12-02-2005, 07:31 PM | #1 |
Member#: 53916
NESIC
Vehicle:16 19 ND RF / 818s Soul Red/ Gel coat red |
SAFC Newbie...reset or removal?
I didn't get a manual for the SAFC when I bought my RS-T from a guy in virginia last year, and I couldn't dig up what I was after searching. Is there a way to reset the ECU so that it doesn't affect anything, but only monitors what's happening? If so how do i do it?
To fill you in: I bought a used 99RS-T that was tuned with an S-AFC. It worked well for a while, until the turbo blew. Decided that I should put the car back to stock, and save for an engine swap. Almost done. Car runs, but is having problem with fuel delivery...even with SAFC dialed all the way back, it's still running too rich. With the turbo, the car was running huge RC 550 injectors. That's way too big for NA, so I've decided to pull the injectors and go back to stock. The injectors have been swapped, and I'm soldering the injector plugs back in now. (taking a break to write this post) Once that's done, the car is 98% finished. The only thing left to do is reset or remove the SAFC. If it's possible to reset the thing so it doesn't actually create a fuel correction, but simply reads what's going on in with the engine, essentially a "blue flashy light machine," I'd be in favor of doing that for the time being. Less invasive and no hole in my dash. If that's not possible, I suppose I'll just unplug it and remove it from the car. Or is that the preferred option anyway?
12-02-2005, 08:31 PM | #2 | |
Member#: 9794
TXIC
Vehicle:02 2.5LWRX-Retired 335i w/twins |
You can't just reset it using the restore default function as it'll pick the wrong number of cylinders (6) and throttle/maf type and the car won't start. Just DL the pdf and you'll be set. |
ECU reset after removing snorky? | itjustWoRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-15-2005 05:26 PM |
Reset or not? | STISTL | Newbies & FAQs | 5 | 11-11-2004 01:51 AM |
Reset or not to Reset? | grozgon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 04-11-2004 09:42 PM |
to reset or not to reset ? | scooby01 | Normally Aspirated Powertrain | 2 | 09-02-2001 09:44 PM |
