01-12-2006, 11:40 AM | #1 |
Member#: 21481
NESIC
Vehicle:99 2.5RS 14 Impreza STI |
a few different problems. link between them?
I got all of these codes at once and don't see how so many things could go bad at once. The car is a 93 1.8 L. It will start after about a dozen tries but its pretty rough.
12 - Starter switch or circuit 21 - coolant temperature sensor or circuit 34 - EGR solenoid valve Help? Which should I start replacing? Think minimal spending.
01-12-2006, 12:51 PM | #2 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
#21 is your best place to start and the most common failure on those cars. Do you own a voltmeter? You can always test things, but the coolant temp sensors are known for failing...
01-12-2006, 12:58 PM | #3 |
Member#: 21481
NESIC
I could probably get my hands on a voltmeter. Where is the coolant temp sensor located exactly?
01-12-2006, 01:10 PM | #4 |
Member#: 7034
NESIC
Vehicle:2005 Nissan Altima 2.5SL - Black |
Coolant temp sensor? Wouldn't that be the thermostat?
01-12-2006, 02:02 PM | #5 | ||
Member#: 21481
NESIC
From another thread: Quote:
07 vs 08 sti where can i find out all the differences between them | swizz977 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 06-30-2009 12:39 AM |
Question about STIs. Comparison between them all? | Rento | Newbies & FAQs | 31 | 01-27-2009 11:09 PM |
End links, Any difference between them all? | Bbasso | Brakes, Steering & Suspension | 21 | 01-29-2007 09:20 PM |
Photos - Difference in size between Azenis and Re-92 | Branwell | Brakes, Steering & Suspension | 14 | 05-08-2002 05:03 PM |
Prodrive/RECARO seats...anyone have a link to them? | PURE EPI | Interior & Exterior Modification | 5 | 02-08-2001 12:58 AM |
