Welcome to the North American Subaru Impreza Owners Club Thursday February 20, 2020
Old 09-20-2005, 02:43 PM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default 500whp on the FP Red
As we mentioned in a previous thread about the Forced Performance Red, we intended to push the turbo in a US STI platform. We installed this FP Red, along with the 8CM turbine side (from my 8cm Green) into one of the PDXTuning STIs. Other supporting mods include:
Fully balanced and printed block with CP Pistons
Supersecret assembly technique (just kidding! Tim and I build the block in my garage!)
Stock heads, gaskets, and cams
ARP Head Studs
Forced Performance FP Red with uber cool 8cm turbine housing and 3" inlet.
Perrin FMIC
Perrin Intake
Perrin Modified Injectors
Perrin BigInlet for 3" turbos
TurboXS Turboback exhaust (catless)
AVCR Boost Controller
Exede Hypersingle Clutch
Walbro 255lph fuel pump
Cobb AccessPort with ProTuner
The purpose of the test was to push both a pump gas and a race gas (C16) tune.
The pump gas tune produced the results below. As is obvious, the actual hp would be a bit higher if the dyno had been setup to run a few mph farther, as torque was still holding pretty well. Still we were able to squeeze out 406whp on pump 92 octane. The pump gas boost was about 24psi, and the C16 tune was peaking at about 30psi, running down to 29 at redline.
With the addition of C16 and boost, HP jumped to 507whp, which is a pretty good gain given the under the manifold turbo limitations.
Here is a snapshot of the C16 data. I donít have IDCs or Boost as Tim didnít log those with the Protuner. Iíll see if I can get a street run of the spoolup for comparison.
The most obvious question to come from this data is how did this turbo beat the GT35R? Before anyone jumps the gun, give us some time to complete the comparison. The GT353R tune I did on my car has a number of differences, including: Less boost (as per the posted datalogs, my boost peaked closer to about 28psi because I was hitting the boost cut on the UTEC), a MUCH more restrictive input to the turbo (I had some really old fuel rails that were in the way, so the 4Ē inlet jumped down to almost 2.5Ēs right as it passed the manifold), and less tuning time due to a few hoses that kept coming loose.
Rest assured we will be going back very soon to make this right and see what we can really get out of the 35R on our dyno.
None the less, the faster spoolup and amazing torque of the Red are hard to argue with. You really can get the power without the lag.
Take a look:
Not only do you get better spoolup, but you loose very little over running a green. This green is a Water Injection tune, as most of the regular Greens get more in the 330-340 range.
Finally, here is a snapshot of Timís car in our new shop!
More to come..
Jeff Sponaugle
PDXTuning.com
PDXTuning is offline   Reply With Quote
Old 09-20-2005, 02:43 PM   #2
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Holder for more data...
Old 09-20-2005, 02:47 PM   #3
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
Man, posts like these make me wanna say "SCREW RETIREMENT!" and raid my 401K....
fogdor is offline   Reply With Quote
Old 09-20-2005, 02:53 PM   #4
wrex03
Member#: 29963
04 sti
wrex03 is offline   Reply With Quote
Old 09-20-2005, 03:03 PM   #5
driggity
Member#: 7453
2014 Scion FR-S
Hot Lava
It may not really matter because of the other restrictions on the GT35R setup but what turbine housing was this with?
Great numbers on the Red. The low end looks comparable to the Green on the dyno, but how does it compare in terms of feel on the street? Does it lose much in terms of responsiveness?
driggity is offline   Reply With Quote
Old 09-20-2005, 03:11 PM   #6
TexRex2002
Member#: 36303
06 Evo IX
in a prior pdx post somewhere, there was a comment about there being a noticable difference in perceived throttle response ("true lag" let's call it) between the green and the red. I.e. stomping the gas above boost threshold resulted in more wait time for target boost on the red. Do you guys still feel that way?
TexRex2002 is offline   Reply With Quote
Old 09-20-2005, 03:11 PM   #7
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
great post yet again, cant wait to come home and let you guys tune my 06 with a red
BREWPUBEAVER is offline   Reply With Quote
Old 09-20-2005, 03:12 PM   #8
DeepFreeze
Vendor
Member#: 91288
2002 Ver8 WRX STi
-320
Must, cut credit cards now....must resist...
DeepFreeze is offline   Reply With Quote
Old 09-20-2005, 03:16 PM   #9
InfamousDX
Member#: 25413
still internally gated??? wow!
Old 09-20-2005, 03:47 PM   #10
MARKGSTI
Member#: 70197
Very nice write up, congrats on the power #'s.
Impressive.
MARKGSTI is offline   Reply With Quote
Old 09-20-2005, 03:52 PM   #11
keyser_soze
Member#: 57445
Jeff could you fill us in on your experience in this case with Perrin Modified Injectors (i.e. how did you like them, any thing about them you didn't like, any issues, would have preffered other injectors if you were to do it again etc).
Nice results and thanks for sharing as always. Thanks.
keyser_soze is offline   Reply With Quote
Old 09-20-2005, 03:55 PM   #12
TexRex2002
Member#: 36303
06 Evo IX
also, 30 degs of advance at 7000 !!!
Acessport timing must be different than UTEC timing?
Old 09-20-2005, 04:22 PM   #13
Scoobs2002
Member#: 64615
2002 Impreza WRX
GT42R Power!
I noticed that too, and im sure the timings are not different :|
But hey...race gas works wonders.
Scoobs
Scoobs2002 is offline   Reply With Quote
Old 09-20-2005, 04:36 PM   #14
Lucky Loser
Member#: 70055
a ✈
NICE very nice...
Lucky Loser is offline   Reply With Quote
Old 09-20-2005, 04:45 PM   #15
Gilmore25
Member#: 58985
Wow very impressed on spool up over the 35R.. What if you ran the motor out to 7800 or 8000 RPM would it drop off like a cliff??
Gilmore25 is offline   Reply With Quote
Old 09-20-2005, 04:50 PM   #16
Wombat North
Member#: 21267
STI, EWG 8cm Green
UTEC/ECUtek/WI & SD tune
Can't help but wonder how a green with an 8cm housing and EWG would do on pump and WI.
Wombat North is offline   Reply With Quote
Old 09-20-2005, 04:55 PM   #17
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
What's that MAF voltage...about 4.7~?
Soon2Bgreat is offline   Reply With Quote
Old 09-20-2005, 05:26 PM   #18
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
I'll let Tim comment directly, but you are correct that even though the boost threshold is about the same, the real lag is more. Tim can comment how much, but by my seat of the pants, it's not too much!
It sometimes appears that the UTEC timing is a bit less, but this was a lot of timing due to the C16.
I thought the same thing. The cams might cause more rollloff, but certainly there is still a bit more there at the very upper end!
I'm sure it would do better, but at some point, the compressor is a limiting factor. The 49 lb wheel is no match for the 65lber.
According to the datalog, 4.8 volts, with the BigMAF.
Cheers,
Jeff
Old 09-20-2005, 06:16 PM   #19
9vapors
Member#: 92582
Well come on Tim, I am impatiently waiting!!! Great numbers, congratulations. Makes me want a red rather than a GT35R now, just can't get over the difference in lag and where it makes the power. I am also waiting on the new GT35R dyno sheet, any timeframe on when we might see that? Thanks for posting your finds, and numbers, again, just awesome!
9vapors is offline   Reply With Quote
Old 09-20-2005, 06:30 PM   #20
Usaf*STi
Member#: 88063
06 STi
Black as night
I think after seeing that i might be going with an FP red.... unless i see a similar graph from the 35 in the future.
Usaf*STi is offline   Reply With Quote
Old 09-20-2005, 07:26 PM   #21
turbobob
Member#: 38231
Very nice collection of data. It is always refreshing to see testing performed in a complete and thorough manner.
turbobob is offline   Reply With Quote
Old 09-21-2005, 12:15 AM   #22
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Impressions on protune vs ecutek and utec? I know in the past pdx has advocated the use of the utec on top of a reflash.
santofontana is offline   Reply With Quote
Old 09-21-2005, 01:19 AM   #23
RadarOnPaws
Member#: 47658
Jeff, Tim, I was told the 8 cm housing isn't in production anymore on the FP's, only the 7... is that correct?
RadarOnPaws is offline   Reply With Quote
Old 09-21-2005, 02:42 AM   #24
deluxsti
Member#: 84313
04 Aspen STi
this with stock heads? no porting?
deluxsti is offline   Reply With Quote
Old 09-21-2005, 03:09 AM   #25
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
stock heads, just as its listed above just good old forged pistons.
Ben
anyone got any measurments of the FP Red compressor wheel....? q_dubz Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-23-2009 10:29 PM
New Results with the FP Red! alcrudojr #00 Proven Power Bragging 40 12-26-2007 05:25 PM
510 lb-ft with the FP Red (Part 2) PDXTuning Proven Power Bragging 24 04-14-2007 04:10 PM
Mods needed for the FP Red djyuck Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 33 09-08-2006 01:19 PM
