCS cam gears on the passenger side head. The head I have are labeled Z20, and the block is an EJ20 labeled EJ20 Z20 701
sebastian323 is offline   Reply With Quote
Old 01-14-2020, 01:16 PM   #17
subaru_gc8
Member#: 29292
2004 WRX wagon
I beleive those are off a ej20x or y they are dual avcs btw
subaru_gc8 is offline   Reply With Quote
Old 01-16-2020, 01:37 AM   #18
sebastian323
Member#: 510671
2006 WRX
Gray
Yes I have an EJ20x ( I dont know what the x is yet)
This is what my AVCS cam gears look like
https://i.imgur.com/2W3GY2J.jpg
https://i.imgur.com/sMr7bA8.jpg
Old 01-16-2020, 08:14 AM   #19
bugeyerex02
Member#: 195967
WR Blue
EJ20X is the engine code. EJ20X came off an 03+ legacy GT automatic, the EJ20Y came off an 04+ legacy GT with a 5 speed manual.
Both have dual AVCS.
I believe the main difference is the x has a vf38 twinscroll setup from the factory, while the Y has a td04-19t single scroll.
Both good motors. If you have an auto, it's an x, a manual, it's a y, unless a swap has been done.
bugeyerex02 is offline   Reply With Quote
Old 01-16-2020, 03:03 PM   #20
sebastian323
Member#: 510671
2006 WRX
Gray
The little timing belt retainer that is present on manual cars to keep the belt from coming off if you get bumped while parked in first was there (https://parts.mckennasubaru.com/p/Su...hoChhwQAvD_BwE, so I believe the engine came off a manual car. My engine came installed in a manual 06 WRX hawkeye. Does the fact that I have a legacy motor mean the previous owner changed the ECU ?
Old 01-16-2020, 06:46 PM   #21
bugeyerex02
Member#: 195967
WR Blue
There's no way we can tell this. Do you have a taxtrix cable? Can you pull the map and post the ECU ID?
Old Yesterday, 05:50 PM   #22
sebastian323
Member#: 510671
2006 WRX
Gray
The car is a 2006 WRX and the original owner swapped in an EJ20X/Y from a Subaru Legacy GT and retained the original EJ255 ECU and wiring harness. My EJ20X/Y has AVCS on both intake and exhaust for a total of four AVCS cam gears and four AVCS solenoids. I realized there are actually 2 solenoids on the heads for the exhaust AVCS, which were unplugged (one of them even had its connector broken off). I have read on a LegacyGT forum that the EJ20X/Y can be run with the exhaust AVCS solenoids unplugged but that the exhaust cam gears need to be locked in a neutral position to avoid exhaust timing advance/retardation.
If you have the Z20 heads, you should know that when the exhaust side AVCS components are unplugged, the cams go into full retard position, which robs quite a bit of power that the engine should have.
Um. I spoke to Jeremy at Outfront Motorsports, the definitive knowledge source for all things Subaru engine related regardless of continent of origin. He says "why would you want to do that? Tell him it wont work". Then he says, "if he pays you to do it have him sign that your not responsible before proceeding".
Then he proceeds to laugh and go on about all the sand cars he has built (and that I have worked on) with locked cams and unplugged solenoids.
Just trying to save you the grief. All you have to do is leave the exhaust avcs solenoids unplugged.
- https://legacygt.com/forums/showthre...-270757p2.html
how to tell if engine is JDM V7 sti ejcivicdee Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-25-2010 02:59 AM
how to see if struts are blown. SA2USA Brakes, Steering & Suspension 1 01-02-2009 02:16 AM
Just a test to see if OT has infact seen it all Turk Off-Topic 10 01-28-2008 04:45 PM
How to Check if AVCS is on. Tirpitz56 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 10-16-2007 01:47 AM
How to see if a money order was cashed? Hazdaz Off-Topic 7 07-13-2006 08:50 PM
