09-19-2005, 10:49 PM | #1 |
Member#: 73144
Vehicle:2002 subaru gda silver |
launch control ?????
hii alll.... i have gda subaru with spec-c engine with LINK ems. now i want to install launch control, but i must buy it separate, because my ems didn`t have launch control features. can u suggest me for launch control brand. Does it safe for my car, because i usually start at 8000rpm. thanks..........
09-20-2005, 02:28 AM | #2 |
Member#: 79708
Vehicle:00' R-STi WRB |
use the clutch for launch control...
09-20-2005, 01:05 PM | #3 |
Member#: 177
NWIC
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
racelogic traction control
09-20-2005, 04:29 PM | #4 |
Member#: 2780
Vehicle:junk yards rule! Project FrankenSTien |
needs a clutch switch to work
09-20-2005, 05:30 PM | #5 | |
Member#: 45790
Vehicle:2006 Corvette C6 Z51 SUPERCHARGED |
09-21-2005, 10:38 AM | #6 | |
Member#: 96509
09-21-2005, 11:50 AM | #7 |
Member#: 56343
SWIC
Vehicle:02 S202 Really! blue |
I have a couple of Rev Lite launch control units they kill both spark and fuel which is safer, Mount switch under clutch pedal
09-21-2005, 03:23 PM | #8 | |
Member#: 95157
Vehicle:05 Impreza RS 2.5 OBP 5spd Winged |
09-21-2005, 05:08 PM | #9 |
Member#: 2289
Vehicle:1998 11.87@112mph Subaru L Ver 6 STi Type R |
If it doesnt break then do it
Ditch the Link for something better if you want launch control. Add on setups are not the way to go. |
09-21-2005, 10:10 PM | #10 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
well launch control will limit your launch rpm in most all cases...what you are looking for is most likely traction control if launching at 8000
try launching at a lower rpm for starters....then see if you still need it |
09-22-2005, 11:25 AM | #11 |
Member#: 177
NWIC
real traction control is a thing of beuty
the race logic is one of the few aftermarket units it reads the abs sensors and adjusts advance to limit wheel slip i know jeff sponagule was trying one out but in hind site scoobie steve has the right idea ditch the link for something more advanced motec/AEM/pectel/$$$/$$$ |
09-22-2005, 11:56 AM | #12 |
Member#: 1185
Vehicle:I flap my gums and now I'm a specialist |
Tried the Motec with anti-lag . Before launch at the start line, the sucker was making 18psi of boost ! Can imagine what WRC cars feel like when they have 3 bar at the start line, with traction control !
09-25-2005, 11:54 AM | #13 |
Member#: 73144
thanks for your suggest..... i think i will take racelogic product....!!! i started that car at 8000rpm because my car is laggy. i used standard spec-c engine with HKS 3037`s turbo. and if i start it under 8000 my car didn`t run well. the rpm will dropped. the launch control not make my engine blow right....???? because some of my frenz say that can make my engine damage if i used launch control...............
09-25-2005, 01:28 PM | #14 | |
Member#: 33782
if the problem is the laggy turbo then just get anti-lag for when you are the track...not to mention it is cooler and doesn't cause ultimately slower 60' times like a TCS can do. |
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? | jigga | Other Engine Management | 5 | 04-17-2007 08:16 PM |
Utec launch control tried out on my 03 wagon | IA Performance | Engine Management & Tuning | 20 | 03-19-2003 07:07 PM |
UTEC launch control in full effect. Opinions within | IA Performance | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 56 | 03-13-2003 07:46 PM |
UTEC Launch control rev limiter? | Typhoon | Engine Management & Tuning | 6 | 01-28-2003 09:08 PM |
Launch control and flat shift...what do you think? | Onederer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 29 | 10-23-2002 06:40 PM |
