01-26-2006, 04:40 PM | #1 |
Member#: 89446
Vehicle:04 rs psm |
00-01 intake on 04
will a intake that is for a 00-01 fit on a 04 rs. I mean its the same engine and same intake design so i would assume so rite?
01-26-2006, 09:17 PM | #2 |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
it does, but you need to make a hole for the ait sensor. i am using a cobb intake. here is a pic of my my04 with a cobb cai. you cant really see it but i drill and dremeled out a hole near the bend, and use the rubber grommet from the stock intake to help fasten it.
01-26-2006, 10:05 PM | #3 |
Member#: 87139
Vehicle:2003 Forester XS JBP |
00-01 Impreza are Map based not MAF if your car is Map based it fits.
01-26-2006, 10:10 PM | #4 |
Member#: 22664
everything ATX said is correct, it is what i did on my 03 and 04, get a 00-01 cobb and drill the hole i think it was 1/4" hole? but dont hold me to that i can check just use one of unibit drill bits, and start small and keep checkin every little bit
remeber when you are done clean out all metal shavings and any leftovers, wash out the tube.. and check fitment |
01-26-2006, 10:29 PM | #5 |
Member#: 89446
Vehicle:04 rs psm |
does it matter where you drill the hole in the tube?
01-26-2006, 10:31 PM | #6 |
Member#: 22664
id attempt to do it as close to the filter as you can like around or before the bend
now the sensor might not reach but the wire is wrapped in like electrical tape you can cut it out carfully to get some more length out of it REMEMBER MEAUSRE TWICE CUT ONCE!! i cannot stress that enough make sure the sensor can reach the hole you drill before its drilled |
01-26-2006, 10:31 PM | #7 | |
Member#: 89446
Vehicle:04 rs psm |
intake on 04 wrx? | wrxstyles | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 01-27-2008 12:30 PM |
WTB: 00-01 RS or 00-02 Forester stock air cleaner / air box / air intake tubes | JapCarRealGood | SWIC Private Classifieds | 2 | 12-30-2006 01:18 PM |
WTB: 00-01 RS sedan or 02-04 WRX or even 96-01 OBS/GD wagon... | G2 | Private 'Wanted' Classifieds | 1 | 02-27-2004 01:23 PM |
00-01 Impreza on History Channel: Drag Racing | quentinberg007 | General Community | 1 | 05-22-2002 02:55 AM |
FS: AEM Short Ram intake RS 00-01 | KillerTHC | Bay Area Impreza Club Forum -- BAIC | 10 | 12-26-2001 02:32 AM |
