Welcome to the North American Subaru Impreza Owners Club Thursday June 4, 2020
Old 10-20-2005, 12:42 PM   #1
ein86
Member#: 67817
FRS 2019 Bronson
Smith&Nephew Genesis II
OMGHi2U Alarm question: 2nd stage unlock wire?
Anyone know if there is a seperate wire to unlock the other doors?
Basically, Im working on my aftermarket alarm (DEI 871xp). I want the doors to unlock like the factory: drivers door first, the the rest of the doors the next time you push the remote. I have 3 sources for wiring diagrams of my car ('02 wrx wagon) and all of them just have a single lock/unlock listed (as in all doors at once).
Thanks
ein86 is offline   Reply With Quote
Old 10-20-2005, 01:39 PM   #2
vipernj
Member#: 86854
2004 fx35 02 Z06
Beryllium, Millenium Yell
no, there is only 2 wires... lock(green), unlock(blue)... double pulse unlock should work but I dont remember ever trying it out.. Just go into the features with either a bitwriter or with the push button and switch to double pulse unlock.. aggressive door locking wouldnt work in this case..
vipernj is offline   Reply With Quote
Old 10-20-2005, 02:44 PM   #3
ein86
Member#: 67817
FRS 2019 Bronson
no, not on the DEI, I know how to set that up for double pulse. Im looking for the wire in the car itself that unlocks the other doors seperately, if there is one.
Thanks
Old 10-20-2005, 03:53 PM   #4
armand1
Member#: 10309
'02 OBS 2-tone!
You're in luck. There is only a single *lock* circuit, but there are 2 *unlock* circuits, one for the driver's door and a second for the other 3 doors plus the hatch:
HTH
Old 10-20-2005, 03:55 PM   #5
armand1
Member#: 10309
'02 OBS 2-tone!
If you are leaving the OEM keyless entry module in place, it may be easier to tap into the lock/unlocking function there (it connects to the integrated module); let me know if you need the diagram for that.
Old 10-20-2005, 05:01 PM   #6
ein86
Member#: 67817
FRS 2019 Bronson
Yeah, I think I am leaving the OEM part in, so if its different I may need it.
Thanks for the diagram
Old 10-20-2005, 06:49 PM   #7
joyride2k
Member#: 50638
1999 Impreza L
You can 5 wire the unlock motor wire from the driver door with the first unlock pulse, then pulse the 3 wire negative unlock wire in the car with the second unlock pulse from the alarm.
joyride2k is offline   Reply With Quote
stock alarm passenger door doesnt unlock...? SnowSurfer Car Audio, Video & Security 5 05-26-2006 01:15 PM
Clifford alarm occasionally does NOT unlock the doors ImportVenom Car Audio, Video & Security 8 01-20-2005 11:19 PM
Blitz dc dtt ii, 2nd ignition / accessory wire? Bobalouy Engine Management & Tuning 0 03-22-2004 02:28 PM
Local Question: TurboXS Stage 4 or Vishnu Stage 2? WRXcellent Tri-State Area Forum 10 02-03-2003 01:23 AM
newbie question: turboxs stage 1 and mbc Iceberg Slim Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-13-2002 08:13 PM
