Welcome to the North American Subaru Impreza Owners Club Tuesday July 14, 2020
Old 09-22-2005, 01:09 PM   #1
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Default 510 lb-ft with the FP Red (Part 2)
As most of you have seen from the previous thread (http://forums.nasioc.com/forums/showthread.php?t=849824) we have been pushing the 8cm Forced Performance Red on one of the PDXTuning STIs.
We took the car over to the local Dynapak dyno for some more tuning. Our goal was to push the midrange boost a bit more, and refine some of the fueling. We target getting a bit over 30psi in the midrange, as well as having it hold to 30psi at redline. We set the boost controller (AVCR) to 90% duty cycle the entire run (learn and feedback off), so this is about the max of what the internal wastegate combo will run.
The results:
510 lb-ft of torque at 4900 rpm, and 521hp at 6700 rpm.
These runs were done on the Dynapak, which as you can see below, records a LOT more torque compared to the Matrix Mustang Dyno. It is well established that this dyno design (which hold the car at the start RPM for a configurable time, often 2-4 seconds) can results in higher then normal torque. (at least when compared to a regular inertial dyno). Also, the load pushed against the car is linear in nature, as the dyno tries to control the ramp time to a liner and constrained rate. (you set the time for a pull). On the other hand, the Mustang simulates real world load by adding additional drag at higher RPM to simulate aero drag. To be clear, in no way would this same car make 510 lb-ft on the Mustang dyno. This should be yet another clear demonstration that you can't make comparisons across different kinds of dynos (much less even the same kind).
Here is the plot of what the car did. ( Note that this is with SAE corrections, which are what most shops use. The dyno can also show either uncorrected or DIN correction. The correction factor wasnít much, since the SAE standard is at 77 degrees, and it was about 80 on the dyno. ) I have not yet seen a shop post results with DIN correction (which reads lower).
As per the previous thread, this is with C-16 fuel, AFRs in the 12.0-12.5 range, and timing was as per the previous thread as well (ramping to as much as 31 at redline).
Also, on the previous thread it was mentioned about the possibility of this car doing a 10 second 1/4mile. While we have not raced the car yet, I would suspect we could get something in the low 11s, but I would not comment or promise it having the power to do mid to high 10 seconds. Based on what I have seen from our results on the mustang dyno, something in the 380-400whp range usually nets 118-119 mph trap speeds, and perhaps 11.9-1.7 ETs. ET's are very dependent on the launch, while trap speed is more power dependent. You would suspect that 500 whp on the Mustang dyno would net something in the 125mph range. As for the ETs, it would be very dependant on the launch and the shifting.
Perhaps someone can reflresh my memory: What power levels were other cars in the 10ís running? (complete STIs of course, not gutted lighted cars)
Looking back at the archives:
"STI 591.1whp USDM *update*-> [email protected] and video as proof "
and
"Few month ago we run [email protected] with 504whp with a USDM STI. "
Using the Mustang numbers (506whp), I would suspect that if we get a good launch and great run, something in the [email protected] might be in the cards.
However, the [email protected] was with 591whp (a LOT more), and NOS!
Cheers,
Jeff Sponaugle
PDXTuning
PDXTuning is offline   Reply With Quote
Old 09-22-2005, 01:09 PM   #2
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
For more data..
To refresh everyones memory:
Mod List:
Fully balanced and printed block with CP Pistons
Supersecret assembly technique (just kidding! Tim and I build the block in my garage!)
Stock heads, gaskets, and cams
ARP Head Studs
Forced Performance FP Red with uber cool 8cm turbine housing and 3" inlet.
Perrin FMIC
Perrin Intake
Perrin Modified Injectors
Perrin BigInlet for 3" turbos
TurboXS Turboback exhaust (catless)
AVCR Boost Controller
Exede Hypersingle Clutch
Walbro 255lph fuel pump
Cobb AccessPort with ProTuner
Also, here is an overlay of Tims car a while ago on the same dyno with a 7cm Green on race fuel. That particular tune was very very wavy because we later determined the wastegate door was a bit loose, and the AVCR had significant trouble keeping the boost constant (thus the nice sweeps in power!)
Old 09-22-2005, 01:17 PM   #3
x99percent
Member#: 27108
2004 STi
2004 A4
Funny, I was just talking to someone else about how differently the DynaPack and Mustang dynos read... it's nice to see results from the same car on the two different dynos.
x99percent is offline   Reply With Quote
Old 09-22-2005, 01:25 PM   #4
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Yep. To be fair, the car actually produces much more torque on the dynapak, due to the load and holding. It's not so much that it measures incorrectly, but more so that its tests the car in a different configuration.
As for which one is more like the street, I'll be posting some data on that soon.
Cheers,
Jeff
Old 09-22-2005, 01:32 PM   #5
flycaster
Member#: 60142
2011 WRX
Grey
So, the waves in both curves are boost fluctuations. Interesting. I guess that makes a case for EWG's. Can you feel this at all on the road?
The difference in dyno numbers is striking. When you guys tuned my GT30R and it made "only" 335 ft.lbs on the Matrix mustang, I tried to explain this concept to a guy with a 20G who is convinced he makes almost 60 ft lbs more. I didn't push it since I don't think he was too interested in hearing it, and we're both happy regardless.
flycaster is offline   Reply With Quote
Old 09-22-2005, 01:36 PM   #6
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Yes.. On the Green, it was noticable on the boost gauge as well. On the Red, I noticed the dips, but there were not as bad.
On the road, it doesn't really occur. The loading on the road is much different, and the boost controller really seems to learn better.
To be clear, I think it would have worked MUCH better with an external wastegate, which we will fit on the car right away.
Cheers,
Jeff
Old 09-22-2005, 02:22 PM   #7
MARKGSTI
Member#: 70197
Where did you get that one from...the guys from PR
Any info about the Green with the bigger 3" compressor cover??
MARKGSTI is offline   Reply With Quote
Old 09-22-2005, 06:00 PM   #8
deluxsti
Member#: 84313
04 Aspen STi
great job guys
so is this flywheel hp or whp, because the other thread says whp and the dyno here says flywheel, or am i just a noobie to the whole dyno conversions
dynapack is the one the bolts to the brakes right?
deluxsti is offline   Reply With Quote
Old 09-22-2005, 06:15 PM   #9
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
It's wheel horsepower, the dynapack's just print flywheel on the graphs for some reason.
When I dyno'd my car last year I actually made more torque on a Mustang dyno than a Dynapack, but that could be due to correction differences (the Mustang was at 5000 ft., the dynapack at about 400 ft.). I did make more whp on the Dynapack however.
Old 09-22-2005, 07:08 PM   #10
PKSJ4
Member#: 92680
2004 STI
nice numbers with a rebuilt block
PKSJ4 is offline   Reply With Quote
Old 10-03-2005, 11:15 PM   #11
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
Thanks! Those pistons seem to be holding up very well. I've been running the same CPs in my 257 for some time now at 2.0bar and things are still holding together great.
A new dual carbon clutch will be going in asap, as the hyper single is toast. I'm curious what other 500+whp guys are running for clutches? RPS Carbon?
Jeff
sponaugle is offline   Reply With Quote
Old 10-04-2005, 12:29 AM   #12
WRXskeet
Member#: 69435
2005 Aspen STi,rip02
Bugeye mafia 02 :(
what is the avalibility on the 8cm turbine housing for the red?
and whats the price on the red?
WRXskeet is offline   Reply With Quote
Old 10-04-2005, 12:47 AM   #13
AntiochCali
Member#: 30185
2003 320 whp
on a heatbreaker dyno
Any ideas on hw a 7cm Red would compare on your setup to the 8cm Red you are running now? Would spool be much improved?
I'd be willing to give up a little up top if I could spool a little better.
AntiochCali is offline   Reply With Quote
Old 10-04-2005, 01:18 PM   #14
Division By Zero
Member#: 7555
Jeff,
I'd like to see some data on the EWG once you guys get it in there. However, not just on the 8cm, but also on the 7cm. Using a large 44mm gate, I wonder just how much of a diff there will be between the two? You might be able to get away using the smaller housing and still be able to come close in top end performance but with a broader torque curve back to the left of the graph.
Division By Zero is offline   Reply With Quote
Old 10-04-2005, 01:56 PM   #15
SW00P_G
Member#: 5591
EJ257 Gt35r
I would bet that the power with a 7cm housing would be almost exactly the same. But you would probably have to run an external gate to keep the boost up on the dyno.
SW00P_G is offline   Reply With Quote
Old 10-04-2005, 04:32 PM   #16
ratt_finkel
Member#: 46218
06 EVO 9
I'm curious, is 1st gear even usable on the street?
ratt_finkel is offline   Reply With Quote
Old 10-04-2005, 04:39 PM   #17
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
^^^lol, some what....
if you really get on it you wont have time to floor it befor you need to shift.
BREWPUBEAVER is offline   Reply With Quote
Old 10-04-2005, 07:08 PM   #18
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Jeff
Last time I spoke with RPS, they said the carbon setup was still in the works for the Subies....so I went with the 6 puck RPS Max. Phil thinks alot of it, and it's not very expensive.
S.
n2xlr8n is offline   Reply With Quote
Old 10-04-2005, 07:12 PM   #19
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Jeff
I'm running an ACT 6puck with pressure plate. It drives well and holds fine so far. It's held up to 6-8 drag launches and passes and daily driving for about 2 months. Granted i'm on a 2.0l and making only 380wtq.
Louis
Soon2Bgreat is offline   Reply With Quote
Old 01-26-2006, 08:05 PM   #20
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
How does the 7cm FP Red compare to the 8cm FP Red. I'm curious for two reasons. First, almost every person that buys one will get a 7cm unless they already have an 8cm FP turbo that can be upgraded. Second, I have currently have two FP turbos (a 8cm 18g and a 7cm red). I plan on having FP put the 8cm on the red which they said would only cost $75. I mainly want to know the differance in top end power. FP said that it could be as much as 10%-15%.
CK02WRX is offline   Reply With Quote
Old 01-26-2006, 08:35 PM   #21
mikaust
Member#: 7468
2008 Outback
very limited
I have used the RPS and ACT 6 puck both have worked great.
mikaust is offline   Reply With Quote
Old 01-26-2006, 08:39 PM   #22
Caplin 2.5
Member#: 71203
2005 2.5rs
Crystal Gray Metallic
im pretty sure you'll prob break into the 10's with a very good run and that new clutch.... good job!! I wish i had a car like that
Caplin 2.5 is offline   Reply With Quote
Old 11-28-2006, 09:25 PM   #23
R0DENT
Member#: 111756
04 WRB STi
Few Mods...
Sorry to bring up an old thread but WOW
R0DENT is offline   Reply With Quote
Old 11-28-2006, 09:36 PM   #24
VIR EURORALLY
Member#: 53517
STi Outback STi
I'm preparing for the 8cm FPRed right now. If I can get anywhere within 20% of this I'll be happy.
VIR EURORALLY is offline   Reply With Quote
Old 04-14-2007, 03:10 PM   #25
badger5
Member#: 128188
2001 seat ibiza cupr
yellow
on the new reds, what size is the internal wastegate ported to?
same penny size as the 7cm green i believe? is that right?
do any of you guys suffer boost creep on the greens and reds on internal gate?
i run a green on a seat ibiza cupra (5v turbo motor, which is 1900cc)-its my racecar. interested in information on how you get on with greens and reds.
i have suffered my 2nd wastegate seizure however on the green, so am worried there is something fundermentally wrong. anyone else had this?
thanks
bill
badger5 is offline   Reply With Quote
FS/FT 2003 Evo FP Red Turbo blazersman Private Vehicle 'For Sale' Classifieds 14 12-03-2009 03:07 PM
I am maxing out MAS with my FP Red, need advice TurboQueef Built Motor Discussion 29 07-30-2008 11:13 PM
400 lb-ft on an 08 STI Stage 2! sponaugle Proven Power Bragging 123 05-17-2008 08:20 PM
New Results with the FP Red! alcrudojr #00 Proven Power Bragging 40 12-26-2007 04:25 PM
485hp Pumpgas/Meth with an FP-Red TopSpeed Proven Power Bragging 25 02-24-2006 10:04 PM
