Welcome to the North American Subaru Impreza Owners Club Monday March 30, 2020
Old 11-14-2005, 10:54 PM   #1
surferdude166
Member#: 54970
2014 WRX Hatch
Question Quick UP Question
I bought a helix up pipe a couple of months ago but haven't put it in yet. I was wondering though what do you do with the wires from the egt sensor? I know that its main purpose is to check egt's for the sake of the pre-cat, but with an aftermarket catless you don't need one. So, when you remove the sensor, do you just cut the wires off as high as you can or can you disconnect them somewhere?
surferdude166 is offline   Reply With Quote
Old 11-14-2005, 10:58 PM   #2
phillepe
Member#: 88856
2007 Sti
on 36's.....
you can get a resistor from radio shack for like $3 or something.... just search for cel up pipe delete
phillepe is offline   Reply With Quote
Old 11-15-2005, 05:06 PM   #3
surferdude166
Member#: 54970
2014 WRX Hatch
Thanks, but I already know about the cel fix, I just don't know what to do with the wires from the egt sensor. Can you unplug them somewhere?
Old 11-15-2005, 05:10 PM   #4
tubular031
Member#: 88767
2003 Cobb Stage2 WRX
Sexy Blue
yes they unplug up near the shock tower on the pass side. there are 3 connectors under a little plastic cover. Its the bottom connector I believe. When you take out the stock up pipe, leave the probe in the pipe.
tubular031 is offline   Reply With Quote
Old 11-15-2005, 07:12 PM   #5
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Unplug those wires, put in the resistor and remove the probe. You can block up the hole in the UP w/a bolt. I don't recall the bolt size.
Many have reported that, over time, the probe just wears down due to the hostile environment it lives in (hot exhaust gas) and can then break off. What piece breaks off has to go somewhere, if it does break off, and the only place it will probably go is up, towards the turbo.
Is this all true? Don't know. It has been reported on the board a number of times. Perhaps someone can give a personal experience.
Probably, over time, a functioning probe fails and it gets replaced before any damage could happen. But, if you disconnect it, you would never know if that time had come (probe failure) and you would would not know you need to change it out.
Just something to consider. If it was me, I'd remove it. I don't have mine in there anymore.
Since you haven't installed the UP yet, you can go find a bolt that would fit the opening properly. Good hardware store will usually have something like that. It is not a wierd or uncommon size.
Samurai Jack is offline   Reply With Quote
quick up-pipe question blackrexxer03 Newbies & FAQs 4 07-30-2008 06:44 PM
Quick Rack Quick Install Question. bushflyr Brakes, Steering & Suspension 6 08-21-2007 01:35 PM
Quick tire question, could really use a quick reply... MUGWUMP Mid West Subaru Owners Club Forum -- MWSOC 17 01-12-2007 08:00 AM
Quick oil question, need quick answer. garface Service & Maintenance 8 12-06-2001 02:54 PM
Quick tire question. Please answer quick!! KURB21 Brakes, Steering & Suspension 2 07-02-2001 04:40 PM
