01-29-2006, 02:27 AM | #1 |
Member#: 76586
RMIC
Vehicle:2006 9-2x Aero |
Serious Misfiring
My car has been misfiring for the last couple months or so. It runs fine when its cold, but as it warms up it starts to misfire. By the time it gets totally warmed up its misfiring like crazy anytime the engine is under load.
Any ideas? The misfiring is the worst below 3k rpm. Above 3k some of the misfiring goes away, but it still runs like i'm towing an anchor. Replacing the spark plugs seemingly fixed the problem(obviously not really) for about 800-1000 miles, then the misfiring came back. Paying for college is strain enough on my wallet, so i would rather not have pay someone $200 to tell me it was a $20 sensor. Your help is greatly appreciated. Ken
01-29-2006, 09:02 AM | #2 |
Member#: 11808
I would first remove the chassey ground wires and clean the lugs and the surface where they attach to. Pay especial attention to the ones on the shock towers and the firewall. If that doesn't cure it then I suspect the coil pack.
01-29-2006, 09:59 AM | #3 |
Member#: 22462
SWIC
Vehicle:2001 AutoFozzyFTW SilvernBlack |
A buddy of mine had the same issue last year . It turned out to be a coil pack .
01-29-2006, 10:53 AM | #4 |
Member#: 90513
my uncles outback had a misfire, that wouldnt throw a cel. they replaced plugs, wires, and a coil pack. it turned out to be a bad o2 sensor.
01-29-2006, 01:06 PM | #5 |
Member#: 11808
Bad O2 sensors usually get a CEL rather quickly but, no one said anything about a cel.
01-29-2006, 02:21 PM | #6 |
Member#: 76586
RMIC
Can anyone explain why replacing the spark plugs would temporarily fix the problem if it were caused by coil pack or O2 sensor or something else?
misfires misfire misfires galore! | bugeyerex02 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 05-12-2010 05:46 PM |
misfire...misfire...misfire... | BoXinWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 18 | 05-28-2009 02:18 AM |
first cylinder 1 misfire, after plugs, 1,3,4 misfire! | DieselClown | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 32 | 08-26-2008 02:59 PM |
Multiple Misfire and Misfire Cylinder 3 | Anub1s | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 12-19-2005 12:40 PM |
misfires,misfires,misfires | eatsrice | Engine Management & Tuning | 6 | 08-04-2004 08:47 AM |
