Welcome to the North American Subaru Impreza Owners Club Friday April 28, 2017
Old 01-25-2006, 05:22 PM   #1
jjameson
Member#: 4986
2002 BlzYel JDMSTiv7
GRP 08 FXT
Default JDM EJ207- Where to install oil pressure sensor
So when I had my USDM WRX EJ205 motor I had installed my apexi oil pressure sensor into the port on the block below the intake manifold/alternator. I had removed the set screw type thing on the block and installed some NPT fittings and a little metal line to raise the locoation of my sensor to above the intake manifold. The sensor has what, an 1/8" NPT fitting.
This worked well. This seems like (being the engineer that I am) a better place than adding on a oil filter adapter to install sensors. The oil filter adapter just seems kinda hokey, but would work perfectly fine.
So on my JDM EJ207 swap where is the best place to install the oil pressure sensor? Is there a similiar port or bung on this EJ207 block or do I just go the route of the filter adapter?
jjameson is offline   Reply With Quote
Old 01-25-2006, 05:48 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Unless there is something unique about the EJ207, every Ej series block I have ever seen has that port you used...
Old 01-25-2006, 07:23 PM   #3
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
you saw the one on the V7 block matt, its there.
now, if anyone has that part number for the subaru part that goes into that bung.....
anyone?
Hurley 2.5 WRS is offline   Reply With Quote
installed oil pressure sensor-> CEL Lamb155716 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-29-2008 11:28 PM
Where to install oil pressure sensor? Alaskan EJ20 Alaskan Impreza Club Forum -- AKIC 10 02-21-2008 08:56 PM
Where to put oil pressure sending unit? rok_toy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-09-2005 10:29 AM
Where to get oil pressure sensor SLowery Electrical & Lighting 9 04-12-2003 11:44 PM
Help - where to get oil pressure fittings CStearns Bay Area Impreza Club Forum -- BAIC 2 03-30-2002 11:01 PM
