02-08-2006, 11:52 AM | #1 |
Member#: 100444
obx headers
I was wondering if anyone that istalles a set of the obx headers are getting a check engine light as a result of it? Are the bungs in the cats long enough to get rid of the code?
02-08-2006, 11:56 AM | #2 |
Member#: 44887
NESIC
Vehicle:00 GC6 Silver |
You will get a CEL from almost any aftermarket header.
02-08-2006, 11:57 AM | #3 | |
Member#: 34670
South East
Vehicle:2016 slowmobile |
02-08-2006, 04:40 PM | #4 |
Member#: 78314
Vehicle:04 PSM WRX Audi mask the right way |
How does one get rid of the CEL???
02-08-2006, 04:47 PM | #5 |
Member#: 81338
Vehicle:2005 2.5 RS Wagon Crystal Gray Metallic |
engine management or praying
02-08-2006, 05:03 PM | #6 |
Member#: 74769
Vehicle:07 WRX TR UGM |
well seeing that the O2 bung is on the wrong side of the pipe...ya, thats OBX for ya
02-08-2006, 06:47 PM | #7 |
Member#: 21935
TXIC
Vehicle:2010 '13 BRZ Premium WR Blue Pearl |
To this day I haven't had a CEL related to the O2 or the cat with my OBX header and mine has been on since October. I guess it depends on the car.
-Jim |
02-08-2006, 11:36 PM | #8 |
Member#: 58806
Vehicle:1998 RIP Legacy2.5GT 2.2L legacy wagon |
Yea ive had the headers on since December and i drive ALOT ..... no 02 sensor related CEL's ....
I do have EGR malifunciton code... but not from that |
02-09-2006, 12:12 AM | #9 |
Member#: 74907
NWIC
Vehicle:98 cam'd EJ251 Wrx Tranny,slowr than ish |
i was wondering...what if you keep your rear CAT and move the rear o2 sensor BEHIND the 2nd cat....wonldnt that get rid of the CEL from the lack of a 1st/header cat? only reason i ask is because im going to get aftermarket headers w/o a cat and would like to know if my theory is valid or BS.
~Josh~ |
02-09-2006, 12:26 AM | #10 |
Member#: 68340
Vehicle:2006 WRX SMG |
i too would like to know, if we get the OBX header (which has the O2 bung on the wrong spot), and get a HFC from magnaflow with 2 O2 bungs on the cat; could we plug the bung on the header and use the 2 bungs on the HFC? also would like to know if the cat has to be welded in a certin direction or could it be mounted in any direction?
thanks |
02-09-2006, 12:27 AM | #11 | |
Member#: 68340
02-09-2006, 01:55 AM | #12 |
Member#: 68340
anybody?
06-09-2006, 12:53 AM | #13 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Pat |
06-09-2006, 07:44 AM | #14 |
Member#: 94873
06-10-2006, 06:57 PM | #15 |
Member#: 120
AKIC
Anyone have an answer to the "bung in the wrong place" issue? I'm still curious.
Pat |
06-11-2006, 01:54 AM | #16 |
Member#: 16874
NWIC
Vehicle:2008 2008 Audi RS 4 2014 Audi S Q5 |
I think the issue was not so much the part of the header but the orientation. I think that it is on the top of the header, say 12 o'clock, and the heat shield interferes with it, where as the ideal location would be 8 o'clock.
Jared |
06-11-2006, 02:03 AM | #17 |
Member#: 5691
BAIC
Vehicle:2001 2.5 RS Silverthorn |
Header wrap will eliminate most CEL issues associated with headers. I've been running my ebay-borla-knockoff headers for about a year, not a single CEL.
06-11-2006, 04:00 PM | #18 |
Member#: 116636
Vehicle:2003 impreza black |
ive been look buying the head/cat ebay special any noticable power gains
06-11-2006, 07:54 PM | #19 |
Member#: 120
AKIC
There are dyno results posted in a few threads in this forum.
Pat |
06-20-2006, 09:31 PM | #20 | |
Member#: 1134
Vehicle:2015 Outback H-6 White |
OBX's eBay listing for the headers currently says "factory O2 sensor location," so maybe they caught wind of fitment issues and fixed it? I too am thinking of EL headers. TWE's unfortunately are the only ones that maintain the stock cat location, and also cost nearly a thousand clams. RalliTEK has no fitment issues, but bought from the same SEMA supplier that OBX did. So they seem to be very much the same header... ...save for fitment problems. That maybe are fixed now. Maybe...? Current auction: HERE! =S2= |
06-21-2006, 12:55 AM | #21 |
Member#: 91833
Vehicle:98 black RS-Sold Indy Forum's Kid |
2000 miles and no cel
06-21-2006, 09:21 AM | #22 | |
Member#: 94873
Yes, there are no fitment issue on these 2. 1st O2 located in the "Y". 2nd O2 located in the small straight pipe, after the resonator (which looks like a CAT). I replaced that (resonator + O2) with a HFC, also put in a new O2 right after the HFC. The wiring of the rear (2nd) O2 need to be extended as well. Mechanical CEL fix also put in. |
06-21-2006, 02:37 PM | #23 |
Member#: 1134
Mechanical CEL fix (PDM bung extension) hasn't done squat for me, so far. **shrug** Depends on the car I guess.
Yes I know they're basically the same header, mentioned that in an earlier post. But the OBX ones, at least a while ago, had fitment issues. The question is whether that's been fixed by OBX or not. |
06-21-2006, 10:25 PM | #24 |
Member#: 90968
VIC
Vehicle:2003 WRX WRB |
I've got the OBX header on my 2000 RS. Since the header eliminates both cats (yes, your car has two) don't be too surpised if you get CEL P0420 - cat inefficiency. I tried splicing a low pass filter into my rear O2 to clear-up the CEL - didn't work. Two thoughts.
Live with the warm glow of your CEL and check your codes weekly with a scanner. Or put tape over the light and check for codes weekly. Some of the later cars are less prone to P0420 when fitted with Borla headers (keeps the second cat). The OBX, as you get it, is completely catless. |
06-22-2006, 08:26 AM | #25 |
Member#: 1134
If I go with an OBX or RalliTEK, I'll remove the cat-delete pipe's resonator and weld in a high-flow cat and O2 bung.
2.5 RS OBX Header, Borla Header , Apex N1 Catback | arkady151 | MAIC Private Classifieds | 20 | 07-08-2012 09:35 AM |
WTT: My EL OBX Headers & HFC for your UEL Borla Headers and anycat | CRedfield | MAIC Private Classifieds | 3 | 07-31-2008 03:17 PM |
2.5 RS OBX Header, Borla Header , Apex N1 Catback | arkady151 | Engine/Power/Exhaust | 23 | 07-31-2006 10:47 AM |
OBX header vs. MRT header dyno results | Patrick Olsen | Normally Aspirated Powertrain | 7 | 06-26-2006 08:31 AM |
OBX header? | PsycloneWRX | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 07-04-2002 10:00 PM |
