Welcome to the North American Subaru Impreza Owners Club Tuesday September 29, 2020
Old 02-05-2006, 06:40 AM   #1
ka mano
Member#: 78022
PdxT built 2.5L 6sp
30R.82, 274/276, H2O+meth
Default CONTEST: Free PdxTuning! Free Torco! Guess dyno#s: 2.5L, GT30R.82, DPR2 cams
PdxTuning.com is doing a build on my '05 WRB wagon. I thought I'd share the fun with you guys and make it interesting with five contests (#5 added on 9-19-06). PdxTuning and the manufacturer of Torco, torcoracefuels.com, are offering some great prizes!
There will be eight prizes winners. Six will receive free bottles of Torco, a fuel accelerant I use all the time.
PdxT will be tuning 5 maps: 1) 92 pump, 2) pump + water injection,
3) pump + water/meth injection, 4) pump + water/meth + Torco, and 5) C16
The first three contests will use the best dyno pull on map 4 with water/meth injection and Torco.
Here are the first three contests: . . . . . . (no entries after 9-12-6)
Predict the:
1. Maximum wheel horsepower
2. Maximum wheel torque
3. RPM when maximum wheel torque is first achieved
Post your guesses in this thread and I'll compile them below in posts #4 and #5 so everybody can see which numbers have been taken. The first person to pick a number claims it for themselves. One entry per member per contest. The closest prediction on each of these first three contest questions will win. If the exact winning number for a contest question isn't chosen, the closest guess wins, with a tie going to the lower number. Same deal for question #5.
No fractions or edited posts will be recorded as valid entries.
Here are the final two contests:. . . . . . . . . (still open for entries)
4. Create a spreadsheet (or other proof) calculating the octane equivalent of TORCO
5. What gain in peak whp will we get during the tune when we move from
. . pump + water/meth injection to pump + water/meth + Torco?
It's possible to win five prizes. Let's have some fun!
Here are the prizes: (All eight winners will receive a PdxT-shirt!)
#1 PEAK HORSEPOWER
1st Prize: free PdxTuning EcuTek or Cobb AP base map upgrade + a PdxT window banner
2nd Prize: 10% off the normal price of: an EcuTek reflash, an AccessPORT, or a UTEC.
#2 PEAK TORQUE
1st Prize: 3 bottles of TORCO + a PdxT window banner
2nd Prize: 1 bottle of TORCO
#3 LOWEST RPM FOR PEAK TORQUE
#4 FIRST SPREADSHEET CALCULATING THE OCTANE EQUIVALENT OF TORCO
Added on 9-19-6:
#5 GAIN IN PEAK WHP BY ADDING TORCO TO PUMP + WATER/METH INJECTION
1st Prize: 1 bottle of TORCO
Tuning by the aces at PdxT on a Dynapack. . Build by Dustin, their ace mechanic.
And the games begin!
PdxTuners and their families aren't eligible!
ka mano is offline   Reply With Quote
Old 02-05-2006, 06:51 AM   #2
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default here's the mod list...
...and Dustin makes it look sweet!
POWERTRAIN
. Axis Power Tuning: STi 2.5L balanced & blueprinted shortblock with forged & coated Mahle pistons
. . . . . DPR Racing: cylinder head port & polish
. . . . . . . . . . . .Kelford: stage 3+ cams... 274/276 @ .010 and 232/225 @ .050, with .403" lift (the 'F' cam)
. . . . . . . . . . . Coworth: SS valves +1mm head diameter
. . . . . . . . . Supertech: seats, dual springs, titanium retainers
. . . . . . .Garrett: GT3076R .82 a/r turbocharger with 3" GT ballistic exhaust housing
. . . . . . . . TiAL: 44mm external wastegate
. . . . . . Aquamist: 2d water injection with 30cc accumulator and DDS3 gauge
. . . . . . . .APEXi: AVC-R electronic boost controller
. . . . . . . .Perrin: turbo kit (thermo-wrapped & coated), crank pulley, modified & flow-tested injectors, and catch can #1
. .PdxT/DentSPORT: custom modification of Perrin DP and WG pipe to fit GT ballistic 3"-outlet turbine
. . . Iota Research: PnP of TGVs, throttle body, intake manifold, header, UP, & turbo
. . . . . . . . NGK: iridium #7 plugs
. . . . . . . Walbro: Buschur Racing fuel pump
. . . . . . . GReddy: header (port-matched, thermo-wrapped & coated), catch cans #2 and #3, and EVO2 muffler
. . . . . . TurboXS: fuel rails, UTEC, BOV, and FMIC with TurboTec-wrapped cold tubes
. . . . . . . . Cobb: AccessPort with base map for injector scaling and base timing
Performance Coating: Chromex-coated intake manifold
. . . . . . . . .A-N: fittings with stainless-steel and reinforced rubber lines
. . . . . . . . . STi: 6-speed drivetrain
. . . . . . . .Exedy: Hyper Twin Racing clutch
. . . . . . .Kartboy: short-throw shifter
. . . . . Neetronics: PDC-01 DCCD
. . . . . . . . PWR: radiator
. .PdxTuning/Mocal: oil cooler
HANDLING and BRAKING
. . . . . . . . .SSR: 17x7.5 Competition... 12.7 lbs x4
. . . . . . .Michelin: 235/40 YR17 PS2... 21 lbs x4
. . . . . . . Brembo: front and rear brakes
. . . . . . . . . STi: steel braided brake lines
. . . . . . . . Perrin: Positive Steering Response System, rear sway bar & end links
. . . . . . . . Cusco: carbon-fiber rear strut tower brace
. . . . . . . . .Tein: Flex coilovers and Electronic Damping Force Controller
INTERIOR and ELECTRONICS
. . . . . . . .custom: upholstery / painted trim / window tint / rear seats removed
. . . . . . . .MOMO: Race Air Leather/Aluminum shifter knob
. . . . . . Defi-Link: gauges (OT, OP, fuel pressure, etc.) and display w/ peak hold / warn / record
. . . . . . . . .Blitz: DTT DCII turbo timer
. . . . . . Valentine: Valentine 1 radar detector with remote audio / display
. . . . . BlinderUSA:
Blinder M40 X-Treme Laser Jammer
. . . . . . . FIAMM: 130dB 485Hz horn plus 138dB 405Hz horn (Magnum Blaster)
. . . . . . .Kenwood: 25th anniversary eXcelon XXV-05V head. 50W x4 + 47W x1
. . . . . . .Kenwood: touchscreen monitor /receiver /DVD /VCD /MP3 /CD-ROM
. . . . . . . .Boston:
GT-20 2x100W & GT-22 2x175W amps (front speakers + sub)
. . . . . . . .Alpine: MRP-F240 200W 4-chan. amp (center channel + components)
. . . . . . . .Boston: Z5 surroundsound speakers with Neo Type-M2 imaging (clock display removed for center channel speaker)
. . . . . . . Pioneer: TS-SW124D 12" 1200W shallow-mount subwoofer
. . . . . . .Kenwood: eXcelon KDC-CX87 20-bit resolution 10-disc CD changer
. . . . . . . . Sirius: satellite radio
. . . . . . AutoPage: security alarm system
EXTERIOR
. . . . . . . Seibon: carbon-fiber reverse hood scoop
. . . . . . . . .STi: jdm front lip
. . . . . . . . OEM: jdm rear aero-splash set
Old 02-05-2006, 06:52 AM   #3
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default Dan Paramore's notes...
Here's the headwork... wait'll you see the pics!
Notes from DPR
combustion chamber volume: #1: 48.0cc; #2: 48.1cc; #3: 47.9cc; #4: 48.0cc
intake seat pressure: 83 lbs @ 1.448" ISH / 160 lbs @ .400" lift / .985" CB / .064" BCB
exhaust seat pressure: 81 lbs @ 1.456" ISH / 157 lbs @ .400"/ .985’ CB / .071" BCB
intake port runner volume: 140cc
exhaust port dogleg: 140cc
exhaust port straight: 120cc
seat width: set up for durable street / road-race application
int valve guide-to-stem clearance: .0017" -0 +.0003"
exh valve guide-to-stem clearance: .0019" -0 +.0003"
head thickness: .018"
amount milled: zero
lash intake: .0055" - .006" (with lube )
lash exhaust: .0095"- .0011" (with lube)
cam journals: straight
cam journals: deburred, lapped, planed, and polished
cam caps: deburred, lapped, installed, line-honed and polished
camshafts: installed (no valve) and tested for fit.
lifter buckets: sides and face are polished
bucket bores: deburred top & bottom, then polished.
valve spring retainers weight: 5.4g each (stock is 14g)
spring motion mass: 9.29 (stock 13)
keepers: 1g
total weight: 15.6g (stock 28.9g)
intake valve: 53g
intake valve: 1.450" diameter back cut w/ flat face & polished margin
exhaust valve: 52g
exhaust valve: 1.300" diameter, flat polished margin, radiused 1.300"
flow testing: multiple tests on file
bore size: STD
port: mold created
valve & seat: angles and specifications on file
Old 02-05-2006, 06:52 AM   #4
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default whp predictions...
Post your predictions and I'll put them up here.
(8-22-06: had to move torque and rpm predictions to post #5 as the character limit was reached in this post.)
PEAK WHP
675 OvrClkdPmp
606 Virusx86
601 Rando
600 Last
594 conker69
592 stitremen2
590 shvrdavid
587 Irishman
584 John__Gotti
581 Erconcepts
575 txl146
564 garie
563 Crowder13
562 blowbyu24
560 hondahata
557 bpang1
556 06WRXTR
555 vwown3d
552 Peeblesmx445
551 dallas_wrx_blue
550 herewegoagain
545 Worxman02
544 audio1der
541 FromAP1toSTI
539 SPOOLN
537 White 2.5rs
536 Ceyvme
535 dmross
534 forced4
532 bwrxzboost
531 2ndGearFling
530 Cardiggity73
529 SolidSnake
528 ControlFreak
527 Distinctive
526 WejR20X
525 Blennophobic
524 dudical26
523 LickwidS0ap
522 theicewall
521 adamrmr
520 mno
519 RR02wrx
518 linkzard
517 PHMetallic
516 trbowrx
515 F22-Raptor
514 js3324
513 GregsblueRex
512 RipinRichKids
511 slvr02scooby
510 xS2k
509 boundy3
508 02SilverRex
507 jstbstn
506 Ctracer911
505 P-TownWRX
504 04blue-meanie
503 midnite_wrx
502 MTOWRX
501 Striker13
500 turboed22
499 gotti
498 channerman
497 WRXRallyBlue
496 drees
495 614inda617
494 ImposSTiR
493 powerleak
492 eviltuna7
491 DarthChicken
490 BREWPUBEAVER
489 santofontana
488 STiyiyi
487 broken_gears
486 goofywrx
485 HighWayDrifter
484 OppositeLock
483 Need BB
482 platinum_sti
481 jjimpreza
480 raineri
479 rjrutzky
478 speedemn9
477 eatus ravenous
476 MF-DIF
475 ProxyWRX
474 dentsport
473 n2xlr8n
472 ShaggyGT
471 specialev
470 wrex03
469 millerni
468 STi-JDM
467 InsatiableAmos
466 petawabit
465 Gfunk720
464 Turbo4me
463 engineerx
462 BOXER28
461 modaddict
460 dvang
459 STimo
458 Chiketkd
457 06BlackSTIwith550WHP
455 02WRX2.5
453 JNUTZ
450 SW00P_G
448 Crystal_Imprezav
447 TexSurfer
443 B16A2NR
442 RichWRX
441 wrxskier18
435 SilverSurfer04STi
423 innova
420 timmydogg
419 WRX8XB
418 Defiantspaz
PEAK WHP ADDED BY TORCO
40.5 millerni
28.2 aps2fast4u
27.6 SilverSurfer04STi
23.3 STimo
21.8 Ceyvme
19.9 02wrbrex
18.6 WRXRallyBlue
16.2 theicewall
Old 02-05-2006, 07:31 AM   #5
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default predictions for peak wtq and lowest rpm for peak wtq
PEAK TQ
635 Last
630 OvrClkdPmp
601 conker69
576 stitremen2
570 Carndiggity73
563 Irishman
550 Worxman02
547 wrxzboost
545 WejR20X
544 garie
540 herewegoagain
537 Crowder13
536 slvr02scooby
535 trbowrx
531 Striker13
530 GregsblueRex
529 John__Gotti
528 LickwidS0ap
527 FromAP1toSTI
525 BREWPUBEAVER
522 SPOOLN
520 xS2k
519 614inda617
518 boundy3
517 WRXRallyBlue
516 audio1der
515 Blennophobic
514 dmross
513 Ceyvme
512 2ndGearFling
511 Peeblesmx445
510 linkzard
509 Erconcepts
508 InsatiableAmos
507 ControlFreak
506 bpang1
505 dallas_wrx_blue
504 theicewall
503 SolidSnake
502 Rando
501 B16A2NR
500 specialev
499 PHMetallic
498 forced4
497 turboed22
496 aimetti
494 HighWayDrifter
465 06BlackSTIwith550WHP
493 Ctracer911
492 P-TownWRX
491 02SilverRex
490 F22-Raptor
489 jstbstn
488 drees
487 vwown3d
486 04blue-meanie
485 millerni
484 Distinctive
483 platinum_sti
482 White 2.5rs
481 shvrdavid
480 RipinRichKids
479 MTOWRX
478 STiyiyi
477 powerleak
476 eviltuna7
475 raineri
474 rjrutzky
473 goofywrx
472 happasaiyan
471 STimo
470 santofontana
469 jjimpreza
468 OppositeLock
467 midnite_wrx
466 broken_gears
465 channerman
464 modaddict
463 gotti
462 engineerx
461 Need BB
460 ProxyWRX
459 Turbo4me
458 BOXER28
457 dentsport
456 js3324
455 n2xlr8n
454 ShaggyGT
453 Defiantspaz
452 dudical26
451 mno
450 STi-JDM
449 ImposSTiR
448 Virusx86
447 DarthChicken
446 timmydogg
445 Gfunk720
444 speedemon9
443 Chiketkd
441 petawabit
440 dvang
439 TexSurfer
438 Crystal_Imprezav
435 JNUTZ
432 RichWRX
431 SW00P_G
430 Blackboxracing
429 wrxskier18
427 wrex03
425 SilverSurfer04STi
423 WRX8XB
401 innova
RPM WHEN MAXIMUM WTQ IS FIRST ACHIEVED
6000 herewegoagain
5900 JNUTZ
5850 shvrdavid
5800 OvrClkdPmp
5790 06BlackSTIwith550WHP
5500 vwown3d
5480 DarthChicken
5450 Chiketkd
5400 ImposSTiR
5300 jjimpreza
5250 SW00P_G
5200 Julio
5150 LickwidS0ap
5100 audio1der
5050 modaddict
5000 bpang1
4950 F22-Raptor
4930 conker69
4925 Carndiggity73
4900 Blennophobic
4899 ControlFreak
4897 2ndGearFling
4880 blowbyu24
4875 mno
4865 06WRXTR
4855 garie
4850 Gfunk720
4835 turboed22
4825 Worxman02
4810 WejR20X
4801 BREWPUBEAVER
4800 RichWRX
4795 Irishman
4790 slvr02scooby
4785 platinum_sti
4780 STiyiyi
4777 drees
4775 WRXRallyBlue
4772 Last
4770 John__Gotti
4765 wrex03
4760 wrxzboost
4755 White 2.5rs
4752 JBravo920
4750 SilverSurfer04STi
4747 speedemon9
4735 GregsblueRex
4725 xS2k
4720 boundy3
4715 happasaiyan
4705 linkzard
4702 TexSurfer
4700 Striker13
4690 OppositeLock
4680 MF-DIF
4675 dentsport
4655 trbowrx
4650 Blackboxracing
4640 wrxskier18
4635 Crystal_Imprezav
4620 Ceyvme
4605 dvang
4602 timmydogg
4600 Defiantspaz
4590 eviltuna7
4585 dmross
4580 n2xlr8n
4575 midnite_wrx
4553 02SilverRex
4550 WRX8XB
4520 PHMetallic
4511 Erconcepts
4510 FromAP1toSTI
4500 ProxyWRX
4495 theicewall
4490 gotti
4480 Turbo4me
4478 forced4
4475 santofontana
4465 Need BB
4460 goofywrx
4454 channerman
4452 Distinctive
4450 rjrutzky
4438 Virusx86
4430 dudical26
4425 MTOWRX
4420 Ctracer
4401 B16A2NR
4400 02WRX2.5
4390 powerleak
4375 aimetti
4367 Crowder13
4365 SolidSnake
4350 petawabit
4340 Peeblesmx445
4320 P-TownWRX
4300 jstbstn
4255 millerni
4280 SPOOLN
4275 InsatiableAmos
4260 engineerx
4250 innova
4240 614inda617
4230 STi-JDM
4225 ShaggyGT
4200 RipinRichKids
4175 Rando
4150 RR02wrx
3890 HighWayDrifter
Old 02-05-2006, 08:45 AM   #6
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Not empty for long...
Old 02-05-2006, 08:47 AM   #7
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Out with the old...
Need something in here, too...
Old 02-05-2006, 09:13 AM   #8
JNUTZ
Member#: 90132
2003 WRX
Rally Blue
I hope I can atleast win a T-shirt..... Dude I bet you're excited to get your car done. I need to get down to PDX and have them finish tuning my car.
JNUTZ is offline   Reply With Quote
Old 02-05-2006, 09:30 AM   #9
Defiantspaz
Member#: 101100
04 WRX STi
WR Blue Pearl
Peak WHP = 418
Peak WTQ = 453
RPM of peak WTQ = 4600
Defiantspaz is offline   Reply With Quote
Old 02-05-2006, 09:41 AM   #10
ka mano
Member#: 78022
PdxT built 2.5L 6sp
It's starting to come together. Good luck with your tune!
PM'ed you.
Old 02-05-2006, 09:41 AM   #11
gpatmac
Member#: 18446
2002 WRX wagon
psm
I'm not gonna guess because I never win anything, but I bet you've put at least $26,493.61 into your car.
gpatmac is offline   Reply With Quote
Old 02-05-2006, 09:42 AM   #12
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Originally Posted by Defiantspaz
Peak WHP = 418
Peak WTQ = 453
Those #'s belong to you! Torque-y!!
Old 02-05-2006, 09:46 AM   #13
ka mano
Member#: 78022
PdxT built 2.5L 6sp
It's a moving target!
Old 02-05-2006, 10:20 AM   #14
gpatmac
Member#: 18446
2002 WRX wagon
psm
I was speaking from personal experience.
Congrats & good luck. Hopefully I'll be able to post a similar thread soon.
Old 02-05-2006, 10:36 AM   #15
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default ...down the rabbit hole!
Thanks. I'm sure your ride is plenty fun as it is... but let us know your plans when you shape 'em up!
Old 02-05-2006, 10:58 AM   #16
SilverSurfer04STi
Member#: 71542
2013 WRB BRZ
I'll guess 435 whp
I'll guess 425 wtq
I'll guess you make earliest peak torque by 4750
Originally Posted by ka mano
. . . . . . . . . . PEAK HP
JNUTZ. . . . . . . . . . 453
02WRX2.5. . . . . . . 420
Defiantspaz. . . . . . 418
. . . . . . . . . . PEAK TQ
Defiantspaz. . . . . . 453
JNUTZ . . . . . . . . . . 435
. . . . . . . . . . RPM of EARLIEST PEAK TQ
JNUTZ. . . . . . . . . . 5900
Defiantspaz. . . . . . 4600
SilverSurfer04STi is offline   Reply With Quote
Old 02-05-2006, 11:19 AM   #17
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
No harm in guessing.
is this like price is right? j/k
I'll guess
419 Peak hp
423 Peak Tq
4550 Rpm of Earliest Peak TQ
WRX8XB is offline   Reply With Quote
Old 02-05-2006, 11:22 AM   #18
ka mano
Member#: 78022
PdxT built 2.5L 6sp
Default Come on down!
I always wanted the girl moving the curtain... who cares about what's behind it!
Old 02-05-2006, 11:30 AM   #19
Gfunk720
Member#: 42549
E92 M3
B9 Audi SQ5
Cant hurt to guess...
My prediction
-465whp
-445wtq
-Peak Tq at 4850
Gfunk720 is offline   Reply With Quote
Old 02-05-2006, 11:31 AM   #20
garie
Member#: 26607
2002 wrx wagon
Peak WHP = 564
Peak WTQ = 544
RPM of peak WTQ = 4855
garie is offline   Reply With Quote
Old 02-05-2006, 11:33 AM   #21
HighWayDrifter
Member#: 8908
2012 Ford Raptor
485 peak hp
494 peak tq
3890 rpm of eaarliest peak tq
HighWayDrifter is offline   Reply With Quote
Old 02-05-2006, 11:59 AM   #22
RichWRX
Member#: 15544
STI hydra,2.65l
BW s374 turbo(twin scroll
1. Maximum wheel horsepower === 442
2. Maximum wheel torque==432
3. RPM when maximum wheel torque is first achieved==4800
RichWRX is offline   Reply With Quote
Old 02-05-2006, 12:11 PM   #23
MTOWRX
Member#: 57621
2008 LGT
Black Pearl
Hp: 502
Tq: 479
Rpm: 4425
MTOWRX is offline   Reply With Quote
Old 02-05-2006, 12:13 PM   #24
BREWPUBEAVER
Member#: 84547
06, Lafawnduh
Fender rolling king
470whp
465wtq
530whp on C16
519wtq on C16
4800rpms
BREWPUBEAVER is offline   Reply With Quote
Old 02-05-2006, 12:14 PM   #25
RipinRichKids
Member#: 87980
Evo8 MR
350whp 93 stock turbo :)
512 peak hp
480 peak tq
peak tq 4200rpm
RipinRichKids is offline   Reply With Quote
WTB Complete type 2.5l Cosworth heads w cams bodyshot Private 'Wanted' Classifieds 2 12-14-2009 11:22 PM
2.5L hybrid, retarding intake cams question Turbo_Mike Built Motor Discussion 20 01-06-2008 02:56 AM
PA: DOHC 2.5L heads w/ new cam seals, intake manifold t3hWIT Engine/Power/Exhaust 67 09-07-2007 10:05 PM
wtb- 2.5l n/a twin cam engine or long block redxbob Private 'Wanted' Classifieds 0 10-27-2006 07:06 PM
WRX vs. 2.5L STi crank and cam position sensors - the same? Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-24-2003 09:35 AM
