02-27-2008, 07:15 PM | #151 |
Member#: 47145
Vehicle:2012 Gas Saver |
there is greater velocity around a turn so it may actually be better for atomization.
02-27-2008, 09:04 PM | #152 |
Member#: 124263
Vehicle:2004 WRX Wagon RomRaider + UTEC Tuned |
Unless the cross sectional area of the pipe changes, velocity will (averaged across the pipe's diameter) remain constant. Bends have nothing to do with average velocity other than lowering the average velocity of the entire system. Each bend induces a loss that negatively impacts system flow.
Turbulence may increase a bit, but I'm not going to break out my old fluid dynamics book to see how much. I think that the most important concern is the possibility of the meth/H20 droplet impacting on the piping on the outside of the bend and rejoining the fine atomized droplets into larger drops, thus negating the atomization of the nozzle. Kind of like how a centrifugal separator works. Buck |
02-28-2008, 04:39 AM | #153 |
Member#: 116499
South East
Vehicle:2005 WRX STi Black when clean |
right on thanks guys for the info I have the Perrin Blow-through and it has a 90 right infront of the TB so really just wanted to see if I need to place the nozzle right after it closer to the TP or would it help to have it back before the 90 degree bend. Just wanted to see what others have done and how it has worked out for them.
-Eric |
02-28-2008, 04:40 AM | #154 | |
Member#: 116499
South East
That was my real worrie and why I asked thanks Buck |
04-04-2008, 10:11 PM | #155 |
Member#: 173809
Vehicle:2005 WRX Black |
anyone know how to hook the Snow meth up to the utec so it works with my map switch.So I can run meth on one map an no meth on the other???????????????????
04-05-2008, 01:16 PM | #156 |
Member#: 18987
NESIC
Vehicle:2014 Forester Dark Grey Metallic |
You will essentially need to have a water/meth tune on one map slot, and then a pump gas tune on another map slot. Then when you want to run just pump gas, just unhook the snow controller (little plug on the back) and then the pump wont turn on a a certain boost level, or MAP voltage.
DP |
04-05-2008, 07:18 PM | #157 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
Best to put your more conservative pump gas map in slot one, as this is the one that valet mode defaults to for fueling. If you never use valet mode, it doesn't really matter.
04-05-2008, 10:32 PM | #158 |
Member#: 173809
So do I have to run any wires to the utec or just hook the meth up as if I had no utec? Going to turbo xs for tune an he said he would do like 5 pump gas tunes an 2 meth tunes I just don't know for sure how to hook the meth kit up so he can do it. I just don't want to run meth all the time because I have to order it. I've got the stage 2 MAP boost kit for larger turbo and it has the controller. also have map switch for utec.
04-05-2008, 11:55 PM | #159 |
Member#: 18987
NESIC
I know when I had UTEC, it only had 5 map slots, does it have 7 now? If so, 5 pump gas maps is cool, but how many different tunes do you need? I would get maybe high boost and low boost pump gas tunes, and high and low boost meth tunes. 4 Maps total. Less time on the dyno trying to perfect 7 maps. Also you can concentrate on 4 really good maps for what you need. If you need 7 different maps, go for it. I guess you know what you use the car for. But I digress, you don't have to hook up any other wires to the UTEC, unless you are using the spare solenoid on the UTEC to control the system. Are you using the UTEC to control the pump? Or are you using a Snow Performance varible controller either MAP or Boost Pressure. If you are using the snow controller, you would have have the UTEC selected to the appropriate MAP for methanol using the Map selector switch, and then make sure the meth controller is hooked up and set correctly based on your meth tune, and off you go. If the UTEC is controlling the pump, you have the have the pump signal wire hooked into the UTEC, so the UTEC can drive the pump based on parameters set by your tuner into the UTEC. If this is the case, he will have to select when the spare solenoid is not to be used (pump gas maps) (not sure if possible been a long time since UTEC, forgetting it's capabilities) Make sure you have him name the maps accordingly and tell you which maps are where so you don't mistakenly select the wrong map and run without meth when you should be.
DP |
04-06-2008, 01:09 PM | #160 | |
Member#: 173809
The tuner is the one that said 5 gas maps an 2 meth.I think 2 an 2 would be fine. I have to hook up the turbo xs solenoid to adjust the boost for the diff maps I'm guessing that will wire into the utec spare selonoid. I just don't want to run meth all the time I don't drag because I'm still on the stock tranny. I just wanted it for when someone wants some. Sorry I'm a newbee at this. |
04-07-2008, 08:29 PM | #161 | |
Member#: 18987
NESIC
DP |
04-07-2008, 09:30 PM | #162 |
Member#: 173809
So if I unplugg the controller it won't spray but what about the vaccum hose thats hooked up will that hurt anything engine wise? Also what would be better for more HP meth or alky. Not sure what to do 100% or 50/50. Not sure what the snow pump will take heard 100% meth hurts pump not sure about alky. I have to order meth unless I run washer fluid. I can get alky for $4.75 a gallon.2005 wrx 20g 7cm all suporting mods. Anyone tried both to see hp differances?
04-13-2008, 04:05 PM | #163 | |
Member#: 127670
Vehicle:2007 HTA GT3794 Darton Sleeved |
04-13-2008, 07:25 PM | #164 |
Member#: 18987
NESIC
04-16-2008, 07:42 PM | #165 |
Member#: 177683
SCIC
Vehicle:1998 JDM RHD Integra Black |
great info thanks guys
05-06-2008, 02:51 AM | #166 |
Member#: 59400
Vehicle:2018 STi TypeRA 420/ 2008 BMW 335XI 470AWHP |
Going to be getting tuned this weekend, road tuned, but only option here in Alaska. Because the tune will last close to a year, considering PDX can only fly up once a year to do this, I want to make sure I go with the right option.
I have the SMC kit and just had the kit upgraded (it's been dormant for 2 years). Anyways, should I get the tune for 50/50 water/meth mix or should I just get it tuned for denatured alcohol? I read the FAQ, but I didn't see on which one most people prefer. thanks, -Wes Going to post this in another thread, if this needs to be moved or deleted please do. Not sure if it was OK to ask this question here. Last edited by Wes_FSTGDB; 05-06-2008 at 03:04 AM. |
05-06-2008, 09:15 AM | #167 |
Member#: 17256
South East
There are only 5 "map slots" in the UTEC memory. Positions 6-9 on the switch rotate through the first 4 maps with Launch Control disabled.
05-06-2008, 12:17 PM | #168 | |
Member#: 18987
NESIC
DP |
05-06-2008, 02:24 PM | #169 | |
Member#: 59400
Thank you for the help. -Wes |
05-07-2008, 01:13 PM | #170 | |
Member#: 18987
NESIC
-DP |
06-03-2008, 01:47 PM | #171 |
Member#: 181515
so whats the best way to get rid of the cabin/trunk smell after use? besides not using it ofc. anyways even if i don't it lasts a long time.
06-03-2008, 02:09 PM | #172 |
Member#: 17256
South East
There is no smell unless you spill it while filling the tank. If you are using 50-50 meth-water, there will be very little smell even if you do spill it. If you are spraying it on your intercooler and get carried away, I think you might could smell it a bit. Just go easier with the button on the intercooler sprayer.
06-03-2008, 05:20 PM | #173 | |
Member#: 181515
I did run the car hard the other day for the first time since install so maybe that's it? Perhaps I'm not used to it? I've only had it for about 3 weeks now but i must say there came a point where it basically smelled like a nail salon if you know what i mean. |
06-18-2008, 09:56 AM | #174 | |
Member#: 18987
NESIC
Any other questions, ask. -DP |
07-11-2008, 07:58 PM | #175 |
Member#: 18987
NESIC
EDIT: I will throw some cliff note questions into this post due to the amount of questions I keep seeing in the main forum that would mostly be answered if people sat down and read this thread. I just hate to see someone have a bad experience due to someone coming on here, and asking what is best and having something sold to them that they don't need, or isn't up to their needs. I think all the water meth vendors are good, but as vendors you should be asking these people what their needs/budget and power goals are, before just willy/nilly suggesting a system. I had to add these here instead of the original post due to length. I have exceeded 15,000 characters. And to think I hated writing when I was in High School.
So away we go... Things to ask yourself when looking at a kit.... Only you can answer these questions... What is/are my power goals? Where/how am I going to install the kit? How much does meth cost, and how much will this kit use on average driving? What are my current power mods, and am I ready for meth yet? IE do I have the correct supporting mods? EM (engine management), injectors, aftermarket exhaust, etc. (Granted not all of the previous are required, but you will get much more out water/meth with that stuff.) EM is pretty much required. How technical is the kit to install, and am I technically minded enough to do the install? How much $$ do I have to spend on the initial cost of teh kit (reference the question above for this also...do I need someone to install this for me?) What are my intentions to upgrade (mods and water meth kit) in the future. (Am I going to need bigger jets, a bigger pump, a new kit or a re-tune)? How easy is meth to aquire around where I live? Do I need to have it shipped in? How much development went into the kit I am looking at? Good failsafes? Proven Gains? Simple install? Good packaging (ease of install)? General kit operation? If anyone can think of any other C/N questions I need to add here. Let me know. |
water / methanol injection kit -new or used | blazin sti | Private 'Wanted' Classifieds | 3 | 05-27-2006 09:01 PM |
Water/Methanol Injection or Race Fuel or Both | ejh25 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 03-28-2005 07:35 PM |
Derek Devises Water/Methanol Injection | mistaboosta | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 11-01-2004 06:52 PM |
Derek Devises Water/Methanol Injection | mistaboosta | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 0 | 11-01-2004 05:51 PM |
