02-02-2006, 01:18 PM | #1 |
Member#: 20498
NESIC
Vehicle:2006 WRX TR Aspen White |
what is the issue? coolant pics
Hey guys, well it seems that i have absolutely no luck. Car went in to the shop approx 3,000 miles ago for a leaking headgasket. was replaced with cometic gaskets, twe cams, valvesprings/retainers etc. thermostat, timing belt, water pump.
ive been battling a hesitation issue, replaced coil pack, cat, pcv, fuel filter, wires, plugs, front o2, about to replace knock sensor. and now this. about 1,700 miles after the work was done, i was getting gas, and decided to check my oil! the stick came up BONE DRY. so i put a quart in and immediately brought the car for an oil change. switched to synthetic at this point, not sure what weight was used. 1,300 miles later! i notice the oil pressure dropping during cornering, and braking... car is DRY again! im consuming oil at an alarming rate! there is no oil on the ground around the car, and no blue smoke coming from the tail pipe. i popped the cap to the radiator and the coolant looks a nice green normal color. -i check my coolant overflow tank and see a froathy / milkshake mess with black deposits floating on top. -the oil on the dipstick looks normal and does not appear to have coolant in it. (ie. milkshake, or thicker) -I have recently ran a can of techron through my gas tank. -at idle i notice small bubbles every once and a while in the coolant overflow tank. -while opening and closing the throttle i get big gulping bubbles. The first picture is of the car when it is cool. notice the black gunk stuck to the sides of the container. There does not seem to be fluid oil floating on top of the coolant, just these deposits, and the froathyness. the second is after a normal drive to get lunch and then back to the office. If the car is driven harder the coolant gets much thicker and the level raises quite a bit. car is going back to the shop Monday morning. someone tell me the head gasket isnt leaking again! i can not afford to open this engine again! the amount of money ive spent on this car could have easily afforded me a complete STi swap with some beer money left over.
02-02-2006, 01:37 PM | #2 |
Member#: 11506
NESIC
Vehicle:2010 Legacy GT 1999 10AE Miata |
Poo.... looks/sounds like your cometic HG is leaking I think.
If the exhaust ports on your block are discolored brown, then it is most likely a leak |
02-02-2006, 02:38 PM | #3 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 19 Audi RS3, 13 Armada |
Milky Colored Coolent + Black Slime Chunks In Overflow Tank = Compression Leak from Cylinder Bore to Coolent Passage
Possible Reasons: Blown Headgaskets Cracked Cylinder Warped Head Deck Warped Block Deck Your car should be under a 100k mile headgasket warranty. I don't know how all of that stacks up with your new parts and cometic HG. Call the SOA Warranty line listed on their site. Good luck getting anything out of them. Should have gone for the STI swap. Seriously you'll never get rid of the headgasket issue. Brad |
02-02-2006, 03:02 PM | #4 |
Member#: 20498
NESIC
the only thing im hoping for now is some kind of warrenty on the work that the dealership did the first time. headgaskets were replaced 3,000 miles ago! should not have blown or be leaking already.
02-02-2006, 03:47 PM | #5 |
Member#: 5030
I would investigate a little and ask if they measure the deck to be true on the block and heads before installing HGs. If not ask why?
I had mine replaced under warranty at 58k miles and they were leaking again by 89k. I got on the phone with SOA and they said since mine was a Phase I motor it wasn't covered by the 100k HG warranty that Phase IIs have. Apparently not enough people with Phase Is complained. Now for a shortblock swap. Brad |
02-04-2006, 11:15 AM | #6 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
It does not look good.
MY99 2.5GT pretty much covered it. Neither of my Phase-I's were covered, so don't complain since you may have an out with SOA. |
02-04-2006, 12:30 PM | #7 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
When my head gaskets blew the 2nd time, less than a year after being replaced by the dealer the 1st time, it was covered. However, that was because there was a 1 year, unlimited mileage warranty on the parts. Since you had them use the Cometic gaskets I think you'll probably be SOL.
Good luck... Pat Olsen '97 Legacy 2.5GT sedan |
02-04-2006, 09:59 PM | #8 |
Member#: 24718
Vehicle:05 impreza RS white |
I was having the same problem with my 99 RS before I sold it. I had just had the motor fixed because the #3 piston broke. After the guy that got it tested it he found out that it was leaking and the block was warped. Good luck with this.
chris |
What is the issue? | Rallly2000 | Suspension/Brakes/Handling | 1 | 07-19-2009 11:22 PM |
If money is not an issue, What is the best EMS? | smac | Engine Management & Tuning | 10 | 08-01-2006 05:18 PM |
Assuming no alignment issues, what is the best performing (dry) tire that is QUIET! | Drew888 | Tire & Wheel | 0 | 04-12-2005 09:30 PM |
What is the issue with STI splitters on wagons? | Chris91se | Interior & Exterior Modification | 2 | 04-01-2005 11:06 AM |
What is the avg coolant temp? | waitandbleed92 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 02-20-2004 01:34 PM |
