Welcome to the North American Subaru Impreza Owners Club Saturday January 21, 2017
Old 10-14-2005, 11:00 AM   #1
i102spd
Member#: 92130
2002 2.5rs
Question Remote Start Tach Wiring Question (i'm all searched out)
ok guys, over the last 3 days i've gone thru just about every post imaginable including scoobymods and ravens-blade on this topic and have yet to find the info i need ... seems all the info applies to every car out there but mine
so here's my dilemma... im working on a 2002 2.5RS... the remote start unit is hooked up and using the voltage sense feature... however it's not a good start and sometimes it starts, sometimes not... i'd like to hook up the tach wire but cant find the right wire... tried the wire of the ECU and the wire going to the gauges... when testing with a meter neither one changed voltage with engine speed ... however i did test the blue wire coming off the ignition module sitting in the middle of the engine bay... this wire gave a readable difference w/ engine speed ... i was surprised though b/c at idle it measured about 1.4V, and when i revved the engine it would measure up to 2.5V(IIRC)... obviously this wire has something to do with engine speed, i just thought a tach wire would read higher... can anyone confirm this for me
thanks in advance
i102spd is offline   Reply With Quote
Old 10-14-2005, 03:25 PM   #2
HolyMahwah
Member#: 53936
2008 Leg GT
2004 WRX -> Billy-fied
1. Are you testing the tach wire using AC voltmeter or DC? It should be set at AC.
2. If you can't find the ECU tach wire (it's green) you can also look at the fuel injectors. Each one should have a two-wire harness and one of the wires will be the same color for all 4. Tap into the other wire to get a signal (ie, non-common).
Tach wire should read 1-5V...
-Dave
HolyMahwah is offline   Reply With Quote
Old 10-14-2005, 04:19 PM   #3
i102spd
Member#: 92130
2002 2.5rs
-Dave
re: 1. cant remember but i was getting readings between 1.5 and 3V, varying with engine speed
re: 2. i did find what is supposed to be the green wire off the ECU, as well as the green wire going to the gauges, but neither registered a change on the voltmeter when engine speed was varied... i havent tried the injectors though, thought that was just on the turbo imprezas but i'll give em a looksy, or maybe i was thinking the ignition coils since the turbo models have individual coils for each cylinder and the non-turbo has one mounted on top of the intake
Old 10-14-2005, 09:15 PM   #4
quynce
Member#: 15409
AC voltage is key. If your meter is set to DC your readings don't mean squat. FWIW, on my '02 WRX, the green wire didn't test properly, but many people have used it successfully. The wire I used was in the main harness in the engine bay.
quynce is offline   Reply With Quote
Old 10-14-2005, 11:47 PM   #5
DaveDangerous
Member#: 44262
06 EVO MR
GG
I have a wiring diagram somewhere for remote starters (where the tach wire is)...i'll look for it and post later.
DaveDangerous is offline   Reply With Quote
Old 10-14-2005, 11:51 PM   #6
DaveDangerous
Member#: 44262
06 EVO MR
GG
ok, atleast on a 04 wrx, the tach is a green wire in the ECM below the glove box. And its AC.
Hope this info helps...
Dave
And what he posted V V V V
Old 10-14-2005, 11:51 PM   #7
audio1der
Member#: 77039
08 Sierra Crew
Drk Brahma
[PRINT THIS PAGE]
12volts black/white to white + ignition harness Starter black/yellow to white/black + ignition harness Second Starter N/A Ignition black to green + ignition harness Second Ignition N/A Third Ignition N/A Accessory black/blue to yellow + ignition harness Second Accessory N/A Keysense white/red + ignition harness Power Lock red/white - keyless entry module Notes: The keyless entry module is to the left of the steering column.Power Unlock yellow/red - keyless entry module Notes: The keyless entry module is to the left of the steering column.Lock Motor lt. green/black to orange 5wi driver kick, door harness Unlock Motor red/white to red 5wi driver kick, door harness Parking Lights+ orange + headlight switch Parking Lights- black/white - headlight switch Notes: The negative parking light wire only functions with the ignition on.Hazards same as turn signals Turn Signal(L) black/green + steering column Turn Signal(R) lt. green/black + steering column Reverse Light brown/yellow + driver kick, harness to rear Door Trigger yellow - keyless entry module Notes: The keyless entry module is to the left of the steering column.Dome Supervision use door trigger Trunk/Hatch Pin yellow/red - keyless entry module Notes: The keyless entry module is to the left of the steering column.Hood Pin N/A Trunk/Hatch Release N/A Power Sliding Door N/A Factory Alarm Arm factory remote only Factory Alarm Disarm factory remote only Disarm No Unlock factory remote only Tachometer green ac instrument cluster or ECM Notes: The ECM (Engine Control Module) is behind the passenger side dash.Wait to start N/A Brake Wire white/black + brake pedal switch Parking Brake pink - parking brake switch Horn Trigger red/green - steering column Memory Seat 1 N/A Memory Seat 2 N/A Memory Seat 3 N/A Interface Module:Category:
Immobilizer Bypass Required:
NoType:
N/APart #: N/ANotes:
Also any injector will work. Use the wire that is not common with the rest.
And no need to meter on an injector
audio1der is offline   Reply With Quote
Old 10-15-2005, 02:25 PM   #8
i102spd
Member#: 92130
2002 2.5rs
beautiful... thanks guys... gonna try it out now and make sure i wasnt a dumba$$ leaving the voltmeter on DC
Old 10-18-2005, 10:52 AM   #9
i102spd
Member#: 92130
2002 2.5rs
just giving an update in case anyone else is looking for this info........
set my meter to AC and stuck a needle in the blue wire coming off the coil (when standing in front of the car it's the wire farthest away) on top of the engine (remember - RS so one central coil, not individual ones at the cylinder)... finally got the readings i was looking for... measured around +/- 2V idling and up to +/- 4.5V when i revved it... thanks for the input guys
remote start, didn't see what i was searching for Meat Supply Car Audio, Video & Security 7 01-28-2007 12:18 PM
Remote Start Tach help? newgensti Car Audio, Video & Security 6 01-11-2007 10:53 AM
02-05 impreza/wrx remote start/alarm wiring.. vipernj Car Audio, Video & Security 6 09-13-2005 03:49 AM
Remote start - Lock wire which goes negative BritSti Electrical & Lighting 5 02-10-2004 06:11 PM
('93-'01) Tach wiring question Greg Sharpe Impreza Forum 8 05-03-2001 08:01 AM
