02-01-2006, 11:56 AM | #1 |
Member#: 791
Vehicle:1998 Impreza RS Brilliant Red |
Weird loss of throttle
Ok... I've got a strange one here. It's happend occasionally over the past 3 or so years, but has been getting worse as of late.
Here's what happens... I'll be driving along, highway or city streets, and I lose all throttle response. If I push the clutch in long enough for the RPMs to drop below 1500 or so, the car will stall. I have to shut off the car completely, and start it again to get moving again, and it'll be fine for a random period of time, usually measuring in days or weeks. It feels similar to fuel starvation when the problem occurs. I've replaced the MAF and cleaned the IAC, with no results. Any ideas??? Chuck '98 2.5RS 260,000 miles or so...
02-01-2006, 12:14 PM | #2 |
Member#: 80465
RMIC
Vehicle:2001 2.5RS Black Diamond Pearl |
Almost sounds like a loose wire somewhere.
02-01-2006, 01:14 PM | #3 |
Member#: 791
Hmm... how do I go about troubleshooting something like that? Just start shaking the looms while the car is running, hoping that the problem happens?
Thanks! Chuck |
02-01-2006, 01:21 PM | #4 |
Member#: 76586
RMIC
Vehicle:2006 9-2x Aero |
Clogged fuel filter?....I would think that would cause more frequent fuel starvation......but its a guess.
02-01-2006, 02:29 PM | #5 |
Member#: 28352
SWIC
Vehicle:1993 1.8 helL (AWD) '06 Corolla XRS! |
Heh, at 260k miles God only knows what's wrong... I say junk it or take it to a shop before you cause an accident. Otherwise it's really not worth the trouble, IMO.
02-01-2006, 02:30 PM | #6 |
Member#: 85900
NESIC
Vehicle:2001 Forester S White |
clogged fuel filter or crap in teh gas tank im thinking
02-01-2006, 04:03 PM | #7 |
Member#: 80465
RMIC
Well, you've had it for at least the past 3 years, what kind of maintenance have you done? I believe you're supposed to change the fuel filter every 60K miles or so. What about the pre-pump filter? might check that out too. or stick a fuel pressure gauge on and look at it whilst running the engine.
02-01-2006, 05:37 PM | #8 | |
Member#: 74900
Vehicle:2008 STI black |
anyway.. I'd start by looking in the engine compartment for frayed wires, bad grounds, anything like that... There are a ton of things it could be.. Is the check engine light coming on when this happens? I have a hunch that it could be your ignition switch.. Try jiggling the keys when it happens, or quickly switching the engine off then on again. like, within 1 second, switch the ignition to accessory, then back to on. (not "start") Get back to us |
a weird loss of power in accelerating? | hagood22 | Newbies & FAQs | 3 | 08-27-2007 11:54 PM |
Weird knock / loss of power event (UTI logs) | bpwatts | UTEC | 13 | 11-23-2006 12:37 PM |
Help, Bucking/loss of throttle | D_Ras | Newbies & FAQs | 5 | 06-03-2006 11:17 AM |
Is loss of HP at the wheels a straight loss or is it a proportional loss? | SC WRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 07-09-2003 09:28 PM |
Signifigant loss of power durring light throttle | Fish | Normally Aspirated Powertrain | 23 | 07-23-2002 11:41 PM |
