01-09-2006, 11:59 PM | #1 |
FTW RIP
Member#: 1820
I think theres a Fraggle in my car
Fraggles are cool and all but I dont like them messing with my car.
I have a 1998 2.2 Impreza wagon. Sometimes (about 50% of the time) it starts fine, no check engine light on Sometimes It hesitates to start, still cranks and everything then the check engine light comes on and I smell fuel. Sometimes it takes up to 10 minutes to start and then I have to punch it, usually after I run it and turn it off to put gas in or something. It makes me a sad panda when it does this. I have been having this problem for a few weeks, I just replaced the plugs and wires 2 days ago and have checked the vacum lines. FTW
01-10-2006, 12:14 AM | #2 |
Member#: 89912
Vehicle:2006 wrx wrb |
it may only be dozzers.....
01-10-2006, 12:16 AM | #3 |
Member#: 16245
Get your code pulled. Usually mexicans can do this with the proper machine.
01-10-2006, 08:33 AM | #4 |
Member#: 58779
Vehicle:2015 Honda Fitbox 15 Legacy kid hauler |
Or Autozone. Do you have an aftermarket intake?
01-10-2006, 10:06 AM | #5 |
FTW RIP
Member#: 1820
no aftermarket intake
FTW |
01-10-2006, 11:04 AM | #6 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Fuel Filter-change it
Fuel sock on fuel pump- pull it out and clean it Clogged injectors- run a tank of injector cleaner through there OT: Still have any interest in selling off your Stromung? never heard back on your FS on pirates... |
01-10-2006, 06:51 PM | #7 |
FTW RIP
Member#: 1820
mother****er ran fine all day here in denver check engine light turned off and all. All my driving was stop and go turn car off turn car on for 100 miles.
not selling the stromung till i get a tacoma but then its yours FTW |
01-11-2006, 03:09 PM | #8 |
Member#: 77896
Vehicle:98 impreza 2.5rs Black |
you should still get the CEL checked. Your car will store the code even though it has gone off...
01-11-2006, 03:26 PM | #9 | |
Member#: 87762
Fuel Filter and 5 cannisters of Injector cleaner will probably remove the gremlins...and is easy to do. |
01-11-2006, 06:50 PM | #10 |
FTW RIP
Member#: 1820
5 cannisters of injector cleaner? What kind and how much $$ I ran some cheap ass STP through it today and drove 160 miles with no CEL
FTW |
01-11-2006, 08:27 PM | #11 | |
Member#: 87762
At 160K, if you are not going to the injector cleaning service...then I would recommend putting a cannister of techron in the tank over the next 4-5 fillups. I have 185K on my car and I just put 2 cannisters of Techron in the same tank of gas....and this after I did the injector service on it yesterday. The car is continually running better....so it is apparant that each treatment is continuing to clean out the fuel injectors. I forgot how fun these cars are to drive when they are running correctly. |
01-11-2006, 08:41 PM | #12 |
FTW RIP
Member#: 1820
my car only has 80k on it
FTW |
01-11-2006, 08:43 PM | #13 |
FTW RIP
Member#: 1820
and how many times should i run techron through it and when
FTW |
01-11-2006, 09:27 PM | #14 | |
Member#: 87762
But If the Injection cleaner took care of your CEL..and your car is running better..then perhaps you should start out by doing it every time you change the oil ? And if CEL's start popping up again.....or.....you start noticing poorer acceleration....then you can do it on a more regular basis. But I would go ahead and give is a heavy dosage on the front end by putting several cannisters in over the next few fillups....that way you are really cleaning out the injectors after not running any cleaner through them for the last 80K miles. |
01-23-2006, 09:33 PM | #15 |
FTW RIP
Member#: 1820
happened again today... could it be bad gas? I have been filling up with conoco 87 octane and before i went shredding today i filled up with safeway 87
FTW |
01-24-2006, 11:21 AM | #16 | |
Member#: 89234
01-24-2006, 01:29 PM | #17 |
Member#: 832
RMIC
01-26-2006, 10:37 AM | #18 |
Member#: 7101
Vehicle:00RS I want to fill your mouth with spiders |
If there is a fraggle in your car, you should direct all your questions to the trash heap.
01-26-2006, 08:21 PM | #19 |
Member#: 38474
Vehicle:1998 Impreza Wagon L Brilliant Red |
I think I may need to clean my injectors soon. been having some hesitation on startup lately. ... I beat you all i only have 53000 miles on mine and its the same 1998 L wagon
01-26-2006, 08:55 PM | #20 |
Member#: 98807
SCIC
Vehicle:1999 RSTi RHD BF5 & BJ6 |
01-28-2006, 03:12 PM | #21 |
FTW RIP
Member#: 1820
got the code pulled at Vato Zone it turned up P0340 "camshaft position sensor" what the hell does that mean?
FTW |
01-28-2006, 03:32 PM | #22 |
Member#: 73562
NESIC
Vehicle:05 doh mah ILikeGurlsThatLikeGurls |
i think maybe, if you cant find the fraggle, then check your filters. one time i had a tiny little unicorn poking holes in my muffler and pooping in my filters.
i mean, who would've guessed a tiny mythalogical animal pooping in my filters? jwu |
01-28-2006, 03:46 PM | #23 |
FTW RIP
Member#: 1820
I have a unicorn, its name is unicornhole! complete with the exclamation point and everything. He is quite mischevious. He craps rainbows. He ****s platypuses. But I did find out the code so you guys should help me or Im going to buy a ford focus and paint it to look like a subaru wrc car... and I know you dorks dont want that
FTW |
01-28-2006, 05:15 PM | #24 |
Member#: 89234
You need a new camshaft position sensor. It's as simple as that. It's located on the driver's side head. Easy to replace. I think it's just one bolt and a electrical connector. That should take care of your CEL.
01-28-2006, 05:39 PM | #25 |
Member#: 7101
are sensors there just to tell you they're bad and not indicate something else is wrong? could the camshaft actually be in the wrong position?
Is there an inline fuel filter in my car? Or just in tank? 07 sti | SSG | Service & Maintenance | 4 | 06-26-2009 03:10 PM |
Why is there water in my car? | ValY2J | Service & Maintenance | 5 | 06-10-2007 11:02 PM |
Is there a sub in my car? | SpecK | Car Audio, Video & Security | 3 | 04-15-2003 12:31 AM |
I think someone tried to break-in my car | M3sum | North West Impreza Club Forum -- NWIC | 9 | 08-19-2002 12:20 PM |
I think I put leaded gasoline in my car! Anything i can do? | PaulRex | Tri-State Area Forum | 9 | 07-28-2002 04:59 PM |
