01-28-2006, 06:42 AM | #1 |
Member#: 20744
Vehicle:05 Baja Regal Blue 03 WRX Little Red Wagon |
Header setup
I'm looking for an EL header setup with a high flow cat that will bolt up to the stock catback. Which headers will do this and not have any CEL issues?
01-28-2006, 06:49 AM | #2 |
Member#: 40636
Vehicle:2001 2.5 RS Coupe Silver |
None. It's that simple.
01-28-2006, 10:38 AM | #3 |
Member#: 92913
W. Canada
Vehicle:2005 2.5RS Wagon Crystal Grey Metallic |
Pretty much your only option is TWE headers with Stromung or RT high flow cat pipe.
EDIT: Actually, now that I think about it, doesn't Cobb offer an HFC option? |
01-28-2006, 10:59 AM | #4 |
Member#: 52744
W. Canada
Vehicle:2005 Outback Gold |
Yes Cobb offers a High flow cat option on there headers, i recomend the COBB headers.
01-28-2006, 02:39 PM | #5 | |
Member#: 20744
01-28-2006, 09:08 PM | #6 |
Member#: 74769
Vehicle:07 WRX TR UGM |
rallitek is comin out with a HFC version soon
01-28-2006, 10:10 PM | #7 | |
Member#: 92913
W. Canada
EDIT: Now that I think about it, it's probably a pressed-in half-donut, so the answer to that part of your question is Yes. |
01-28-2006, 10:18 PM | #8 |
Member#: 105490
VIC
Vehicle:2005 Impreza 2.5RS PSM 2.5L of N/A fury :-( |
The Stromung has bungs weled in. One is up front in the stock location (on my '05 RS anyway) and the rear one is on the cat itself which is nearer the end of the cat pipe. On my car this required me to solder in 4 wires of about 2ft in length to the rear sensor so it would reach.
It also has a flared end, well actually the pipe just extends past the flange on the cat pipe, and a donut gasket (a stock sized one by the look of it) fits in nicely. The stock cat back will join up ok. With my TWE headers, I did notice a lot of metallic rattling noises with the Stromung cat. Since switching back to the stock cat I get less of that noise, but it's still there. I'm not sure what causes that noise yet. |
01-29-2006, 02:11 AM | #9 |
Member#: 49694
NESIC
Vehicle:2021 6spd Mojave Snazzberry |
right now i'm running the cobb coated with high flow cat, with stock cat back. it bolts right up but i get a cel after about 100 miles or so
01-29-2006, 02:54 AM | #10 |
Member#: 40636
Any of the above options are good. You will be happy with the power they make, and it will make the car feel much better. However, you will throw a CEL with any EQ header setup. So if you don't want a CEL you better stay with stock parts, or maybe even try a CEL fix, such as the MIL eliminator or an O2 extendor.
FS: Normally Aspirated (NON-Turbo) JDM header setup, only one in the country!!! | Kostamojen | Engine/Power/Exhaust | 7 | 10-17-2008 04:24 PM |
Everything you NEED!! uppipe,dp,headers,TBE, & Chip tuned for the whole setup! | Stover954rr | Private 'For Sale' Classifieds | 9 | 12-22-2005 10:18 AM |
borla headers with stock setup? | subenick | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 5 | 06-02-2004 06:33 AM |
Headers for twin scroll setup | EMS | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 41 | 12-08-2003 08:07 PM |
equal length header setup | N/A | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 07-24-2002 08:55 PM |
