02-07-2006, 02:47 PM | #1 |
Member#: 1465
Vehicle:2000 rs sedan brp |
rough idle? help
hello people,
my 2000 impreza 2.5rs is idling very roughly, dash board light goes dim and bright, feel like it is going in a stalling mode. what are some of the area i should be looking at to inspect this probem? thanks
02-07-2006, 03:04 PM | #2 |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
Most likely....
...dirty injectors....
Run a few bottles of cleaner through. should do the trick. |
02-07-2006, 03:26 PM | #3 |
Member#: 1465
what brand of injector cleaner do u recommand?
02-07-2006, 09:21 PM | #4 |
Member#: 1465
the CE light went on today on my way home from work.
i got it check from a frd it said 'fuel trim malfunction bank 1" anyone experience this problem before? CE light is gone now, but the idling is still rough well i did a little serach and i got this http://forums.nasioc.com/forums/show...im+malfunction but just wondering if ppl have more advice or suggestion to the problem Last edited by gerardchau; 02-07-2006 at 10:32 PM. |
02-08-2006, 04:53 PM | #5 |
Member#: 1403
TXIC
Gumout, STP or Gunk. Concentrated of course. They all work about the same.
<---- Knows... was store mgr for Checker/Shucks/Kragen for three years. Course if you threw a code thats different. Now you have somewhere to start. Injector cleaner is cheap maintanence for our cars though as the injectors are easily clogged, especially if you use questionable gas. |
New turbo, rough idle????Help!!!! | KUEDA | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 06-02-2010 05:11 PM |
Flashing CEL/No codes/Semi Rough Idle- HELP! | Gfunk720 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 24 | 08-23-2008 02:19 PM |
Help!!Rough Idle | RexRexRex | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 10-25-2003 04:09 AM |
help/comments w/rough idle issues? | Benjamin Tang | Legacy Forum | 14 | 10-01-2003 05:55 AM |
Very rough idle...HELP! | bouse1 | Normally Aspirated Powertrain | 1 | 08-10-2001 03:15 PM |
