#1 |
Member#: 73684
NWIC
Vehicle:2012 4Runner |
![]() I installed my new springs and struts on Saturday. The springs were the H&R's that I got cheap from subaruparts.com. I also installed KYB GR-2s all around and new Group-N front strut mounts. The install took me about 6 hours since it was my first time and I didn't have access to air tools but overall it was pretty straightforward. Thanks to everyone that gave tips and instructions and to Dobes for the headsup on the springs. Anyway, here are the pics:
Before: ![]() Rear stock vs. H&R: (These springs are designed for a wagon so the drop in the rear isn't as much as the front) ![]() Front stock vs. H&R: ![]() New front assembly: ![]() Final Results: ![]() ![]() ![]() Review: I love this setup. The drop is not too drastic and I like that. I can still go over speedbumps with no problems. Cornering is now much flatter and there is little to no nose lift or dive in corners and between shifts. The ride is a little harsher but the KYBs do a great job absorbing the bumps. I'm still expecting the rears to settle a little more. So just for the record, despite what H&R says, these springs WILL work on a sedan; you just need the Impreza spring perches for the front. I also trimmed the rubber perch by about 1 inch to make it work. Overall drop was 1.25" in the front and 1" in the back Questions? Comments?
#2 |
Member#: 53410
SWIC
Vehicle:BE-> GD->GR->SG->BL WAawd.org |
![]() Be careful while the springs settle...odds are things will drop a little more before settling, so watch out on speed bumps
![]() Looks great though! Welcome to the lowered BE squad! fibuz |
#3 |
Member#: 34959
NESIC
Vehicle:1988 XT6, E21, E30 |
![]() So wait, the H&Rs for the wagon will work on the sedan? I've always been told no. It's fine with me if the rear is higher; I like a little rake.
Looks great! |
#4 |
Member#: 86291
NESIC
Vehicle:'97 LegaSTi-2.5XTR '96 BrightonCoupeWRX-SR30 |
![]() looks great...must handle real well now huh!
![]() i want to do that same setup on my wagon, the gr2's cannot be beat for that price! |
#5 | |
Member#: 73684
NWIC
![]() Quote:
#6 |
Member#: 52324
NESIC
Vehicle:2011 WRX LTD (FS) 1990 T30 miata |
![]() looks good Mitch. Wish I had a smiliar setup. please be sure to let us know how it is in a few days after everything settles.
So did you use Grp N's for the fronts only? what did you do in rear? Last edited by iamrazor; 11-20-2005 at 10:35 PM. |
#7 | |
Member#: 73684
NWIC
![]() Quote:
Yeah I used the Group-N's on the fronts but the were not necessary. They are the same dimensions as the stock mounts, only stiffer. For the rears I used the stock mounts and they work fine. So literally the only thing necessary to make the H&Rs work is the front perches. |
#8 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
![]() Mitch - chuck up the part#s for the items you bought... that will avoid any confusion over what part was used...
#9 | |
Member#: 73684
NWIC
![]() Quote:
Springs - H&R PN 29443 KYB's - Front PN 334273 & 334274 (L&R) Rear PN 341275 I don't remember the part number for the strut mounts but they can be found just about everywhere. |
#10 |
Member#: 56015
RMIC
Vehicle:02 WRX Wagon 05 XT Forester |
![]() Looks good Mitch! So you did end up having to cut the stops to make it work? Either way I am glad you FINALLY got it all in
![]() How where the lower strut bolts? Let me guess like 500 ft/lbs ![]() |
#11 |
Member#: 66222
NESIC
Vehicle:2000 Legacy '68 Spitfire |
![]() Looks good! (sorry, that's all I got!)
#12 | |
Member#: 73684
NWIC
![]() Quote:
#13 |
Member#: 73684
NWIC
![]() Just an update: These springs have settled a little more and the back has evened out. I'll get pics up after work if this damn rain ever stops.
#14 |
Member#: 9853
International
Vehicle:to keep your mouth shut. |
![]() Looks good, Mitch! The drop isn't quite as drastic as my iONs, but I like it!
For comparison: ![]() ![]() Jonathan |
#15 |
Member#: 73684
NWIC
![]() Jonathan - Thanks. I was actually using your iON thread for comparison when I was done to compare the drop. It's actually pretty close now that they have settled more. I actually freaked out when I put the two rear springs (stock/H&R) next to each other and saw that there was only about a half inch in difference. I kind of expected this since they are suposed to be wagon springs but the are settling in nicely.
#16 |
Member#: 76382
BAIC
Vehicle:2000 BH BP Wannabe |
![]() I had my springs and struts installed yesterday. I am loving it! I would throw in a dancing banana if I knew how.
Thanks to Mitch for the part # on the spring perches. I had new stock top mounts installed as well. I would recommend the correct rubber mounts for the front perches, mine were cut to fit. |
#17 |
Member#: 73684
NWIC
![]() Sweet! Get some pics up soon. Glad I could help w/the PNs.
#18 |
Member#: 76382
BAIC
![]() I'm going on an epic drive tomorrow in rain soaked Sonoma and Mendicino couties. Hopefully I can get some good pics.
It is really strange getting into the car now that it is lower. The ride is great, firmer but not too. Real flat in turns and no squat and dive. I also have every Kartboy bushing installed which helps it feel solid. |
#19 |
Member#: 113535
NESIC
Vehicle:2012 OB3.6R/RX-7/E92 |
![]() where did you get the Group-N strut mounts? and do you have the PN by a chance? thanks a lot for the info. ive been searching everywhere for a suspension set up for my car.
#20 |
Member#: 94945
Vehicle:2015 Dodge Charger AWD |
#21 |
Member#: 9072
Vehicle:95 Legacy L puke |
![]() ....starting to wish i would have gone with the h&r's now as that looks to be the amount of lowering i wanted.....as opposed to the eibach pro kit's since the eibach's weren't wagon specific springs....
#22 |
Member#: 52238
NESIC
Vehicle:2001 Legacy GT LTD Hummer Black |
![]() I'm gonna give this a little update bump...
So how is this setup holding up? Do you still like it? Recommend it? How much do you think it settled? Are your rubbing at all now w/ the 18's? -Rob |
#23 |
Member#: 73684
NWIC
![]() They're holding up great. I still love the ride and handling, but it may be too rough for some. Potholes definately shake you up a bit. It definatey settled at least another half-inch all around since the first pics in this thread was taken:
![]() No rubbing issues at all though. |
#24 |
Member#: 16874
NWIC
Vehicle:2008 2008 Audi RS 4 2014 Audi S Q5 |
![]() any straight on side shots of it fully settled?
Jared |
#25 |
Member#: 62824
Vehicle:'06 STI Black |
![]() Man, I swear ive seen that car before...??
Almost done with another mod (and install pics) 56K BEWARE | 2003Baja | Baja Forum | 2 | 09-23-2004 08:55 PM |
saw a gt2 today (couple of pics) 56k why not? | stuttgart | Off-Topic | 42 | 05-07-2004 07:16 PM |
New suspension woes...H&R+KYB | tora | Legacy Forum | 10 | 03-21-2002 08:30 PM |
H&R springs installed (before & after pics) | megatron | Brakes, Steering & Suspension | 46 | 12-20-2001 09:52 AM |
H&Rs+KYB AGXs on MY01 RS | moss | Brakes, Steering & Suspension | 15 | 11-22-2001 08:50 PM |
