Welcome to the North American Subaru Impreza Owners Club Wednesday May 31, 2023
Old 09-09-2005, 11:12 AM   #1
Hayaboosted
Member#: 60042
2004 WRX STI
Rotated T67 ALLABOUTSPEED
Default How Could my New Tranny leak?
Hey I just got done putting in my RA gear'd tranny. Well its been 2 days since I completed it. Well last night I see oil on my driveway and check it out. It smells just like gear oil. So the first thing I do is check the oil.. its a qrt low. So I than check the drain bolt. Thats tight. So I took it down to the shop and put it on the lift. It looks as if it was leaking out of the right axel. Im not sure how this could happen. I know the axel pin that i put back in, the end was broken off. But it still went through more than half the axle. It appears to have the same amount of play in the axel as the left side, which is completly dry. I hate these trannys. Just when I thought I was done with it..
Hayaboosted is offline   Reply With Quote
Old 09-09-2005, 11:35 AM   #2
Impr3zy0u
Member#: 93404
On my dsm "not sure if this applys to subarus" the fluid was way over filled and it leaked out the axel. Did you check the fluid worm? i believe thats how your supposed to.
Impr3zy0u is offline   Reply With Quote
Old 09-09-2005, 11:40 AM   #3
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Damaged axle seal! Easy to do and tough to replace. They go on from the inside of the tranny, but could be replaced by removing the CV axle and spinning the back lash adjuster all the way out(thing with the nubs that the axle stub goes through). Never done it this way, but should work just fine and way easier than splitin' the trans.
BTW-they are directional so make sure you get the correct one
Kevin
Crazykev is offline   Reply With Quote
Old 09-09-2005, 12:28 PM   #4
Hayaboosted
Member#: 60042
2004 WRX STI
Kevin
So if it is the seal. Can anyone confirm that I can replace it without removing the tranny? Im really not in the mood to ever want to take it out again.
If its a damaged seal, would it be the transmission builders fault?
Old 09-09-2005, 02:17 PM   #5
Hayaboosted
Member#: 60042
2004 WRX STI
I dont know if it account for anything but when I was a quart shy i added the penzoil syncro mesh, to get it up there again. Well I checked it last night after inspecting it to find where the leak was and after I added the syncromesh. I checked the dipstick and it had a slight white color to the oil. Is that normal.
Old 09-09-2005, 09:44 PM   #6
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The seal is easy to damage putting the axle in, and yes it can be replaced without removing the tranny.
Brian
Old 09-12-2005, 05:25 PM   #7
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
make sure to make a mark on the back lash adjuster housing and the tranny in the same spot so that you know how far to screw it back in when re-installing the housing into the side of the tranny.
I made the same mistake and did it this way...no problem.....it is a PITA to get off though without the Subaru tool....screw driver and hammer worked though.
SloRice is offline   Reply With Quote
Old 09-13-2005, 06:29 AM   #8
Hayaboosted
Member#: 60042
2004 WRX STI
Does anyone have something to show me how to install it? Or is it basically... I have to mark where the adjuster is, remove the bolt and it just comes off?
When I ordered the seal, they also told me to order this giant o-ring. Is that correct?
Old 09-13-2005, 07:45 AM   #9
Andrewtech
Member#: 47821
Yes, you should do the o-ring also. It's cheap and your in there. You may find the inner lip of the seal has been folded over after you remove the side cap. It's very easy to catch the seal when putting the front diff in (left side) and case half on (right side). Good luck.
Andrew
Andrewtech is offline   Reply With Quote
Old 09-13-2005, 08:57 AM   #10
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Just put a bunch of grease on the axle stub before reinstalling so the seal is less likely to get cought up on something.
Glad to see that it can and has been replaced without the trans being split. I always thought it was possible to do it this way, just never have myself.
Kev
Old 09-20-2005, 07:09 PM   #11
Hayaboosted
Member#: 60042
2004 WRX STI
Well I got it fixed. I took about an hour start to finish... The seal was garbage! no more leaks now either.
Old 12-10-2005, 09:15 PM   #12
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
I am having the same leak out of the passenger side of the tranny.
Does any one know the part numbers for those 2 seals?
And what would cause the axle to keep popping out? (I think that is why it is leaking.)
thanks
chudlo is offline   Reply With Quote
Old 12-11-2005, 08:38 PM   #13
Hayaboosted
Member#: 60042
2004 WRX STI
thanks
the axle shouldnt pop out.. check out the dowel pin and make sure its in there
Old 12-11-2005, 11:41 PM   #14
chudlo
Member#: 15505
I am going to a dealership to get it fixed next week. So I will be watching them do the work, and hopefully figure it out for myself.
Which of your seals was damaged?
If you have the part numbers too, I would appreciate you digging them up. I want to order them ahead of time since I have to have the car back the same day.
thanks,
chud
EDIT: I think these are the MT part#s:
G730041 oil seal right
G730042 oil seal left
G97501 o-ring
Old 12-12-2005, 10:40 AM   #15
Hayaboosted
Member#: 60042
2004 WRX STI
Yeah you just buy the seal.. which is obvious. Than the o-ring. Its an easy fix.. But make sure you have that dowel pin on the axel.. Thats the only thing I can think of as to the reason your axle keeps popping out.
Do I have to take apart my new tranny? Cavadini Transmission (AT/MT) & Driveline 0 12-11-2005 03:34 PM
my new tranny sti ra limited 4.44 dccd bigworm Transmission (AT/MT) & Driveline 10 11-06-2005 12:12 PM
How to install new tranny? Clutch? Flywheel? *-* Transmission (AT/MT) & Driveline 0 05-27-2003 12:41 AM
Identifying tranny build date on my new tranny.. GDA Transmission (AT/MT) & Driveline 1 10-21-2002 10:19 PM
So far so good, on my new tranny oil swap.... Philip Bay Area Impreza Club Forum -- BAIC 3 05-14-2001 10:29 PM
