Welcome to the North American Subaru Impreza Owners Club Friday August 18, 2017
Old 01-26-2006, 11:18 PM   #1
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
OMGHi2U Help with turbo dyno graphs
I'm in the process of making a very simple to read turbo upgrade chart for the WRX. It will look like this:
Turbo Name/Full Spool RPM/Max TQ/Max HP
What help I would like would be in the form of dyno plots. ANY dyno plots you have of ANY aftermarket turbo on a WRX would help. Specifically, I'd like the following:
Car mods list (just performance) + dyno plot
I am NOT interested in your:
Race gas plot
OMFG eleventy billion PSI, blowtorch EGT tune plot
I'm looking mostly for full TBE + aftermarket turbo plots. If you are skeerd to post, you may send me your mod list and plots to [email protected] as it's far easier for me to receive email than to surf the boards with my slow connection on this ship underway.
Don't be afraid to post if there are already posts with your turbo type. I'm looking for averages here and I am also aware of different dynos, elevations, gas types, tunes, etc. My chart will be for TREND ANALYSIS so that in general terms one can say that X turbo is generally bigger than Y turbo for those that don't want to mess with CFM data or compressor maps.
Old 01-26-2006, 11:19 PM   #2
intence
Member#: 58477
. Member #1 of
the witty MS Crew
ah no love for stock turbo?
intence is offline   Reply With Quote
Old 01-26-2006, 11:27 PM   #3
patr
Member#: 97
"full spool RPM" is a bit misleading. On a load holding dyno you can get any turbo to make a lot of boost really low, down low where you would only ever see it in 6th gear on the road. i.e. you can get an FPGreen to make lots of boost at 2600 RPM if you want to, it just might take a while. A more accurate figure IMHo of spool speeds would be something like "time to xx bar at xx RPM". Or, if you really want an RPM number, "RPM to reach xx bar at yy rate of acceleration starting from zz RPM". And of course, this would all have to be with equivalent flow characteristics of the other components (i.e. not FMIC vs TMIC or headers vs. non etc)...
patr is offline   Reply With Quote
Old 01-27-2006, 05:12 AM   #4
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Of course there's stock turbo love.
I know about dyno loading, that's where dynojets come in. I'll do my research to level the field as headers, FMIC, etc will play a roll.
While my chart will not be 100% perfect, you have to realize that 90% of people don't feel like learning compressor maps to find their perfect turbo. This chart is for n00bs as a general guidline vs what the more advanced user would use.
Old 01-27-2006, 10:03 AM   #5
intence
Member#: 58477
. Member #1 of
the witty MS Crew
heck ill post up
stock td04 / full spool at 3500 / 235hp / 235trq
Cobb Stage 2 93 oct 16 psi
Catless TBE (TXS stealthbacK + prodrive)
Catless Uppipe (Helix)
IC Hoses (Samco)
Old 01-27-2006, 10:21 AM   #6
vlady
Member#: 77997
dirty blue
Here is my mod list (that matters):
vf34
sti pinks
walbro fuel pump
Borla header
Perrin up
Helix dp (catted)
Greddy evo2 catback
Helix tmic (which made the car amazingly consistent on the back to bak dyno runs- almost 20)
Protune (AP)
Forge bov
GPMoto shorty intake
So here are the numbers.
Cobb OTS vf34 map (91oct) ?psi
248.13whp
253.60wtq (this was only due to a boost spike at around 3700rpm)
AFR- 10.5-1
Harman 91oct - 17psi fading to 15psi at redline
265.40whp
253.41wtq
AFR- 10-1 (the key here was safety since I'll be running crappy 91oct most of the time)
This was smooth as butter
Harman 95oct (aproximate, 5gal of 101 to half tank of 91) - 18psi
290.24whp
277.43wtq
AFR- 11-1
Full boost on the dyno is seen at 3600. On the street, positive pressure is seen as early as 2200rpm (in 3+gear) and full boost is at 3400rpm.
I will dig up the dyno sheet and post it very soon.
vlady is offline   Reply With Quote
Old 01-27-2006, 10:36 AM   #7
djoye
Member#: 50072
2017 WRX STi
WR Blue
Mods:
  • VF22 turbo
  • STi pink injectors
  • Walbro fuel pump
  • TurboXS 2.5" turbo-back (Magnaflow muffler) + gutted up-pipe
  • XEDE (used Vishnu Stage 2 map with modified boost table as the base)
Tuning done at Dyno4mance on their Dyno Dynamics dyno.
93 octane: (250HP, 230TQ)
djoye is offline   Reply With Quote
Old 01-27-2006, 11:04 AM   #8
turbo tecnica
Member#: 74470
2013 Accord Sport
72 LS1 Vette
My mods:
- IHI VF39 turbo
- STi 565cc Pink injectors
- Walbro 255lph fuel pump
- Cobb AccessPort (Protuned @ TDC Tuning)
- Invidia uppipe
- HKS downpipe
- Borla cat-back
93 oct., 16.8psi boost, hits full boost (on the street) around 3500-3700rpms. Ran it like a dog on the dyno (20~ runs, stock TMIC). These are VF39 numbers vs. my previous Cobb OTS stage 2 numbers.
269whp / 250wtq
turbo tecnica is offline   Reply With Quote
Old 03-21-2006, 12:51 PM   #9
intence
Member#: 58477
. Member #1 of
the witty MS Crew
more!
Old 03-21-2006, 03:00 PM   #10
Erexxx
Member#: 92054
2008 Mazdaspeed 3
Cosmic Blue Mica
Helix catless Turbo Back Exhaust
Samco Intercooler hoses.
Stock airbox with removed silencer
Cobb Stage 2 91 octane MAP.
Green is stock run...And the others are cobb cali 91 stage 2, and regular cobb stage 2 91.
click to enlarge!!
Erexxx is offline   Reply With Quote
Old 03-21-2006, 03:57 PM   #11
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
MOD list
Spearco TMIC
Injen up pipe, xover pipe, short ram
Cobb TBE w/hi flow cat
Samco Y-pipe
Pinks
VF39
Walbro
This is on CA 91 oct Protuned at Harman
markuswelby is offline   Reply With Quote
Old 03-21-2006, 03:59 PM   #12
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
And here is my stock turbo plot
Mod list
Stock turbo
Injen uppipe,xover pipe, short ram
Protuned at Harman on CA 91 oct
Old 03-21-2006, 08:06 PM   #13
testes1010
Member#: 47145
2012 Gas Saver
My old VF30 setup:
Peak HP: 266whp @ 6250rpm
Peak Torque: 253wtq @ 4800rpm
Full Boost in 3rd gear: 18psi @ ~3000-3200 rpm
Mods: 93 pump tune by RiftsWRX, TXS UTEC, Hyperflow TMIC, catless TurboXS TBE, Crucial Uppipe, 'Pinks', Walbro 255lph Fuel Pump, XS-Engineering CAI, Deadbolt Monster Vf30, NGK Iriduim Stock heat range plugs.
My current DB TD05H-20G setup:
Peak HP: 326whp @ 6650rpm(meth), 308whp @ ~6400rpm(no meth)
Peak TQ: 292wtq @ ~3700rpm(meth), 273wtq @ ~5400rpm(no meth)
Full boost in 3rd gear: 21psi @ 3500-3600rpm(meth), 23psi @ ~3600rpm(no meth)
Mods: 93 Octane tune - TurboXS UTEC (professionally tuned by Jorge @ P&L Motorsports), TurboXS Hyperflow TMIC, TurboXS Magnaflow Catless Turboback Exhaust, BPM XVR crossover pipe with port-matched & ceramic coated stock exhaust manifold, services supplied though Crucial Racing, Crucial Racing Uppipe, Crucial Racing 160deg T-stat, Ultimate Racing 785cc/min Cylinder Flow Matched Injectors, Deadbolt Zilla TD05H-20G (ceramic coated), CoolingMist 150PSI Alky Injection (UTEC activated, 50/50 Meth/Water), GMC Syclone Boost Solenoid, Perrin Turbo Inlet Hose, Walbro Fuel Pump 255lph, XS Engineering CAI, Mr. Josh's Lightened Crank Pulley, APS DualVent BPV, DIY Stainless Steel Hi temp painted & thermal barrier covered Turbo/Downpipe Heatshield, NGK BKR7E gapped @ 0.025
testes1010 is offline   Reply With Quote
Old 03-22-2006, 10:00 AM   #14
VWGrk1
Member#: 57882
2004 WRX
E-mail sent. Hopefully the number of people who e-mailed you is greater than the number of those who posted.
VWGrk1 is offline   Reply With Quote
Old 03-22-2006, 10:03 AM   #15
-Kevlar-
Member#: 82378
<--- Hot Donuts Now
you dont have a dyno shop on the boat you could get it from?
-Kevlar- is offline   Reply With Quote
Old 03-30-2006, 12:05 PM   #16
gizmodude311
Member#: 71856
2002 psmWRX wagoneer
COBB VF39, v7 STI susp
You're my hero
gizmodude311 is offline   Reply With Quote
Old 03-30-2006, 12:12 PM   #17
gizmodude311
Member#: 71856
Originally Posted by turbo tecnica
My mods:
- IHI VF39 turbo
- Invidia uppipe
- HKS downpipe
- Borla cat-back
269whp / 250wtq
This is exactly what I am planning on doing... I was wondering if someone had a similar setup, but with a port and polish on the turbo... I would like to regain a little of that low-end back and I have a really good turbo shop in town that can do a p&p...
Old 03-30-2006, 12:14 PM   #18
gizmodude311
Member#: 71856
^ also if someone had a dyno of a clipped vf 39, that would be great!
Old 03-30-2006, 05:08 PM   #19
WRXShawn
Member#: 35742
2002 PPG + FPGreen
I-Speed has a great database of dyno graphs that you can use. It provides the mods for the vehicles as well. Check it out:
http://www.i-speed.us/dyno_results/db_searchDyno.cgi
WRXShawn is offline   Reply With Quote
Old 03-30-2006, 05:18 PM   #20
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
Not sure if GREAT is the correct word....
just searched for any 2.0L WRX with VF39 and came up with nothing......
Old 03-30-2006, 05:33 PM   #21
gizmodude311
Member#: 71856
I saw a suby with a MUGEN sticker on it about an hour ago... we should dyno his car and see how much HP the sticker added
sorry... off topic I know... i'm just bitter .... what an idiot
Old 03-30-2006, 05:48 PM   #22
markuswelby
Member#: 82379
2005 KWIK WRX
WR BLUE
HA HA, don't be furious, just LAUGH!!
Old 03-30-2006, 08:26 PM   #23
JRSCCivic98
Member#: 67080
Originally Posted by markuswelby
HA HA, don't be Furious, just LAUGH!!
Maybe the guy with the Mugen sticker was Fast... Get it?
JRSCCivic98 is offline   Reply With Quote
Old 03-30-2006, 08:48 PM   #24
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
Lets start from the front of the car and work my way back.
Perrin Lightweight Pulley
Injen CAI
Perrin Tubo Inlet Hose
IHI VF-39
USDM STi TMIC
STi Pink Injectors
Megan Header/Up-pipe
Helix Catted DP
Greddy EVO Catback
Walbro Fuel Pump
StreetTuned on the Road by... Myself
Full Spool at 4100-4200 RPM
252 HP/261 TQ
Mustang Dyno
darksands is offline   Reply With Quote
Whats With My Dyno Graph!!?? outlwstr Proven Power Bragging 47 03-09-2008 10:24 PM
100% stock vs. upgraded turbo dyno graphs desert pirate Proven Power Bragging 9 08-07-2006 01:50 AM
Help with weird dyno numbers... Invisiguard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 12-11-2003 10:57 AM
Aftermarket Pulley with turbo dyno question Kevin Thomas Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-19-2003 08:38 PM
