Welcome to the North American Subaru Impreza Owners Club Thursday April 18, 2019
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 12-28-2005, 09:55 AM   #1
jvs04wrx
Member Sales Rating: (2)
Member#: 87813
Default highly modded 04 wrx fs
For sale!
2004 Subaru impreza wrx!
2004 subaru wrx with 29,XXX miles in white
Fully loaded with sport package
Estimated 400 hp at the crank
Exterior mods
Charge speed body kit 4 pieces
Painted center grill and cleared out headlight assemblies
De badge and wingless trunk lid
Subaru RS hood “ no hood scoop”
Hand made exhaust guard
Handling
Progress lowering springs 1.8”f + 1.6”r progressive rates
Cross drilled/slotted rotors
Hi temp painted calipers “original pads”
White line steering rack bushings
AR front strut tower brace
18”+8.0 buddy club p11 rims 265/45/18s tires zr rated 50% trade life
Engine
PE1820 DBB turbo older version with p-20 housing “more flow then new version” upgraded adjustable waste gate, 720 cfm flow rate
UTEC engine management system tuned by jester tuning one of the best in the business. Hi/low boost maps and launch control systems and boost map switch fuel cut set at 25 psi
Turbo xs FMIC with turbo xs RFL B.O.V all wrapped in DEI wrap
Modded stock injectors 820 cc flow rates
Cooling mist methanol injection system with pressure switch and upgraded holding tank 150 psi pump,
“TGV deletes” with ported manifold
Turbo xs dual stage boost controller
Samco turbo inlet hose
Un-specified short ram air intake
Walbro 255 fuel pump
Unorthodox aluminum racing pulley “under driven”
4” bell mouth down pipe with a 3” turbo back system from bltzz usa
HKS upipe
Interior
Carbon fiber center gauge pod with boost//egt//afr autometer gauges
LED for cooling mist activation
Hi/low boost switch
STI shift know and shift pedal
Sti short shifter linkages sti short shifter linkages and cusco shifter bushing
The low down
This car has been garaged kept and is one of the fastest wrx in Florida the current set up will run in the low 12s the car has never been wrecked or abused in any way the oil has been changed religiously every 2,000-3,000 miles
The clutch and tranny is stock and show’s no wear
This car ran 12.80 @ 107 on low boost setting 14 psi before the injectors and FMIC was installed
Low boost is set for 17 psi hi is for 22 psi off meth or race gas 0 knock on any boost levels AFR is tuned 12.5 AFR conservative settings @ 22 psi
Original sticker was 26,000 there has been another 7,000 invested not including the dyno and tuning time
Asking 23,500
Kbb value =20,185$
Nada value=21,300$
James Sterman
407 758 8110 –cell
Location Orlando florida
also featured in citybeats.com
http://orlandocitybeat.metromix.com/...imedia&index=1
email me directly [email protected] if intrested
jvs04wrx is offline   Reply With Quote
Old 12-28-2005, 03:50 PM   #2
wuuusaa
Member Sales Rating: (20)
Member#: 92894
2015 Wrx
bump for a very clean wrx
good luck in selling it
WRB 04 WRX FS with mods ibalongwrx Private Vehicle 'For Sale' Classifieds 4 05-02-2007 12:13 AM
feeler: HIGHLY modded 2004 wrx show car jimtweet Private Vehicle 'For Sale' Classifieds 29 09-27-2006 09:47 AM
NC: Highly Modded 02 WRX Sedan FS (Blue) crazyhorse Private Vehicle 'For Sale' Classifieds 3 07-29-2004 11:26 PM
FS: Highly modded 2002 WRX paulw Private Vehicle 'For Sale' Classifieds 0 12-12-2003 05:09 PM
Spotted: what looked to be a highly modded black WRX at NTB on Spring Hill Rd. SubyNewbie Mid Atlantic Impreza Club -- MAIC 18 09-18-2002 10:08 PM
