Welcome to the North American Subaru Impreza Owners Club Thursday September 21, 2017
Old 11-27-2005, 03:03 PM   #1
anjion24
Member#: 64882
Default any experinces with the Perfect Power 7??
I'm gonna be putting a perfect power 7 in my car and I was wondering if anyone has some feed back on them.
anjion24 is offline   Reply With Quote
Old 11-27-2005, 03:40 PM   #2
anjion24
Member#: 64882
ha ha ha ha bump
Old 11-27-2005, 06:21 PM   #3
scubyslacker
Member#: 44124
2008 STI
I don't have any personal experiences with perfect power, but a friend of mine who does all my car work for me and a whole bunch of other guys out in Denver, CO is running perfect power from rallitek i believe on his Turbo'd Impreza L and he is having great results. He told me its great for beginner tuners and easy to understand. Also, 2 or 3 other pre-2002 tubo'd 2.5RS are running the perfect power out in denver and also have been saying great things about it. I believe an STi owner was thinking about running one. Other than that, I can't really help, good luck...
~Matt
scubyslacker is offline   Reply With Quote
Old 11-28-2005, 11:31 AM   #4
anjion24
Member#: 64882
thanks for the feedback! I'm going to go with it seeing as the guys at rallitek are great! And I know that they will take care of me!
Old 11-28-2005, 01:56 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
don't do it .. no reason to use a hack on an ecu that is reflashable
turbo L is one thing EM on an STI is radicaly differnt
get a reflash or utec
Old 11-28-2005, 03:24 PM   #6
anjion24
Member#: 64882
what are your reasons for saying that?
Old 11-28-2005, 05:30 PM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
A: its a piggy back it "fools" the ecu in to modifiing paramaiters vs just changing them
b: the sti ecu is very very complex
c: many many more reasons (cutting)
look around the the forum the only people that are using the PP are people that have been hood winked into it, for lack of expirence or options
Old 11-28-2005, 05:38 PM   #8
anjion24
Member#: 64882
ok then i pose this question what about the stand alone pp?
Old 11-29-2005, 01:48 PM   #9
anjion24
Member#: 64882
bump for answers!!!!!!
Old 11-30-2005, 11:52 AM   #10
anjion24
Member#: 64882
bump again. last one I promise!
Old 11-30-2005, 12:54 PM   #11
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
Using an offset device like the Perfect Power on your STI is not a good idea. Offset fueling is a very difficult proposition with an ECU that has significant dynamic learning in both timing and fueling.
We have removed many many piggy back devices (Unichips, Perfect powers, Exde, eManage) and replace them with reflashes with significant improvements. If you are serious about getting reliable power with your car, you should consider either a reflash or a UTEC. Given that you are local, you should stop by and talk to one of us. (see our address on www.pdxtuning.com, we are right off 217 and I5.)
Jeff Sponaugle
PDXTuning
[email protected]
PDXTuning is offline   Reply With Quote
Old 11-30-2005, 02:23 PM   #12
Freon
Member#: 88322
2009 BMW 135i
You can really only get away with it in open loop. So you have to ensure the device is only modifying the fuel signal (in this case, MAF voltage) when in open loop.
Otherwise, the ECU adjusts its LTFT and the piggyback ends up doing nothing.
I had an SMT6 on my last car (naturally aspirated) and it worked really good for cutting fuel at WOT, since the stock ECU wanted to run 10-11:1 which was ridiculous for NA. But I couldn't touch the low load (TPS) sites.
But using TPS for load on a turbo engine is probably not appropriate. You probably want to use MAP. And then it becomes hard to only map when in open loop.
Freon is offline   Reply With Quote
Perfect power 7 XRWITS Engine/Power/Exhaust 7 11-06-2007 08:37 AM
Perfect Power 7 PnP XRWITS Engine/Power/Exhaust 4 09-02-2007 04:21 PM
Perfect power 7 07StiChick Engine/Power/Exhaust 0 05-04-2007 12:39 AM
Anyone have any experience with the Autoearth Version 7 Spoiler? Schleppy Interior & Exterior Modification 12 04-16-2003 09:25 PM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 10:58 PM
