01-09-2006, 12:54 PM | #1 |
Member#: 99294
Vehicle:05 sti Black,IBthatsracist. |
HP gains for my ej25.
after deciding to keep my legacy outback and build it up,just to be diffrent im looking to do some work to the engine,give it a bit more power,im on a small budget here,so i will proly end up looking in the for sale forums for most of my stuff.but,what would any of you recomend i put in for easy HP gains i alreaddy have a intake and im looking to get more into moding the car
if this is the wrong place,sorry im still new here
01-09-2006, 01:11 PM | #2 |
Member#: 71203
Vehicle:2005 2.5rs Crystal Gray Metallic |
you can get catback, EL headers for the power ( or UEL headers for rumble), Camshafts are prob the best NA mod i can think of, ECU stuff, and pulley. The pulley is cheap and does good for the price.
01-09-2006, 01:23 PM | #3 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Power?
Catback first Light flywheel and better clutch (Exedy/ACT) second Headers third Cams fourth After than, you need to do a bit more. Have you done HG's yet? If not, save up and consider the clutch/flywheel as well as cams when you need to do HG's. Last edited by Charlie-III; 01-12-2006 at 11:55 PM. Reason: reorder camd vs headers |
01-09-2006, 01:40 PM | #4 |
Member#: 99294
ita auto just to let you know.
and by HG what do you mean im also looking to picking up a HKS carbon-ti exaust this weekend.good choice? |
01-09-2006, 01:46 PM | #5 |
Member#: 52985
HG usually means head gasket
01-09-2006, 01:58 PM | #6 | |
Member#: 30669
The phase-I (usually DOHC [Double OverHead Camshaft]) engines were know to blow the HG's. It really did not matter how you drove, how you maintained or where you lived. I would guess an average is around 90K miles. If yours were replaced a long time ago, they were probably done with the original 3 layer HG, not the better 4 layer HG available later on. Do some searches to see the typical identifiers of when it goes. |
01-09-2006, 02:00 PM | #7 |
Member#: 99294
acctualy if im not mistaken they where replaced resently my whole engine was rebuilt and all that jazz and i got it back a few days ago. its deffinitly got more the 90k on it.
01-09-2006, 02:40 PM | #8 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Charlie,
I am surprised to see you mention cams in advance of headers. Care to share your logic? Woofy, Look at Delta Camshafts for the best price on cams. You do need to send them your core, however. So, the car will be down for a few days. And you need a qualified mechanic to adjust the shims for the valve lash. Figure $500 for that... |
01-09-2006, 04:41 PM | #9 |
Member#: 99294
hum,sounds worth the money. i think im just gunna go with a full exaust all the way back, and work on reciving a better airflow then focus on susp. set up. i don tthink i wanna go to crazy on this car just enuf to make me happy
01-09-2006, 05:10 PM | #10 |
Member#: 58806
Vehicle:1998 RIP Legacy2.5GT 2.2L legacy wagon |
Has anyone sent there DOHC cams to delta cams ?
If so how much gains have you seen and how much doe they charge ? Thanx main |
01-09-2006, 05:59 PM | #11 |
Member#: 832
RMIC
There's a couple of guys with DOHC's running Delta cams, but their screennames escape me right now. I will post if I can remember...
01-10-2006, 01:25 AM | #12 |
Member#: 61237
Vehicle:2004 Impreza 2.5 TS Silver |
Be sure to pick up a G-Tech Pro, so you can tell us what you gained with your tinkering. Maybe not as accurate as a real dyno, but it's better than just a "butt dyno."
01-12-2006, 11:54 PM | #13 | |
Member#: 30669
IIRC, I added to the list and forgot to re-proofread it. Where is the suicide graemlin? |
03-01-2006, 10:49 PM | #14 | |
Member#: 2181
SCIC
Vehicle:2003 Forester XS |
Better a gravedigger than a thread starter...
I have chopped my cat pipe after the first cat and welded in the second cat and everything behind it from a v.8 STi (JDM, 2.0 liter). I have an emanage for tuning. If I mod one thing at a time, which would you do first, header or cams? I'm trying to keep the car as quiet as possible. |
03-01-2006, 11:33 PM | #15 |
Member#: 78118
Vehicle:2002 Corvette coupe 05 Legacy |
93subi is sending his DOCH cams to delta this comming monday. should be fun.
03-02-2006, 12:06 AM | #16 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
...frankenmotor..thats an easy way to get HP........get yourself some phase I or II EJ22 heads and send the cams to delta for regrind. you'll have to run premium gas though. depending on the heads your get you'll be in the 10.8-11.5 :1 CR (compression ratio). search for high compression frankenstein for details.
~Josh~ |
03-05-2006, 09:54 PM | #17 |
Member#: 2181
SCIC
Bump for answer from Matt
03-06-2006, 10:48 AM | #18 | |
Member#: 832
RMIC
If one is looking to increase the CR on an early Ej25, the best solution is to get a phase II bottom end... Redwagon, Not a terrible idea. I ran with the cams, without the header for a month or so when I needed to get smogged. The cams definitely provide more HP gains than the headers do, and if you can do the install yourself, they will be cheaper... |
HP Gains for a fairly stock 08 WRX | RedefinedTR | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 15 | 04-15-2010 01:50 AM |
Gauging interest for my ej25 engine and tranny | thedaddyb | Mid Atlantic Impreza Club -- MAIC | 5 | 11-10-2004 11:25 AM |
cat-back for my ej25 | simprezl25 | Normally Aspirated with bolt-on Forced Induction Powertrain | 2 | 10-01-2004 03:37 AM |
Do i need new driveshafts for my EJ25 swap??? | SubaruPreza | Subaru Conversions | 4 | 09-14-2003 12:12 PM |
