Welcome to the North American Subaru Impreza Owners Club Tuesday January 23, 2018
Old 12-16-2005, 07:51 PM   #1
LeRoy
Member#: 70898
Default open exhaust
Is there much advantage to running an open exhaust on a STi? I understand you can do anything you want from the 1st cat back and remain in A Stock. Would removing everything from the cat back and replacing with a short turn down or turn out give any significant hp gains? I've always hear any exhaust after a turbo robs power.
LeRoy is offline   Reply With Quote
Old 12-16-2005, 08:44 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
That two cats are really what rob the power, and you can't touch them in AS. Sure you can just put a downturn on the car and it will save weight, but I wouldn't be looking for significant horsepower gains out of it.
Old 12-16-2005, 08:51 PM   #3
cbarth3
Member#: 67249
2004 WRX
your mostly going to loose some weight. on my wrx i took the axle back off and made a straight pipe out the back to keep the exhaust heat and crap off of the diff. probably lost about 20 lbs
cbarth3 is offline   Reply With Quote
Old 12-16-2005, 09:13 PM   #4
sciolist
Member#: 50200
2004 STi
I think you mean the last cat.
A full TBE with only one high-flow cat definitely makes a difference in spool and a modest power increase, but that's outside the AS rules.
As mentioned, I think the main thing to be gained from AS exhaust mod's on the STi is a little weight reduction.
sciolist is offline   Reply With Quote
Old 12-17-2005, 09:43 AM   #5
Fred
Member#: 3560
00 2.5RS, 06STi
06FXT, 95rallyimpreza
I think the main thing to be gained is the way it sounds.
Fred is offline   Reply With Quote
Old 12-17-2005, 03:02 PM   #6
AUTOwrXER
Member#: 5817
2005 STi
I wouldn't say mine sounds good with the turn-down; only really damn loud.
I've never dyno'd the car with the full exhaust on versus the turndown. I did it for the weight savings, which is quite a lot. The factory muffler is heavy, plus you save some more weight by turning it down just behind the driver. You do need to secure the exhaust at the last hanger though as my turndown will slip off the hanger even with the Kartboy urethane pieces.
AUTOwrXER is offline   Reply With Quote
Old 12-17-2005, 03:33 PM   #7
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
any pix of the setups?
arco is offline   Reply With Quote
Old 12-17-2005, 05:54 PM   #8
LeRoy
Member#: 70898
I could stand to lose some weight but I've done just the opposite by adding a trailer hitch. I guess if I'm going to get serious about autoX I need to think about removing that for events.
Old 12-17-2005, 06:10 PM   #9
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
I really wouldn't worry about the hitch. Mine didn't hurt me at all. It may add weight one place you'd want it. It's only about 25lbs. Most of us could probably make that up by skipping a few meals from now until race season.
mccanixx is offline   Reply With Quote
Old 12-18-2005, 10:54 AM   #10
AUTOwrXER
Member#: 5817
2005 STi
Buy some good tire bags and cram them in the back seat.
AutoX Advice Needed Please ;) Tire Presures, Open Exhaust ??? etc . . . Hotrodguru Texas Impreza Club Forum -- TXIC 26 10-02-2004 02:10 AM
will an open exhaust kill the OČ sensor? rexmobbin' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-30-2004 10:37 PM
open exhaust ? no muffler? WickedSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 01-09-2004 12:59 PM
Our cars are pretty loud with an open exhaust! trhoppe South East Region Forum 6 11-20-2002 03:28 PM
