01-15-2006, 08:34 AM | #1 |
Member#: 86298
Vehicle:98 LGT Wagon Full WRX driveline & dash |
ej25 shortblock identification question
can anyone tell me the what to look for in figuring out what year a shortblock is from? i found a guy that has a shortblock but he isnt sure about what year it came from and i dont want a newer shortblock to up the cr. i want to try to stay with the 97-98 style for my 97 outback legacy.
01-15-2006, 10:52 AM | #2 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
This thread - http://forums.nasioc.com/forums/showthread.php?t=883746 - has some good information about determining which is which.
Pat Olsen '97 Legacy 2.5GT sedan |
01-15-2006, 02:15 PM | #3 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
The easiest way is to look at the pistons if you know they are stock. Since you want an early series motor, you'll want to see pistons with a large square-type depression across the face of the pistons. If the block is the newer type, the pistons will have a flat top with small moon shaped recesses for the valves.
Either type will be just fine if you're going to just build a daily driver. Jay Storm |
01-15-2006, 03:36 PM | #4 |
Member#: 86298
what type of compression would i be looking at if i go with the newer block, i don't want to have to run premium all the time.
01-16-2006, 12:17 PM | #5 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Going to have to run premium if you build a hybrid with EJ22 heads regardless of which Ej25 bottom end you use...
01-16-2006, 04:33 PM | #6 |
Member#: 5218
I think he may be re-using the 97 EJ25D heads from the legacy. He should be fine with regular gas....I've gone back to cheap gas on my setup....and it's got more compression than he'll have.
01-16-2006, 05:10 PM | #7 |
Member#: 86298
does anyone have any idea on numbers even somethin close
01-16-2006, 07:17 PM | #8 |
Member#: 59357
E. Canada
Vehicle:2009 Forester XT White |
What setup are you running Storm, I'm going for a phase 2 bottom end with 98 dohc heads. What type of numbers do you get?
Thanks Frazer |
01-16-2006, 08:51 PM | #9 |
Member#: 86298
im cool with a phase 2 as long as i dont have to run premium, can anyone confirm that should be the case?
01-17-2006, 01:28 AM | #10 |
Member#: 5218
I'm running a 00' EJ25 bottom end with shaved 98RS heads and .046" Cometic headgaskets. I started off running premium because I was getting misfires and knock. It turned out to be bad gas from sitting too long. Now I run 87-89 and have no problems. I use an Apexi SAFC to dial in fuel trims...but only because I'm running this motor on a 1.8L ECU.
CR numbers should be about 11:1....but I didn't do any cc'ing of anything on this motor. I followed the info posted here and other forums, which has proven to be hit and miss at best. I knew I mighta needed premium and accepted it. Now I'm happy I can run regular. xrturbo: I have a few phase I shortblocks if you need one asap. Might even trade ya for a phase II!!! Jay Storm |
01-17-2006, 10:49 AM | #11 |
Member#: 58806
Vehicle:1998 RIP Legacy2.5GT 2.2L legacy wagon |
Storm do you have any dyno numbers on this setup ...
Also wat other modifications do you have ..... I may be going with the same setup in my legacy come spring time but im not totally sure how much worth it, it would be... |
01-17-2006, 11:04 AM | #12 |
Member#: 59357
E. Canada
This is exactly what I"m doing, I just picked up these
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT and hope to find a phase 2 shortblock. What type of numbers are you putting down Jay? if not numbers, what does the butt dyno tell you? I'm planning on running this in my 98 forester which has the dohc at the moment, so it should run fine with the new setup. Frazer |
01-17-2006, 11:53 AM | #13 |
Member#: 832
RMIC
Xephyr has a phase II ej25 w/DOHC heads and HKS v3 STi 272degree cams in it that puts down 155whp...
01-17-2006, 12:33 PM | #14 |
Member#: 59357
E. Canada
is he running headers? or an intake? What could be done to bump this up a bit?
Frazer |
01-17-2006, 12:58 PM | #15 |
Member#: 832
RMIC
He's got Borla knockoff and a JC sports intake. He has recently installed a Link to play with it more. I haven't talked to him in a month or so and don't know how it has worked out...
01-17-2006, 03:32 PM | #16 |
Member#: 5218
I don't have any dyno numbers. The butt dyno is telling me I'm making at least as much as our RS and can peddle around with it. The stock revlimiter on the 1.8ECU comes in real quick everywhere but 5th....and that's only because I primarily use it to go to work and don't see a need for much more than occasional triple digits.
Quick rundown: '00 bottom end .046" headgaskets DOHC heads shaved ~.010" (ported&polished) stock RS cams USDM STi valvesprings/retainers EJ20G intake manifold EJ18 TB EJ18 ECU and sensors 98RS injectors/rails/fpr Apexi SAFC RS fuelpump EJ25 Fidanza flywheel MRT header (half-catted) 96 brighton trans |
01-17-2006, 04:12 PM | #17 |
Member#: 832
RMIC
I wish you would get that car on the dyno. I have a curiousity to know what Pnp head do on stock cams. I was contemplating putting my Pnp heads on the '95 to run with the SC and see what that does...
EJ25 Shortblock to '02 WRX Swap, VSS Question | toxictv | Subaru Conversions | 5 | 02-01-2010 04:55 PM |
WTB: EJ20 engine/shortblock or EJ25 shortblock | alwu | Private 'Wanted' Classifieds | 5 | 11-21-2009 09:32 AM |
Question about EJ25 shortblocks | JdmBugI | Built Motor Discussion | 9 | 12-13-2007 08:32 AM |
EJ25 Shortblock question | Honkey3k | Normally Aspirated Powertrain | 1 | 08-30-2004 02:48 AM |
Part Number for Phase 2 EJ25 shortblock | oman | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 01-22-2002 05:50 PM |
