Welcome to the North American Subaru Impreza Owners Club Friday June 20, 2025
Old 10-24-2005, 04:26 PM   #1
WJM
Guest
Member#:
Default AVCS Signal
So what kind of signal does the ECU send to the AVCS solenoid?
waveform...on-off....what? Is it just like an injector signal...or...?
Old 10-24-2005, 04:57 PM   #2
mpaone
Member#: 3
2000 Forester L
Lightbulb
Hmmm... thought I read somewhere the the AVCS is a similar signal to the TGV's. Not sure if that helps.
-Mike.
mpaone is offline   Reply With Quote
Old 10-27-2005, 01:38 PM   #3
WJM
Guest
Member#:
-Mike.
hmmmm....
Old 10-27-2005, 02:09 PM   #4
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
With the Hydra, cam advance is controlled with a PWM signal similar to the boost control signal. Not sure if the OEM uses the same strategy.
fragment is offline   Reply With Quote
Old 10-27-2005, 02:37 PM   #5
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
I can't recall if (this is from my notes) AZscoobie or Sponaugle posted this, but here 'tis:
"The STI ECU drives the solinoid at about 20hz, with a variable duty cycle that hovers around 55%. This duty cycle is used in conjunction with the feedback from the indivdual AVCS cam sensors to adjust the position of the cam gear relative to the cam. There really isn't a 'full power' position. Looking at my datalogs from the AVCS, the intake cam advance varies quite a bit over the 3-5.5k range. There does not appear to be any adjustment to engine timing, as far as I can tell. Furthermore, even when the intake cam is at full advance, the duty cycle to the solionod is still around 60%, not even close to 100%. I would not speculate about the reliability of the AVCS parts without further analysis of their design, but there is one thing I know: They are hard to get parts for, since they are not available in the US yet. And, we are not sure yet if the AVCS soliniods are the same on the new 2.5 STI.
Control of AVCS is very simliar to how you would control boost. A feedback
mechanism is used to monitor the position of the CAM, while the duty cycle to the solinoid is adjusted. Remember this is a analog system, not digital. It can advance the intake cam up to 35 degrees with 'infinite' adjustabililty.
The primary goal here is to open the intake cam earlier. It does not alter lift or
duration, just offsets the start of the intake valves opening."
HTH
S.
n2xlr8n is offline   Reply With Quote
Old 10-27-2005, 03:30 PM   #6
WJM
Guest
Member#:
so the signal is the SAME as an EBCS? So i can set it up for 'boost control' but with different parameters?
A hydra is the last resort on a project car we are building...and the AEM is out as it will be very difficult to make certin attributes of this engine and car to work all together and fuction as desired....
however, the MegaSquirt can do all of this, as long as we can get it to talk to the AVCS valves in the correct manner.
Old 10-27-2005, 04:44 PM   #7
Drac9
Member#: 9861
1999 2.35 RS-T w/NOS
Hybrid Rally Blue Pearl
Autronic will work too.
Drac9 is offline   Reply With Quote
Old 10-29-2005, 05:59 AM   #8
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
US STI's can go to around 30 degrees. JDM cars can go to about 40 or so. The issue with most systems is that since this is a hydralic system and the fuel (oil) changes viscosity with temp and we have two seperate cams we need a closed loop system. Most are not. Its real hard to beat the factory ECU when controlling AVCS. There is a test and calibration procedure that the ECU carries out to set the cams at zero as well. Blindly pulsing the AVCS Solenoids is a crap shoot.
Clark
AZScoobie is offline   Reply With Quote
Old 10-29-2005, 10:06 AM   #9
WJM
Guest
Member#:
well....this just got alot more complicated.
Old 11-01-2005, 05:36 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
As I have told Mick already, it is a closed loop feedback system, and the Autronic does this for variable cam timing.
Ben
Old 11-01-2005, 08:18 PM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
I only know of two people to have tuned the AVCS system, Clark (above) and Phil (Element Tuning). The map is pretty small like 16-32 cells.
Old 11-01-2005, 10:38 PM   #12
patr
Member#: 97
Having been tuning these for years on the rally cars, i can also tell you regardless of what you may believe, that there is oil pressure lag, and you can see up to 15 sec. delay (regardless of the solenoid duty) under certain circumstances. So if you are asking about the signal to 'jimmy up' some sort of control device, you should be aware that just having the _desire_ to advance the cam is not enough, you need the right conditions (i.e. rapidly cycling them on and off, or having a zero to full setpoint in a map, for example, doesn't work like you think it might). This is ECU agnostic, there are physical ways to fix this but they also have some drawbacks. And as mentioned you need a position sensor otherwise you will be all over the place. The Autronic has always worked well for the v7 and up engines.
-Pat
www.rocketrally.com
patr is offline   Reply With Quote
AVCS Help deftonez99 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-03-2010 02:38 PM
Directions how to install AVCS heads in a non AVCS car and not use AVCS sgiord86 Built Motor Discussion 1 11-19-2009 04:31 PM
Possible to get STi ECU to pick up non-avcs cam signal? LeeC Engine Management & Tuning 1 07-07-2008 10:10 AM
avcs vs. non-avcs Solomon Subaru Conversions 2 11-17-2003 03:11 PM
Anyone know what signal the AVCS needs to become active?? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-16-2003 10:58 PM
