Welcome to the North American Subaru Impreza Owners Club Sunday January 22, 2017
Old 01-22-2006, 10:31 PM   #1
rabbitnutz
Member#: 51940
Default can someone check my coil pack wiring for me?
so my car is only firing on the back (closest to firewall..) cylinders, and i need my 3 to 4 coil pack wiring double checked. either i wired it wrong, or i have a bad coil pack. wiring is easiest to check i suppose, so here goes. i've got the two .pdf files needed for the wiring diagram, and tomorrow afternoon i will take pics. i just need to know if i put the correct color wire with the correct color wire. if i did actually do that, i'll look into testing the coil pack.
colors on conector from MY98 2.2 harness are as follows:
•red with green-ish stripe
•yellow with green stripe
•blue
colors on the MY02 2.5 connector:
•blue
•green with white stripe
•yellow with white stripe
•red with green stripe.
if anyone thinks they can help if i send them the .pdf's, or knows someonw who can help me out, it'd be appriciated.
~Nick.
rabbitnutz is offline   Reply With Quote
Old 01-22-2006, 11:14 PM   #2
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
hmm.. i didn't know your donor was an 02. But i had the coil pack go bad on me shortly after i did my swap.. But it had been acting up before i ever swapped it from my RS. Seems to be a common problem with the RS.
I'll look at my 01 book, and see if those colors are the same.
subbyspeed is offline   Reply With Quote
Old 01-22-2006, 11:16 PM   #3
gusto
Member#: 58323
nick-
email me them. ill take a stab. i have access to all schematics as well if you need something.
[email protected] dot com
gusto is offline   Reply With Quote
Old 01-23-2006, 09:39 AM   #4
rabbitnutz
Member#: 51940
subbyspeed: thanks
Gus: sent.
Old 01-23-2006, 11:55 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um that is 3 & 4 don't you mean you need the wiring checked on 1&2
Old 01-23-2006, 05:39 PM   #6
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
Heres the 2000+2001 info for the ignition coil connector
Pin 1- Blue
Pin 2- Yellow
Pin 3- Green
Pin 4- Red/green stripe
Old 01-24-2006, 11:03 PM   #7
rabbitnutz
Member#: 51940
Pin 1- Blue
Pin 2- Yellow
Pin 3- Green
it worked !!!! car runs on four cylinders now!!!!!
too bad it idles at 2200 RPMs
Old 01-24-2006, 11:26 PM   #8
subbyspeed
Member#: 16274
2001 GM6 2.0L vf30
e30 black/rust
haha, glad it runs..
That idle problem.. well, uh. yeah. vacuum leaks or something? bad IAC?
Can someone check my learning view please? jexeffectz Open Source Reflashes 2 03-16-2010 01:24 PM
Can someone check out these alignment measurments for me? ismegamanthere Tire & Wheel 13 12-10-2007 02:01 AM
Can someone check my logs? CarterMarkham Commercial ECU Reflashes 11 11-12-2007 01:19 PM
Raleigh area: Can someone check out a car FS for me? Help! Rice & Gravy South East Region Forum 4 10-17-2005 09:25 AM
Can someone go look at their car for me IMPREZIV Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-01-2002 12:40 AM
