01-24-2006, 08:42 AM | #1 |
Member#: 102985
Vehicle:2000 Outback Sport Blue |
2000 OBS (2.2L) PCV valve?
Does my engine have PCV valves? I was looking yesterday to see if I should change them or not and it looks like the hoses just go straight into the valve covers. Are there PCV valves there under the hose?
Also, what is the third hose going into the airbox coming from around the throttlebody area? Thanks!
01-24-2006, 10:49 AM | #2 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
The PCV valve is in the intake manifold. It's the black fitting with the hose on it.
The other hose should be for the IAC (idle air control). It's just a throttle bypass for the idle, and the the valve on the manifold is opened and closed electronically by the ecu. |
01-24-2006, 03:19 PM | #3 |
Member#: 102985
hmm, then what are the two hoses going from the valve covers straight to the airbox?
01-24-2006, 08:43 PM | #4 | |
Member#: 24915
Vehicle:2000 L Wagon Aspen 93 L Wagon Aqua |
01-25-2006, 10:30 AM | #5 |
Member#: 102985
ok, this might be a stupid question, but isn't the crankcase venting system the PCV system? If I get a catch can or just vent using breather filters, which hoses should I use?
01-25-2006, 07:40 PM | #6 |
Member#: 60116
Vehicle:1999 RS Coupe Silver Thorn |
Take off the air box and the intake tube, and it is on the rear of the intake manifold, just left from center. Disconnect the larger hoses one by one until you find the Pcv valve.
01-26-2006, 02:24 PM | #7 |
Member#: 102985
ok, I understand where the PCV valve is now but what can I do with those two hoses coming from the valve covers to the airbox? They're putting oil into the airstream as well. Can I just vent them using breathers?
01-26-2006, 09:25 PM | #8 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
in my old intake set up i t'ed them together to a breather filter and capped the intake pipe. never had any problems.
01-28-2006, 09:23 PM | #9 | |
Member#: 24915
Tod |
MY98 2.5 RS fog lights in a 2000 OBS? | jeff_rage | Electrical & Lighting | 3 | 07-14-2011 08:05 PM |
2 WRX Fuel Filters and 1 PCV Valve | gbwrx | Engine/Power/Exhaust | 1 | 09-22-2007 10:13 PM |
2002 2.5 PCV valve | craigz | Normally Aspirated Powertrain | 3 | 09-05-2006 10:19 AM |
