02-09-2006, 10:40 PM | #1 |
Member#: 98104
supercharger?
I got a 2006 2.5 and I want to get it up to about 230 around the same hp as the wrx and i wanted to know wha should i get to get around that a supercharger, turbo charger? and any reccomendations on them, and how much?
02-09-2006, 11:19 PM | #2 |
RIP 10/12/83 to 02/10/08
Scooby Specialist Member#: 83254
NWIC
Vehicle:98 2.5 RS 04 WRX |
compression too high
engine blow up... Supercharger is much harder to do, It'll have to be custom and cost alot. Turbo can be done using WRX parts. You might be able to get 230hp, but you'd just be asking for your engine to die. You'll need some kind of Engine Management, it can be reliable. But if it Detonates, that'll be the quick end to your motor. Do searches in the Aftermarket Forced Induction forum, there is tons of information on this subject. |
02-10-2006, 01:12 AM | #3 |
Member#: 29355
NWIC
the answer is:
none of the above. if you want 230 hp you should get a WRX. afaik there are no boosted 06s yet, and due to the redesigned heads it will be even harder than previous engines to boost reliably. and previous generations were nearly unboostable anyway. on top of the management woes of the previous cars, you'd have to negotiate for cam crossover!!!! if you want to try, go ahead, but you'd better be willing to spend upwards of 5,000 just for the parts and management. just don't do it. and again, wrong forum. but since you asked, the advice of the majority would be either swap the engine or just trade in for a wrx. |
Supercharge or not to supercharge, that is the question. | ScoobySean | Normally Aspirated with bolt-on Forced Induction Powertrain | 14 | 04-09-2006 12:06 PM |
('93-'01) Vortech supercharger | wcbjr | Impreza Forum | 10 | 06-09-2001 09:14 AM |
('93-'01) Rimmer superchargers | jgring | Impreza Forum | 5 | 06-06-2001 01:51 PM |
Eaton Superchargers Any good Supercharging a RS | Jimmy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 15 | 04-24-2001 06:57 AM |
('93-'01) Supercharger for my 2001 RS? | tnt_rocks | Impreza Forum | 0 | 04-23-2001 02:43 PM |
