Welcome to the North American Subaru Impreza Owners Club Tuesday January 23, 2018
Old 01-04-2006, 10:44 PM   #1
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
Default Installing '04 USDM STI Steering Rack in non-'04 STI
Hello gents!
I'm working on installing a 15:1 ratio USDM STI rack in my 98 Legacy. I can see that the splines on the rack are different than my 98 GT. Anyone worked around this?
Here is a thread about it STEERING RACK THREAD , but I know you guys are probably the ones to have messed with this the most.
Thanks,
Matt
UTCiv is offline   Reply With Quote
Old 01-06-2006, 05:07 PM   #2
suberboy
Member#: 1531
2008 GRB
Red
I installed the 04 STi steering rack in my 1993 impreza. I had a welder cut the two different universal joints apart and make one with the STi splines on the lower portion and the impreza splines on the upper portion. Worked out very well. Although the FWD rack I had in the car prior allowed for more steering angle (tighter turns).
noah
suberboy is offline   Reply With Quote
Old 01-06-2006, 06:47 PM   #3
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
Thanks for the reply!
Although I was hoping to not have to fabricate just, disassemble/reassemble. Well, I may try it but it may go in after the swap then. I don't want to risk stock peices and a system that I know works to either cut and weld myself, or have someone else do it. Budgets suck, though if I just sell off the STI rack, I may be able to get something else thats cool! But having to weld up an exhaust and now a steering U-joint I may just do it.
Oh, did you have to cut and weld? not able to press or pull the U-joints apart? I'll have to yank mine off the Legacy and get a good handle on how it's made.
Old 01-06-2006, 08:32 PM   #4
suberboy
Member#: 1531
2008 GRB
Red
I thought about trying to press the pins out but a friend is a very good welder so that was the easier (free) option
Don't know if you will be able to mix and match the two model u-joints either. I vaguely remember looking at the two u-joints I had and thinking the dimensions of the two were different. But I'm working with a '93 impreza and your Legacys u-joint may be of the same style/design and you might be able to mix and match.
I also am not that familiar with manufacturing processes. So I don't know if a local machine shop could put them back together properly?
Old 01-07-2006, 03:31 AM   #5
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
Well, now I have it laying on the fender, it looks like the easiest way to get the rack to work is welding (no press points look good, a seam is shown, but not pressable without a bit of fab just to get it back in), so I think either I sell the STi rack or weld like you did. Ahhh decisions, decisions,. . .
WTB: '04 STi Steering Rack in Good Condition zmarko Private 'Wanted' Classifieds 2 04-12-2010 06:45 PM
USDM STi Steering rack in bg5 legacy? sti-zy wagon Subaru Conversions 0 02-14-2008 12:59 PM
Will this fit: 04+ STi steering rack in '00 GC? nytoy Brakes, Steering & Suspension 1 10-12-2006 12:59 AM
05 STi steering rack in 04 WRX jebjkey Brakes, Steering & Suspension 4 07-18-2005 12:17 AM
04 sti steering rack in 02 wrx? Benjamin Tang Brakes, Steering & Suspension 7 04-25-2004 12:44 PM
