05-30-2001, 11:38 AM | #1 |
Member#: 5281
Vehicle:2001 Impreza 2.5RS BRP (Black Leather) RB5! |
Cold starting up my Impreza RS 2001
Hi everybody,
Just got a few quick questions. I had driven/owned two cars before and both of them are type I-4 engine. I just purchase a band new 2001 RS a 3 months ago. Knowing the fact that Subaru Impreza is a Flat-4 and EVERYTIME I start up the car it gives a shake left and right as I am starting up my RS. Is this normal?? Am I the only one experiencing this or? I never own a Subaru before and my pass auto didn't do that when I start them up. Last question, From time to time... when I start up my RS.. it "Double" starts the engine in one key turn. What gives? I'm that if this repeatly happens that it can cause some major engine damage. I took it to service and they replace the Iginition AY (Which I have no idea what it is).. but the problem still stands. Anybody experiencing this incident? Any solution? Thank you so much for your expertise~ -AliasAngel
05-30-2001, 01:20 PM | #2 |
Member#: 3288
Vehicle:1998 Impreza 2.5RS Rally Blue Pearl |
Go back to the salesman you bought the car from and ask to start some other cars on the lot and you decide.
Since they replaced an ignition part once already, and the problem still exists, take it back again before you break a gear teeth on the flywheel or the starter solenoid. Albert [This message has been edited by Albert (edited May 30, 2001).] |
05-30-2001, 01:23 PM | #3 |
Member#: 1994
Vehicle:2018 STI WRB |
the "dance" is normal, the double start doesn't sound familiar.
05-30-2001, 01:36 PM | #4 |
Member#: 5281
Thanks Albert for the advice. I definitely plan to take it back to service again. However, the problem only comes from time to time. About 20% of the time~ It is kind of hard to show it to someone the problem if you know what I mean.
Jewbaru~ Hahaha~ the "Dance".... I like the way you put it. The dance is very new to me. I guess all Subaru likes to dance before they run huh? Anybody else experiencing similar problem as mine on start up? Please help out~ What is wrong with my RS ignition? AliasAngel |
05-30-2001, 02:41 PM | #5 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
It happens to me and I always thought it was normal.
05-30-2001, 07:03 PM | #6 |
Member#: 4135
HIIC
"the Dance!?" Man that means my car dances more than I do!!!
05-30-2001, 08:17 PM | #7 |
Member#: 4965
Vehicle:2004 WWhite Evo8 GSR 2010 Outback 2.5i Premium |
It's the "jiggie" that gets it going. It's like the 1st best thing that happens after you turn that key.
05-30-2001, 10:02 PM | #8 |
Member#: 6413
Vehicle:01 Impreza 2.5RS Silverthorn |
I also have a 2001 RS. I get the dance, and I kinda like it! It feels like it's waking up to kick some butt. However, sometimes when it starts I get a "boom" sound. It's not real loud or anything but I have never heard that in any other car before. It is coming from the engine bay not the exhaust. Any ideas what that sound is? Is that normal for Scoobys?
05-30-2001, 10:07 PM | #9 |
Member#: 2277
Vehicle:2001 Impreza 2.5RS Sedona Red Pearl |
I get a bit of a loud grumble when I first start. I think it has to do with the exhaust gases firing and pressurizing your piping. Kind of like a pop/burble/backfire. I think its normal. At least I never worried about it. I had it with my stock exhaust and my aftermarket exhaust. Stock was just quieter.
Keenan |
05-31-2001, 05:12 AM | #10 |
Member#: 4347
NESIC
Vehicle:2006 2.5i Wagon Aspen White |
Boxer engines have the pistons facing out, instead of up like an I-4. The "dance" you get when you start up is perfectly logical if you think about it. And I-4 has balancing shafts to keep it from shaking out of the engine compartment, where a boxer engine's piston vibrations cancel each other out.
As for the double start, I think I've gotten that before on my WRX. I'm not too sure if it's normal. I'm just starting to find all the little quirks in scoobies myself. |
05-31-2001, 07:40 AM | #11 |
Member#: 5281
mad-dog999:
Wow! Finally... I though I was alone on that double starts deal. I guess a few special scoobies like to get a "dance" and a "jiggie" with it, once and a while~ 2001 2.5RS and 2002 WRX both have these little quirks from time to time... It just ignoring sometimes and can get you worry so much you know? After all, we just got our baby not too long ago so~~~ Okay, who else is victimize of this double disco standard deal? -AliasAngel [This message has been edited by AliasAngel (edited May 31, 2001).] |
05-31-2001, 08:42 AM | #12 |
Member#: 481
you should feel the dance with sti mounts and lightened flywheel! it's like a lil' muscle car. you make the car 'dance' by stabbing the gas pedal too.
i dont understand what you mean by 'double start'. could you explain that more? g |
05-31-2001, 09:40 AM | #13 |
Member#: 5281
When you turn on your car with your key... as you make the rotation turn to start it up and release it in one second... The car starts it self and in a 1/4 of a second it starts again as you are in turning the key.
-AliasAngel |
05-31-2001, 10:10 AM | #14 |
Member#: 4347
NESIC
Question: Do you normally only turn the key for a second, no matter what? Or do you hold it until things are purring?
Edit: One other thing When you do start it up, does it ever grind because of the double start? Grinding=bad I think it's only happened once for me, and I'm not sure it's exactly the same thing. I had turned the key all the way, car started, and after I released the key the engine bogged for a second and revved up like normal. [This message has been edited by mad-dog999 (edited May 31, 2001).] |
05-31-2001, 11:35 AM | #15 |
Member#: 5281
Well, I turn the key all the way (Full turn) and hold until the car start... after the engine started... just release the key.
Imagine doing the same thing as above but as you are holding until it start, the engine is about to be on but then dies and come on again... then release the turning of the key. This doesn't happen all the time, It only happens 15% of the time. Boy, it is very difficult explainning this situation because English is my second language.. LOL hahaha~ -Aliasangel |
06-01-2001, 04:25 AM | #16 |
Member#: 4347
NESIC
Sorry I took so long to get back.
I'm not too sure if we had the same thing. I don't know what temps. you have in the mornings down in FL, but this morning in NE the temp. was about 45. I had to hold it a little longer before it turned over, but once it was running it stayed. I'm not a mechanic, so I'd be guessing as to what it would be. Mabye it's a fuel pressure issue? Any mechanics here that could help? |
06-01-2001, 07:38 AM | #17 |
Member#: 1575
South East
Vehicle:2011 WRX Premium Blackest Black |
Aliasangel- If what you are describing DOES NOT include some grinding from the flywheel and starter gear. I'm pretty sure it is normal I get the same thing if it's been real cold and I don't give it a little gas while starting. It's almost like it is going to stall but the ECU says "oh no you don't" and keeps it running.
Again to reiterate, no grinding = probably OK. |
06-01-2001, 09:35 AM | #18 |
Member#: 5281
Hi Skidplatez,
Thanks for the advice. No, there was no grinding involve~ I totally agree with you about it's like almost like to stall but the ECU says "oh no you don't" and keeps it running. But the weird thing is that this incident happens even on hot weather as well. It happen a few times during outside temp of 91 degrees. Well, like you said I guess as long as there was no grinding.. then probably would be fine indeed. -AliasAngel |
squeaking in reverse and cold start up | x12oyx316x | Transmission (AT/MT) & Driveline | 2 | 06-23-2004 06:24 PM |
"Knocking" on cold start-up | Blue_Rexer | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 02-01-2004 11:56 AM |
cold start up, long and strange noise | MAXXPSI | Tri-State Area Forum | 12 | 01-24-2003 05:08 PM |
Cold start up question.. | KAuss | Newbies & FAQs | 13 | 04-03-2002 01:21 PM |
