Welcome to the North American Subaru Impreza Owners Club Thursday October 19, 2017
Old 12-19-2005, 12:05 AM   #1
Clzay
Member#: 26313
02 for life
PSM/Bronze...
Default Just got 17x8 +35 rubby, dub, dub!
I just got my rims put on 17x8 +35. With 225/45/17 tires. I wanted that widened stance/dift style look. But with my tien coilovers lowered all the way, I'm having major rubbage? Thinking about rolling all my fenders, and removing the front liners. How much more clearence will I get by doing this?ok the pics are up now...
Clzay is offline   Reply With Quote
Old 12-19-2005, 12:20 AM   #2
import111
Member#: 24447
2016 Mustang GT w/PP
Red
Probably not nearly enough. 35+ offset is not even close to the 45-53+ offset that AWD Subarus need. Some get away with a 42+, but I wouldn't try it.
import111 is offline   Reply With Quote
Old 12-19-2005, 12:51 AM   #3
Draken
Member#: 16
1968 Saab
Sonett II V4
When you mean you have your Teins lowered all the way, d you mean all way? Cause that is stupid low. No wonder you rub. FWIW, I have run 17x8 35mm offset on my '04 STi with 275/40-17 Hoosiers. When I was originally at 13" from center of hub to fender lip I rubbed a bunch. Now with better ride height I'm fine.
Set your ride height at a minimum of 13.5" from center of hub to fender lip, and see if you rub. Your car will handle better too.
Chris H.
Draken is offline   Reply With Quote
Old 12-19-2005, 03:21 AM   #4
caterpill
Member#: 27136
+35 and 8" wide? I believe the edge of your rim is sticking past your fender.. by a lot.
Which means either you need plenty of camber, which might not even work, or just leave some gap so your tire doesn't turn to shreds..
caterpill is offline   Reply With Quote
Old 12-19-2005, 10:26 AM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Old 12-19-2005, 10:36 AM   #6
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
[translation]I slammed my pimp ride, completely disregarding proper suspension geometry, then, still not satisfied that I had screwed things up enough, I decided to put on wheels that are way outside of optimum offset for the car. [/translation]
Templar is offline   Reply With Quote
Old 12-19-2005, 10:43 AM   #7
Uncle Scotty
OK buy Nates beans
....they're getting younger and dumber by the hour, no????
Old 12-20-2005, 12:13 AM   #8
Clzay
Member#: 26313
02 for life
PSM/Bronze...
seriously...
Old 12-20-2005, 12:40 AM   #9
3DF
Member#: 59373
2005 '01 H6/LegacyGT
'01 H6 (wag) '05 SWP (gt)
When stupid people post.....
3DF is offline   Reply With Quote
Old 12-20-2005, 01:41 AM   #10
Clzay
Member#: 26313
02 for life
PSM/Bronze...
thank-you
Old 12-20-2005, 07:28 AM   #11
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
i'm curious if you did any research at all.
Did you even look at some of the informative stickys about wheel size?
I know the 17x8 +35mm offset is the reccomended size for the Fn0r1-c when the car is equipped with brembos, but even there it isn't worth it.
good luck with 0 suspension stroke, and you dift style
WRX8XB is offline   Reply With Quote
Old 12-20-2005, 07:32 AM   #12
e39
Member#: 102862
What do U think about 18x8.5 with +35 offset will fit MY02 wrx?
Cheers
e39 is offline   Reply With Quote
Old 12-20-2005, 07:33 AM   #13
WRX8XB
Member#: 45323
no
buy the right offset it isn't hard.
cheers
Old 12-20-2005, 08:59 AM   #14
MBPEJ20
Member#: 24360
2004 MR-S
super wrong offset buddy.
MBPEJ20 is offline   Reply With Quote
Old 12-20-2005, 12:19 PM   #15
Uncle Scotty
OK buy Nates beans
Originally Posted by Uncle Scotty
....they keep getting younger and dumber by the hour, no????
Old 12-20-2005, 12:30 PM   #16
Clzay
Member#: 26313
02 for life
PSM/Bronze...
the tires don't even stick out of the fender. With alittle negative camber there perfectly flush, which I think looks the best. I'll put some pics up later this week.
Old 12-20-2005, 12:50 PM   #17
Templar
Member#: 483
2010 RSV4
Either raise your car up some, or get some wheels of the appropriate offset, preferrably do both. Or get another car because this car isn't going to offer what you are looking for.
Old 12-20-2005, 01:08 PM   #18
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Well, you can't have them perfectly flush AND zero gap. The only way you can do that is with zero suspension travel, which would be horrible. The way you have them now, as soon as you hit a bump or the car shifts weight, they are going to rub.
garface is offline   Reply With Quote
Old 12-20-2005, 01:26 PM   #19
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
This is just plain wrong.
That should fit alright, actually. Sort of like 255s can fit with 45 offset. I had 245s on 45 offset 8" wide wheels and it (barely) fit fine. Raise the car up like the other people said and get a performance alignment. You should have no problems after that, as long as looks are the only thing you're after.
rex n effect is offline   Reply With Quote
Old 12-20-2005, 04:50 PM   #20
qingshan
Member#: 81322
12/6 Sti/Fo
swp/CGM
With that look, you should have gotten
13" Lowrider Tires 155/80/13
This is a set of (4) All Season high quality Lowrider Tire with a SPECIAL CUT wide white walls. Size P155x80xr13. These are not your nornal 99.00 tire! These are BUFFED OUT/CUT WHITE WALL TIRES and will fit any 13" rim.
qingshan is offline   Reply With Quote
Old 12-21-2005, 01:48 AM   #21
Clzay
Member#: 26313
02 for life
PSM/Bronze...
yeah... i'll get the pics up tomorrow, then tell me what you think? I like the aggressive stance, maybe when you see the pics you'll like too. But its cool, everyone intitled to there opinion. Ho ho ho!~
Old 12-21-2005, 02:46 AM   #22
ripvw
Member#: 27790
...Thinking about rolling all my fenders...
http://www.rollyourfender.com/
ripvw is offline   Reply With Quote
Old 12-21-2005, 04:54 AM   #23
dan avoN7
Top Scoob 002
Member#: 32771
03 Black WRX
04 White M3
You really need to go with another wheel. +35 is typically what Evo's run. For a subaru a +35 will stick out very far and cause some suspension issues (wheel bearings in particular) I would look into a rim with a +44-+53 offset, +48 works very well for subarus.
dan avoN7 is offline   Reply With Quote
Old 12-21-2005, 10:30 AM   #24
Templar
Member#: 483
2010 RSV4
So what you are saying is that you like the way it looks and don't care that you screwed up your suspension and steering geometries. If that is the case, then do whatever you want. You asked for opinions and multiple people have told you that what you have done is wrong and bad for the car, but all you seem to care about is how it looks. If that is all you care about, the do what you want and stop asking for advice.
Old 12-21-2005, 12:56 PM   #25
Clzay
Member#: 26313
02 for life
PSM/Bronze...
yeah thanks, but all was asking is how much clearence I could get by rolling my fenders? Thanks for all the other advice... i'll keep that in mind? Merry Christmas everyone!
LONG SHOT WTT: 17x8 +35 matte black rpf1s for 17x8 nt03s SUBYDOODIE SCIC Private Classifieds 15 02-09-2009 04:17 PM
just got some enkei nt03+m's in 17X8 :-) (not 56k friendly) spitfirezip100 Tire & Wheel 11 10-19-2005 04:34 PM
Just got my 17x8 Torques with Falken 512's-PSI?? Hollidark Tire & Wheel 0 10-22-2004 05:02 PM
17x8 +35, Will they clear on a 02 WRX? WeSTI Tire & Wheel 12 08-31-2004 07:00 PM
17x8 +35, what will have to be done to fenders? WeSTI Tire & Wheel 3 05-14-2004 08:16 PM
