01-06-2006, 02:17 PM | #1 |
Member#: 25704
Vehicle:2000 Impreza 2.5 RS Red |
RS engine not starting - water?
I came back from vacation (2 weeks) and my engine (2000 RS, 2.5L) no longer starts. I hooked up a battery charger but that still didn't fix the issue. The engine makes a clicking sounds for about 1-2 seconds and then it makes faster clicking sounds. (click----click----click----click-click-click-click, etc.). Each 'click' causes a slight movement (1/8 rotation of pulleys) of the engine's belts. While I was gone we had very heavy rains. Any thoughts on where to start looking for problems? My engine has ~55k miles on it. My best guess is that there is some form of electrical problem (engine is not cranking)... any thoughts? Thanks!!!
01-06-2006, 02:33 PM | #2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
Sounds like a bad starter
01-06-2006, 02:46 PM | #3 | |
Member#: 51642
TXIC
Vehicle:2008 WRX WRB |
Greg_r: how long did you charge the battery? Did you charge it up to 12.0 to 12.5 volts? Have you tried a jump start? |
01-06-2006, 02:59 PM | #4 |
Member#: 90596
Vehicle:2010 WRB STD MWSOC tuner |
Sounds like the battery.
This usually happens if you don't start your car for a long time. My friend has crap load of problems with his car so he doesn't drive it that much, but still turns it on for 10 minutes at least once a week. |
01-06-2006, 03:01 PM | #5 |
Member#: 25704
Thanks everyone! I'll swap the battery with a known good one before checking the starter, etc...
01-06-2006, 03:12 PM | #6 | |
Member#: 51642
TXIC
After I swapped out my stock battery, when I had the above issues, I noticed that the six or so fluid cells seemed quite low. My stock battery would work fine immediately after getting jumped. Though if I parked the car and ran the stereo for a few minutes or even a fan, it would kill the battery. (BTW I bought a $34 Walmart battery and its worked fine for 18 months or so. Been acting a little funny lately with the cooler weather, but it has always fired right up. I even am running with two amps and a 10" sub) |
01-06-2006, 03:30 PM | #7 |
Member#: 25038
Vehicle:2002 PSM WRX sedan |
Bad battery.
Happened to me a few weeks ago. |
01-06-2006, 03:32 PM | #8 |
Member#: 25038
If it was the starter, it wouldn't even click like that.
And, my lights, radio, and everything else worked just fine, but the car would not start. |
01-06-2006, 04:26 PM | #9 | |
NWIC
A single click would usually point towards a weak battery, but he said it clicks several times, that would point me to a bad solenoid on the starter. of course...he could also have a bad ground on the frame or something... |
01-06-2006, 04:31 PM | #10 |
Member#: 51642
TXIC
Battery, starter, alternator issues are tough to diagnose without measuring a charge or testing the equipment.
Best thing to do is the easiest. Check the battery charge and its fluid level. Then check the alternator at Autozone or Advance Auto. Then move on to the starter. Bad starters may not always click, but they do like to screech and whine when trying to start the engine. |
01-06-2006, 04:33 PM | #11 |
Member#: 90596
simplest explanation is usually the right one.
As long as he had no previous trouble and the car sat there for two weeks then that should be the battery. Fully charge the battery (a couple of hours if you have the charger) or jump start it. Then let us know. Good luck. |
01-07-2006, 11:45 AM | #12 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Try disconnectiong your battery and using a different one (either installed or off a set of jumper cables.) The reason for this is that your battery may be so bad, it is preventing power from getting to your starter. So remove your battery. |
Not water cooled, not AWD, engine not in front... going turbo soon | Ghia Nut | Off-Topic | 28 | 01-28-2009 09:21 AM |
Does o2 sensor in downpipe make engine not start. | 97sportwaggie | Service & Maintenance | 1 | 10-29-2008 08:41 AM |
WRX swap in RS will not start | Turb0loverRS | Subaru Conversions | 5 | 05-28-2007 10:04 AM |
02 RS Engine NOT WRECKED | Omega88 | Engine/Power/Exhaust | 0 | 01-12-2007 04:51 AM |
Engine not starting in 2000 Honda Civic DX 1.6L HELP! | Kansai Subaru | Off-Topic | 24 | 11-22-2006 09:49 AM |
